Thanks, ASCII file transfer still works like a charm. Busybox 1.27.2, without getty, was introduced in fw 4.9.23. Earlier versions don't have it. You can do without it, just don't install it when updating manually.flamingbob wrote:Old ascii file transfer. That has been ages ago since that was last used! Good find.
Im quite interesed to see if its now removed or its still in there(getty) Still waiting for 4.9.23 on my rooted toon. The backup toon also didnt get it yet so cant check it. Using this way we could even get getty back that is a lot smaller and makes the waiting a bit less. Still strange logic. With local access there is always no way to lock users out.
Rooting Toon (or boxx)
Re: Rooting Toon (or boxx)
So I got some steps futher. I downloaded dropbear from http://files.domoticaforum.eu/index.php?cam=/Toon
I used plink for transferring the base64 file. It belongs to the putty family,
so it can reuse a saved putty connection. My putty connection to Toon is on com10, and called toon. With
plink, sending a file using a saved connection can be done by:
After the ascii show, I checked the md5sum on both systems, they are equal.
md5sum: 0385737390810f2b1bca1b25977821fc dropbear_2015.71-r0_qb2.ipk
I then installed the package, but it gave some errors.
So I reinstalled it verbose:
After rebooting, I was unable to connect to Toon. I performed a full portscan:
The relevant part of the firewall is present:
I now only can browse to port 80 to find some zwave configuration page.
TL;DR Installed dropbear. Cannot SSH to device. Did the installation fail? How does dropbear start automatically?
plink.exe toon < filename
/ # opkg install dropbear_2015.71-r0_qb2.ipk
Collected errors:
* pkg_run_script: package "dropbear" postinst script returned status 255.
* opkg_configure: dropbear.postinst returned 255.
/ # opkg install dropbear_2015.71-r0_qb2.ipk -V2
opkg_conf_parse_file: Loading conf file /etc/opkg/arch.conf.
opkg_conf_parse_file: Supported arch all priority (1)
opkg_conf_parse_file: Supported arch any priority (6)
opkg_conf_parse_file: Supported arch noarch priority (11)
opkg_conf_parse_file: Supported arch arm priority (16)
opkg_conf_parse_file: Supported arch quby2 priority (21)
opkg_conf_parse_file: Supported arch qb2 priority (26)
opkg_conf_parse_file: Loading conf file /etc/opkg/check.conf.
opkg_conf_parse_file: Loading conf file /etc/opkg/opkg.conf.
pkg_hash_load_feeds:
pkg_hash_load_status_files:
pkg_info_preinstall_check: Updating file owner list.
Installing dropbear (2015.71-r0) to root...
pkg_run_script: Running script /tmp/opkg-5DGVYb/dropbear-hRVnfI/preinst.
check_data_file_clashes: Replacing pre-existing file /etc/init.d/dropbear owned by package dropbear
check_data_file_clashes: Replacing pre-existing file /usr/sbin/dropbearkey owned by package dropbear
check_data_file_clashes: Replacing pre-existing file /usr/sbin/dropbearmulti owned by package dropbear
check_data_file_clashes: Replacing pre-existing file /usr/sbin/dropbearconvert owned by package dropbear
check_data_file_clashes: Replacing pre-existing file /usr/sbin/dropbear owned by package dropbear
check_data_file_clashes: Replacing pre-existing file /usr/bin/dbclient owned by package dropbear
opkg_install_pkg: Installing maintainer scripts.
opkg_install_pkg: Installing data files for dropbear.
install_data_files: Extracting data files to /.
pkg_write_filelist: Creating //usr/lib/opkg/info/dropbear.list file for pkg dropbear.
opkg_install_pkg: Resolving conf files for dropbear
opkg_configure_packages: Configuring unpacked packages.
opkg_configure_packages: Reordering packages before configuring them...
Configuring dropbear.
pkg_run_script: Running script //usr/lib/opkg/info/dropbear.postinst.
write_status_files_if_changed: Writing status file.
pkg_write_changed_filelists: Saving changed filelists.
Collected errors:
Host is up, received syn-ack (0.0025s latency).
Scanned at 2017-11-14 22:31:40 CET for 119s
Not shown: 65531 filtered ports
Reason: 65531 no-responses
PORT STATE SERVICE REASON
22/tcp closed ssh conn-refused
80/tcp open http syn-ack
7080/tcp closed empowerid conn-refused
10080/tcp open amanda syn-ack
-A HCB-INPUT -p tcp -m tcp --dport 22 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
i have exact same question.glsf91 wrote:Is there somewhere an instruction how to carry out a manual update?marcelr wrote: If you have a cron daemon running, then yes. I would try and test for that first. Another option is to edit the base-qb2-ene package. That's the route I tend to take.
Oh crap, Somone in my home started the update of Toon. Now I have to open him up again and start all over. Hopefully the new tut will work for me.
Updating with the cron daemon running works perfectly. I have succesfully updated to 4.8.25 now. Seems that is the latest version Eneco is enrolling nowmarcelr wrote:That's correct.lxz wrote:Thanks for the quick (and creative) getty workaround. Am I correct if I say this is only necessary when initially rooting Toon?If you have a cron daemon running, then yes. I would try and test for that first. Another option is to edit the base-qb2-ene package. That's the route I tend to take.lxz wrote: I have a rooted R10 Toon with SSH access already. Which steps do I have to take to update from 3.6.xx to to 4.9.23?
Can I use this method to update and gain access again after updating?
4.9.23 will be available soon on your Toon but you can also wait for 4.10.x. 4.9 is not worth the trouble.
I did my update before with edit this file base-qb2-ene package and that works.
The cronjob I never try, I also read somewhere on this forum that somebody creates an upgrade script but it has never post it here.
Can you explain a little bit more what you did?michel30 wrote:Hello,
I will write a short manual for that, this weekend.
Don't know about the upgrade script. Upgrading while retaining ssh access involves quite a few steps, not sure if that's easily automated.
Was dropbear installed already on this system? Could be that the installer does not like to overwrite previously installed files, from the same version. Normally dropbear installs, and is active immediately afterwards. Startup at boot is set by the installer.rubyan wrote: After rebooting, I was unable to connect to Toon. I performed a full portscan:
The relevant part of the firewall is present:Code: Select all
Host is up, received syn-ack (0.0025s latency). Scanned at 2017-11-14 22:31:40 CET for 119s Not shown: 65531 filtered ports Reason: 65531 no-responses PORT STATE SERVICE REASON 22/tcp closed ssh conn-refused 80/tcp open http syn-ack 7080/tcp closed empowerid conn-refused 10080/tcp open amanda syn-ack
I now only can browse to port 80 to find some zwave configuration page.Code: Select all
Ok after some trial and error i find out what i had to do. I updated my rooted Toon from 4.8 to 4.9 and i could figure out what steps i had to take. I tried a lot without any luck. Bet then i had a bright moment (after some beers) and i only changed the ip table part, witch was disabled after the update, and voila i had access to my Toon again.
So if you have rooted your Toon before just change the ip table part and your back in business.
Thanks Marcelr for making this possible.
A short manual for upgrading while keeping ssh access is now available in the manuals/tutorials thread:
viewtopic.php?f=87&t=11235#p84033
Thanks for your work!marcelr wrote:A short manual for upgrading while keeping ssh access is now available in the manuals/tutorials thread:
De nada
HI all,
I have the same error as @rybyan when i try to install Dropbear with firmware 4.9.23.
Collected errors:
this is what i have done before (manual Marcelr):
1) connect my serial interface to toon ->Works
2) enter the password for U-Boot 2010.09-R8 ->Works
3) command "printenv" -> Works
4) command "setenv addmisc setenv bootargs \$\{bootargs\} mem=\$\{mem\} lpj=999424 init=/bin/sh" -> Works
5) command "run boot_nand" ->Works
6) not edit "/etc/inittab", because getty not works with firmware 4.9.23. (manual marcelr)
7) edit "/etc/passwd" remove disabled to line "root::0:0:root:/root:/bin/sh" ->Works
no reboot toon/go to Dropbear installation with firmware 4.9.23
9) download package dropbear_2015.71-r0_qb2.ipk ->Done
10) package to ASCII with command "base64 dropbear_2015.71-r0_qb2.ipk > dropbear_2015.71-r0_qb2.ipk.b64" ->Done
11) then command "cat > dropbear_2015.71-r0_qb2.ipk.b64". After 15 minutes to wait no response from MInicom, but i can select <Ctrl+A> S en transfer the file to Toon.
When i connect with MInicom back to Toon <Ctrl+D> , i see the transfer file "dropbear_2015.71-r0_qb2.ipk.b64 " in the directory of Toon.
12) after command "base64 -d dropbear_2015.71-r0_qb2.ipk.b64 > dropbear_2015.71-r0_qb2.ipk", i see the file "dropbear_2015.71-r0_qb2.ipk"in the directory of Toon.
13) Now i try install the file with "opkg install dropbear_2015.71-r0_qb2.ipk" ,but now i see the error :
Collected errors:
What i did wrong?
Collected errors:
Collected errors:
What i did wrong?
