Toon app: DomoticzBoard
Re: Toon app: DomoticzBoard
Hello, finally the Domoticz works. Evenly both solarsystems (Enphase and Sma) are shown as an sensor, great!
But on the Toon i only see 'switches', even when the Solar Sensors al added to favorites.
Is it posible to sho sensors too?
Okay, i will wait patiently : )
Maybe the same issue...
I have installed an blind switch so i can remotely turn on/off the suncreen.
In the Domoticz GUI i see him, but on the Toon app i only see the 'regular' switches like lights.
Is it possible to make this within the app?
Now i have to use my GUI, and the purpose of the Toon app is to use the switches on the Toon.
Greetz
EDIT:
as an temp solution is just choose for a regular On/Off switxh, now its visible
Greetz
EDIT:
Joskep wrote:….But on the Toon i only see 'switches', even when the Solar Sensors al added to favorites.
Hi Joskep,Joskep wrote:...I have installed an blind switch so i can remotely turn on/off the suncreen.
can you send me the Domoticz json output for those devices in a PM (http://yourdomoticz_ip/json.htm?type=devices&filter=all&used=true&order=Name)?
Probably easy to include these devices in the app but I need to know how they show up in the json output.
Goodmorning,
The solution for the blinds was to make it an ON/OFF switch, so then it appears.
It would be nice to see not only 'switches' but also 'sensors' like SMA / Enphase.
PM is send!
Thanks!
PM is send!
Thanks!
if you set the type of your blinds in Domoticz to 'Blinds percentage' then you can fully control the blinds from Toon. Will that work?Joskep wrote:Goodmorning,
PM is send!
Thanks!
I will look into the sensors as well.
EDIT: the other sensors are not supported yet at all in the Toon app. Need to make a new section for those. No ETA.....
Ok, thanks for looking!
Then i wil take a look if theres an other way to monitor my Domoticz dashboard, its great that it shows everything.
When i choose the 'blinds percentage' its the same result as an regular ON/OFF switch, both are shown.
The only difference is that the 'Blinds Percentage' shows an % statusbar, but this option doesn.t work.
I will keep it as an ON/OFF switch, works okay!
Thanks
Thanks
Another question about this app...
In the Toon you can add an shortcut (switch) as an tile.
There no context given, so you don't know what it does.
Is it possible to choose your own switch as an shortcut?
Already tried to change the DomoticzboardTilescreen but don't know in which line i have to add/change the IDX of that device.
Thanks
Thanks
On the tile you can have two switches. The images on the tile act as an on/off switch (no need to go to the detail screen to operate the switches).
You can select which switch to show on the tile by simply clicking on the switch name in the screen.
That will be the new left switch on the tile. The old left switch is moved to the right.
Okay, i've test is , but its al little bit unclear it works like that. Thanks for your explanation.
I'm wondering if there are more Domoticz - freaks using an Toon als interface, hopefully one day we can see all sensors and switches : - )
Or/and more sensors in one tile at dim state.Joskep wrote:Okay, i've test is , but its al little bit unclear it works like that. Thanks for your explanation.
Count me in as Domoticz freakJoskep wrote:I'm wondering if there are more Domoticz - freaks using an Toon als interface, hopefully one day we can see all sensors and switches : - )
But we do need to discuss some things on how this should be implemented. Like do we split them up in switches/sensors/weather tabs or put them all on one page?
- Benjamin Disraeli -
Count me inPeJeWe wrote:Or/and more sensors in one tile at dim state.Joskep wrote:Okay, i've test is , but its al little bit unclear it works like that. Thanks for your explanation.
So what are we waiting for ?
