Toon firmware - update script
qwerk
Post by qwerk »
TheHogNL wrote:They changed their update script again. I just checked it for any problems regarding upgrading on a rooted toon but it is still ok.
I just updated the rooting update script with the new md5sum so when you use the new script (2.86) from the github it will not complain anymore.
just wanted to try this update.
Downloaded the newest script 3.32
no parameters given.
I choose to update to 4.10.6
Then I got: Warning: upgrade script from source server is changed. Do you want to continue downloading the files (if not sure, type no and report in the forums)?
So I typed no, and here is my report.
please advice
Post by TheHogNL »
They indeed changed the Eneco side of the update script. I checked it and the change is ok, nothing to worry about.
I already updated the update-script.sh to allow this.
qwerk
Post by qwerk »
TheHogNL wrote:They indeed changed the Eneco side of the update script. I checked it and the change is ok, nothing to worry about.
that worked.
thanks. FYI I did loose all my tiles. I readded them manually.
I updated via 4.10.6 to version 4.19.10
this one does not have a globals.qml anymore.
How can I prevent some modules from starting?
Before I disabled internetSettings and eMeterSettings. that prevented the Internet and emeter errors on the mean screen.
I would like to do that again.
and also I now have something about monitoring my geiser... how to disable that ?
Post by TheHogNL »
Look in the TSC menu which allows you to disable some native Toon features.
Disabling internet settings isn't necessary. Any 'service center' errors are automatically deleted. Emeter messages are not removed yet. Why would you want that?
qwerk
Post by qwerk »
TheHogNL wrote:Look in the TSC menu which allows you to disable some native Toon features.
the mean reason is to loose the error-triangle
Post by TheHogNL »
qwerk wrote: the mean reason is to loose the error-triangle
You use the Toon without meteradapter then? I could add an option to the TSC menu to disable the emeter app
qwerk
Post by qwerk »
please do. I do not use the meteradapter. No smart meter, and extra measure aids were not included, in my second hand toon
Cctl01
Post by Cctl01 »
+1 for removal of the emeter app. (and therefore triangle)
Post by TheHogNL »
Will look at this in a few days
Post by TheHogNL »
Removing the emeterssettingsapp is not that trivial.
Removing it from globals.qml is possible ofcourse but that means I need to publish two versions of resource files (one with and one without the app).
What would be possible is just to never show the systray triangle, configurable via a setting in the TSC menu. I'm now working on this.
Post by TheHogNL »
Just released TSC version 1.3.2 which allows you to disable the error systray icon
WickedMaster
Post by WickedMaster »
I am trying to use the update script (forced), but it keeps giving me errors (some files cannot be found).
Only fixing files.
creating backup of hosts...
cp: can't stat '/HCBv2/etc/qmf_tenant.xml': No such file or directory
sh: errors:: unknown operand
FIXING: Trying to fix Global.qml now to add all the Toonstore installed apps again.
find: /HCBv2/qml/apps/: No such file or directory
FIXING: Now fixing internet settings app to fake ST_TUNNEL mode.
grep: /HCBv2/qml/apps/internetSettings/InternetSettingsApp.qml: No such file or directory
Modification in InternetSettingsApp.qml is missing. Fixing it now.
sed: /HCBv2/qml/apps/internetSettings/InternetSettingsApp.qml: No such file or directory
FIXING: Now modifying notifications bar to not show any network errors
grep: /qmf/qml/qb/notifications/NotificationBar.qml: No such file or directory
Modification in NotificationBar.qml is missing. Fixing it now.
sed: /qmf/qml/qb/notifications/NotificationBar.qml: No such file or directory
FIXING: Now installing latest toonstore app. This fixes some files also.
Collected errors:
* opkg_conf_load: Could not lock /usr/lib/opkg/lock: Resource temporarily unavailable.
FIXING: Now installing latest busybox mod. This is necessary to enable console output again which is disabled in 4.10 by Eneco.
Custom busybox install not necessary for this firmware.
FIXING: Installing Dropbear for ssh access
Collected errors:
EDITING: Adding serial connection
sed: /HCBv2/etc/qmf_tenant.xml: No such file or directory
sed: /HCBv2/etc/qmf_release.xml: No such file or directory
Collected errors:
Collected errors:
I also tried to remove the locked file and try again, but then it gives me the following error:
Only fixing files.
FIXING: Downloading resources.rcc TSC mod for this version 4.19.10.
mv: can't rename '/qmf/qml/resources-static-base.rcc': No such file or directory
mv: can't rename '/qmf/qml/resources-static-ebl.rcc': No such file or directory
unzip: can't change directory to '/qmf/qml': No such file or directory
Downloading http://files.domoticaforum.eu/uploads/T ... r0_qb2.ipk.
Installing toonstore (2.0.2-r0) to root...
Executing pre-install script for toonstore-2.0.2
Hmmm ... no project file found. Shouldn't happen.
Post by TheHogNL »
As stated here: viewtopic.php?f=104&t=11779&p=88048#p88048
I already helped you recovering your missing directory
mAiden
Post by mAiden »
Eneco is started with update Toon with firmware 4.22.7.. Dont update to this one without the resource file of TheHogNL for this version, if you like the custom apps! ;)
Post by TheHogNL »
And it is ready. Go on and also try the new firmware update feature from the TSC check update menu item :)
Return to “Toon Firmware”
