Page 13 of 86
Posted: Sun Nov 12, 2017 12:56 am
by dennis071nl
@Toonz,
I f&**cked up the upgrade to firmware 4.x, eventually -with the help of Marcel, im back online, but i cant get afvalwijzer to work.
Downloaded the ICS from the katwijk site, placed it in /root/waste/waste-calendar.ics.. But the tile keeps empty...
Is there something that i miss??? Or maybe another file location in 4.8?
Please push me a bit in the right direction please!
Posted: Sun Nov 12, 2017 9:21 pm
by Toonz
Have you selected waste provider 5 in the config screen (access by clicking on the tile) ?
Secondly, the correct filename is /root/waste/waste_calendar.ics (not a '-' between waste and calendar but a '_')
Posted: Sun Nov 12, 2017 9:54 pm
by dennis071nl
Excellent, running in the tile with the upcoming pickup rounds...
is there a way to test the dimstate icon??
Posted: Mon Nov 13, 2017 1:03 am
by Toonz
Just patience.....till 18.00 the day before next collection day...
Posted: Mon Nov 13, 2017 9:23 pm
by dennis071nl
OK, i'll hold my horses and keep my fingers crossed...
#volvertrouwen
Posted: Wed Nov 15, 2017 9:32 pm
by dennis071nl
Just to inform you..
Everything all right; got the icon in dim state
Posted: Thu Nov 16, 2017 12:28 am
by Toonz
Thanks for the feedback, much appreciated
Posted: Mon Nov 27, 2017 12:11 pm
by Templar
Toonz,
The app Domoticz/
Dashticz V2 also has a list of Garbage collectors, check out this file for more info:
github.com/robgeerts/dashticz_v2/blob/m ... garbage.js
Posted: Mon Nov 27, 2017 1:01 pm
by Toonz
Thanks, I know, but I only add new providers on request. It doesn't make sense to spend time on adding providers which no one is using on Toon.
Posted: Mon Nov 27, 2017 3:33 pm
by Demif
Hi All
is it possible to add
http://www.omrin.nl/bij-mij-thuis/servi ... alkalender in the waste app.
thanks
Posted: Mon Nov 27, 2017 6:49 pm
by Toonz
Yes, can do. The website is using the POST method to submit zipcode/housenr. Unfortunately Toon is not supporting the POST method.
The standard workaround is to access to page on your PC, enter your zipcode, save the results page and copy it over to Toon.
As the file contains the dates for the whole year you only have to do this once per year around Jan 1st (or whenever they publish the new calendar for the year)
Will put it on my to-do list.
Posted: Tue Nov 28, 2017 9:08 pm
by Demif
thank you,
but i had no succes, thry the manual (option 3) and the result is a white tile. on toon is no Omrin number, is number 14 ok?
greetz Freark
Posted: Wed Nov 29, 2017 1:12 am
by Toonz
Demif wrote:thank you,
greetz Freark
I have not yet implemented Omrin. Will be in the next release (isn't like any other waste provider so far so needs a bit of coding).
I will post here when done.
Posted: Sat Dec 02, 2017 3:48 pm
by michel30
@Toonz,
The issue what is in google chrome or safari for downloading the page RD4 is for the year 2018 also in internet explorer.
The layout looks complete different:
See:
https://www.rd4info.nl/NSI/Burger/Aspx/ ... &nr=141&t=
<div id="Afvalkalender1_pnlAfvalKalender">
<strong>Januari</strong><table class="plaintextMonth"><tr><td>Dinsdag 2 januari 2018</td><td>Restafval</td></tr><tr><td>Woensdag 3 januari 2018</td><td>
Or I need to wait till january to see if go's okay because when I download it now I see Rd4 Navraagsysteem Inzamelgegevens_htm.htm ( double htm ) the 2017 has only one htm.
Thanks for your great work.
Posted: Tue Dec 05, 2017 10:19 pm
by jeltel
Toonz wrote:Hi all,
I enhanced the app with the waste provider 'dar.nl'.
The calendar.ics file from their website needs to be manually downloaded and copied to: '/root/waste/waste_calendar.ics' .
Shouldn't be too much of an hassle as the file contains all dates for the rest of the year.
Configuration:
You need to edit WastecollectionApp.qml at the top to select one of the six supported waste providers
And edit your zipcode/house nr (not needed for Cure Avalbeheer, Cyclus NV, Dar.nl and Katwijk.nl).
This version is fully compatible with the thermostat_mod V1.2 posted earlier.
Currently supported:
"mijnafvalwijzer.nl"
"deafvalapp.nl"
"cure-afvalbeheer.nl"
"cyclusnv.nl"
"katwijk.nl"
"dar.nl"
Let me know if you want support for additional providers.
Regardsz,
I cannot seem to download an .ics file from afvalkalender anymore. The link you provided:
http://afvalkalender.dar.nl/download_ic ... 41XK&h=401 has been removed or something. How to proceed?
