Page 12 of 18
Re: Special discount for Forum members on Plugwise.
Posted: Tue Feb 23, 2010 4:12 pm
by Tiz
Then I would definitely contact Plugwise about this because I believe that they do want this to work. If you fill in an imaginary discount code you explicitly get a message that it is not valid. Maybe this is a bug introduced when they changed the site. Good luck with that.
Posted: Tue Feb 23, 2010 4:40 pm
by Harry
after 4 a 5 tries i got it, order is out .
what can it be hard to spent money,........i gese you have to be a women to make that easy
Posted: Tue Feb 23, 2010 6:49 pm
by Wim2008
At the first page from paying you have to give in the discount.
B.R. Wim
Posted: Tue Aug 17, 2010 4:43 pm
by Harry
is there a new discount, have to expand whit two new circle's.
Posted: Thu Aug 19, 2010 1:59 pm
by John
Currently there is an discount of approx. 20% for memebers of "Vereniging Eigen Huis". The discount is valid till the 31th of August.
Posted: Thu Sep 02, 2010 4:25 pm
by yjb
New discount available 20% when mentioning the code: UITBREIDING!
Valid until 18 October
20% discount on PlugWise modules
by RdP
Posted: Sun Sep 19, 2010 3:31 pm
by mike
is the plugwise discount offer presently vailable (19 september 2010) ?
Posted: Sun Sep 19, 2010 5:51 pm
by j.hoekstra
Affirmative!
Use it when checking out, at the bottom you can add UITBREIDING! after that it becomes visible at the place where you put customer data.
Posted: Mon Sep 20, 2010 12:35 am
by PietjeNL
Its active till 18 oktober, like the link above says.
Posted: Sat Oct 02, 2010 11:58 am
by PietjeNL
Posted: Tue Jan 18, 2011 1:07 pm
by jheerink
The Gaslicht code is still valid and can also be used to order other items in the online shop directly at plugwise
you can also get a further reduction on the new introduced switch which is presently "on sale"
You can order or via de Gaslicht site and use their link and then later continue to the standard plugwsie shop
or easier to use their discount ode and go strait to the plugwise store. The code is GASLICHT00ADEF
Good luck, Saved me an other €60,- on plugs and some switches
Posted: Sat Apr 02, 2011 9:11 am
by abl
The discountcode of Gaslicht is not valid anymore. Does anybody know another code currently valid? I want to order the extension kit...
Posted: Tue Apr 05, 2011 9:22 am
by Niels
Try "SWITCH" for 20% discount, working until 15th of april.
Posted: Thu Apr 07, 2011 12:05 am
by abl
Thanks for this discountcode. It works and I just ordered the extension set...
