still theb same errors as before and
node-red gives: Node-Red has not been built
Nefit easy support?
Moderator: RDNZL
Re: Nefit easy support?
Did you install node red again?
sudo npm install -g --unsafe-perm
this is the result:
root@raspberrypi:~# sudo npm install -g --unsafe-perm
npm ERR! addLocal Could not install /root
npm ERR! Linux 4.1.7+
npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "-g" "--unsafe-perm"
npm ERR! node v5.3.0
npm ERR! npm v3.3.12
npm ERR! code EISDIR
npm ERR! errno -21
npm ERR! syscall read
npm ERR! eisdir EISDIR: illegal operation on a directory, read
npm ERR! eisdir This is most likely not a problem with npm itself
npm ERR! eisdir and is related to npm not being able to find a package.json in
npm ERR! eisdir a package you are trying to install.
npm ERR! Please include the following file with any support request:
npm ERR! /root/npm-debug.log
root@raspberrypi:~#
npm ERR! errno -21
root@raspberrypi:~#
It seems to be an npm permission issue. See docs.npmjs.com/getting-started/fixing-n ... ermissions
The problem is still not solved.
The script option is the only way to get it going i think
Perhaps the problem is my raspbery.
Thanks for the support you gave me.
Regards
Edwin
Regards
Edwin
