Page 19 of 44
Posted: Thu Nov 15, 2018 5:58 pm
by Toonz
Great response time TheHogNL :D
I just succesfully upgraded a Toon 1 and a Toon 2 via the TSC menu to version 4.22.7. Great job.
I just noticed I needed to disable unused standard features again via the TSC menu after upgrading the firmware
by mAiden
TheHogNL wrote:And it is ready. Go on and also try the new firmware update feature from the TSC check update menu item :)
Nice one. Will try the TSC update check :-)
Posted: Thu Nov 15, 2018 6:28 pm
by hdok
I might have missed something but I just installed the resource file for my version (4.18.8). Did I understand correctly that TCS check update should make it possible to update the toon to a higher version too?
I am so glad I rooted my toon and it is amazing to see the great things that people are doing. Thank you all
EDIT 18:20: I needed to disable the firewall first, after that I did new check and I updated my toon to the latest version automatically, awesome!
Posted: Thu Nov 15, 2018 6:39 pm
by TheHogNL
Toonz wrote: I just noticed I needed to disable unused standard features again via the TSC menu after upgrading the firmware
Correct. These features are disabled using the TenantSettings.json file (a native file on the toon) which got updated in 4.22.7 so all native features got enabled again.
Posted: Thu Nov 15, 2018 11:36 pm
by madpatrick
Ipdate to 4.22.7 went smootly.
Thanks !!
Posted: Fri Nov 16, 2018 12:50 pm
by lievenco
Is it possible to update my Boxx (Toon) with software version 1.0.9.
I tried the update script but, I ran in to some errors...
Posted: Fri Nov 16, 2018 8:33 pm
by mogwai
Tried to update via the new TSC update option but failed. Apparently something changed on the eneco update script...
Unattended selected version 4.22.7
Alright, I will try to upgrade to 4.22.7
Tunnel is alive and configured.
Warning: upgrade script from source server is changed. Do you want to continue downloading the files (if not sure, type no and report in the forums)?
Posted: Fri Nov 16, 2018 9:14 pm
by TheHogNL
Thanks. Eneco changed their upgrade script again. Just checked and nothing wrong with it. I updated the update-rooted.sh script to allow this now.
Posted: Fri Nov 16, 2018 9:52 pm
by Rudolf
Just ran the script from the shell to update from 4.19.10 to 4.20.7 (I'm not ready for the latest greatest...)
It finished without errors, and asks me to check the contents of /etc/password, but I'm unsure if its contents are OK.
root:x:0:0:root:/root:/bin/sh
It does still accept my current password, and I have pubkey-authentication configured.
iptables.conf looks good to, as far as I can tell.
It would be nice if the script (or this topic) had clear instructions on what to check for.
And/or how to fix things I they appear broken.
(by running 'passwd' for example?)
Edit: Everyting is fine!
Posted: Fri Nov 16, 2018 9:53 pm
by mogwai
TheHogNL wrote:Thanks. Eneco changed their upgrade script again. Just checked and nothing wrong with it. I updated the update-rooted.sh script to allow this now.
Thanks. Problem solved, update via TSC succesfull :)
Posted: Fri Nov 16, 2018 11:55 pm
by TheHogNL
Rudolf wrote:Just ran the script from the shell to update from 4.19.10 to 4.20.7 (I'm not ready for the latest greatest...)
Please remind that 4.20.7 is never official launched by Eneco. Only some fieldtester had this firmware. Better go for 4.22.7
On a Toon2 you should check /etc/shadow. But I guess that message from the script is now a bit on the safe side. The GUI update which is now available runs the script in (-u) unattended mode which runs fine. I have already seen it working on a couple of toon1 and toon2's. So maybe I need to tweak down the level of warnings in the script.
Posted: Sat Nov 17, 2018 11:25 am
by yjb
Updated my toon2 to 4.22.7 without any issues as well.
I also noticed the message about /etyc/passwd which should have been shadow. Might be an idea to update the message depending on the platform we're running on.
Also, maybe it's easier when the script just grep's the root line out of passwd/shadow and/or compare it with the previous version.
Also, if you are really concerned about the root password it might be an idea to enable an ssh key based login from a trusted host; in the unlikely event that your password gets changed, the certificate will be, hopefully, still in place,
Posted: Sat Nov 17, 2018 3:48 pm
by TheHogNL
yjb wrote:Updated my toon2 to 4.22.7 without any issues as well.
To me all those extra warnings can be removed. I just put them in in the first version to make sure to check this but it is really not necessary. The new TSC menu has a recover password button also anyways.
Posted: Sat Nov 17, 2018 4:53 pm
by michel30
Thanks again for the nice update script.
I just update my toon 1 to software version 4.22.7 with the TSC update script all okay now problem at all.
I have only one small question I also searching in this forum but could not find it.
In the passed, one year ago I added the new energie price in Globals.qml /qmf/qml/qb/base/Globals.qml but now I see only Globals.qml.back properly I did that before I edit that file.
Now my question where can I enter the new price for next year? So Toon will show this?
Posted: Sat Nov 17, 2018 6:38 pm
by Rudolf
Thanks; just upgraded to 4.22.7 using the TSC Menu in the GUI. It's too easy. :D
One minor thing: After a reboot it shows a notificatin saying there's a firmware update available; when I click on it, it takes me to the 'Meetmodules' screen.
(The Meteradapter is not yet operational, it has been paired, but the sensors are still connected to another adapter from Toon1)
The same happens when I click the 'Download new firmware' button in the notification bar. :o
