HS3 MQTT Plugin
Alles m.b.t. de Homeseer MQTT Broker Plugin van Willem Eradus (Dutch Forum)
Moderator: Willem4ever
raymonvdm
Re: HS3 MQTT Plugin
Post by raymonvdm »
did you check the firewall on you`re windows 7 machine, and verified that Mosquito is actually running?
geert-jan
Re: HS3 MQTT Plugin
Post by geert-jan »
In the mqtt config you checked 'anonymous' and you also provide username/password.
When anonymous is checked, the username will not be send to the mqtt broker.
Can you check your broker config?
Geert-Jan
Verstuurd vanaf mijn ONEPLUS A5000 met Tapatalk
EmilySmith1
Re: HS3 MQTT Plugin
Post by EmilySmith1 »
I manually added Mosquitto in windows Firewall and now it works
Thanks
[img]
[/img]
Can HS3 MQTT plugins manipulate strings Like On,Off,Away,Open,Close etc and convert them to numbers 1,2,3,4,5....and so on
Thanks
Emily
drodegeb
Re: HS3 MQTT Plugin
Post by drodegeb »
I have looked through everything, but can't seem to find it. Is there a way for an MQTT message to control a Homeseer device? Not a device that is a subscription, but instead a native device like a ZWave light switch. I see Homeseer sends out a topic like "/homeseer/78/value" with 0 for off and 255 for on. But, that topic doesn't seem to control it when it's sent from outside homeseer.
Thank You,
Dave
webmeezer
Re: HS3 MQTT Plugin
Post by webmeezer »
Is there a chance you'll add SSL/TLS support (ie port 8883) to the plugin?
Thanks,
Z
geert-jan
Re: HS3 MQTT Plugin
Post by geert-jan »
SSL/tls support is on the feature list.
Currently I am busy with refactoring the implementation to make next steps more easy/testable, next I pick up this feature.
Geert-Jan
nickneutrino
Re: HS3 MQTT Plugin
Post by nickneutrino »
In addition to port 8883, are you intereted to integrate with IOT Core for Google Cloud Plattform.....
Because i create a device entry on the cloud and is mandatory connect with a cert key. :)
rmiles7721
Re: HS3 MQTT Plugin
Post by rmiles7721 »
drodegeb wrote:I have looked through everything, but can't seem to find it. Is there a way for an MQTT message to control a Homeseer device? Not a device that is a subscription, but instead a native device like a ZWave light switch. I see Homeseer sends out a topic like "/homeseer/78/value" with 0 for off and 255 for on. But, that topic doesn't seem to control it when it's sent from outside homeseer.
Thank You,
Dave
I would like to know the same thing. I can see the MQTT topics getting sent out and when I turn a lamp off and on the corresponding lamp in HASS turns off but when I do it in the opposite direction nothing happens. I get this in my HS log:
Sep-30 5:08:25 PM MQTT Info: Received MQTT topic: /homeseer/masterbedroom/desklamp payload: 0
critical_
Re: HS3 MQTT Plugin
Post by critical_ »
Thank You,
Dave
Same here. I'd like to have a device connected to HomeSeer (like a fan, light switch, or something else) controllable from Home Assistant over MQTT without workarounds.
geert-jan
Re: HS3 MQTT Plugin
Post by geert-jan »
Interesting feature request, that already popped-up several times.
Makes Homeseer a bridge between MQTT and other protocols like z-wave.
It is on the feature list, but due to my limited time, what has a higher priority: TLS/SSL encryption support or this request to control HS devices via MQTT?
Geert-Jan
raaguirr
Re: HS3 MQTT Plugin
Post by raaguirr »
Hi!! first of all this is a great plugin, congratulations for your work...
I have simple question, is there a way to specify other port than the default 1883?? i have my mosquitto broker running on the 10350, is there a way to configure to get to this port?
Thanks a lot
geert-jan
Re: HS3 MQTT Plugin
Post by geert-jan »
in the current version the port number cannot be changed. I plan to implement this together with the TLS/SSL support.
Geert-Jan
Fredrick
Re: HS3 MQTT Plugin
Post by Fredrick »
Hey guys,
Trying to get this plugin set up, but I'm struggling with the basics. I've got a Mosquito server set up, and I'm connected to it:
I can also see PINGREQ/PINGRESP in my Mosquito log.
I want to publish the value of some devices, but nothing seems to be sent at all from this plugin. Dont know what I'm doing wrong:
In the log (with info-logging level) this is all I get:
Any idea how I can get it to publish values? I've also tried setting up an event to manually publish device value and custom topic, but nothing is sent.
Thanks!
geert-jan
Re: HS3 MQTT Plugin
Post by geert-jan »
in the configuration I see that you connect anonymous to the MQTT broker, and you also supply username/password.
If the MQTT broker needs a username/password than uncheck the 'anonymous' flag.
Geert-Jan
critical_
Re: HS3 MQTT Plugin
Post by critical_ »
geert-jan wrote:Interesting feature request, that already popped-up several times.
Geert-Jan
I would prefer the ability to control HS devices via MQTT. The TLS/SSL support with port changing ability can come second. A lot of us would be able to use the plugin more regularly so we can give you more feedback. Thanks you.
Return to “Homeseer MQTT Plugin Forum”
