Page 3 of 4
Gas monitoring Bwired
Posted: Mon Mar 23, 2009 11:26 pm
Looks very cool [8D];
Much better then how i once had to do this, back in the DOS days:
Posted: Tue Mar 24, 2009 2:50 pm
by blackbird
I see domotica via telnet/ssh ;)
Posted: Tue Mar 24, 2009 10:16 pm
by Hetwieg
Ik dacht net aan het zelfde :)
Ik zelf ben momenteel bezig met een Rabbit core om alle ruimtes in huis te meten qua temp. (Ook via telnet)
Waarom zelf het wiel nog een keer uitvinden.
Posted: Wed Mar 25, 2009 8:29 am
by fringui
English please... ;)
Posted: Wed Mar 25, 2009 7:49 pm
by Hetwieg
Sorry
I thought the same thing :)
I work at the moment with a Rabbit core to temp all rooms in the house with a one wire bus.
Posted: Mon Oct 19, 2009 7:56 pm
by erisan500
i build this too to measure my gas consumption, though i have a problem.
When the meter is moving very slowly, the sensor seems to react also on the digits (or the change in black/white).
Any idea how i can solve that?
Greetings,
Eric
Posted: Mon Oct 19, 2009 11:07 pm
Try to set the sensor a bit further from the digits, did you also use the potential trimmer (potmeter) to adjust?
Posted: Tue Oct 20, 2009 11:40 am
by erisan500
I tried increasing the distance between sensor and digits, to no avail. Also the potmeter is adjusted.
Looking at the CNY70 datasheet/application note, the optimal current for the transmitter is between 20-40 mA, though with the 2 resistors of 560 ohm (1120 ohm as they are in series), we only get 4 mA. I think replacing the 2 resistors with one of 180 ohm would help a bit, don't you think?
Greetings,
Eric
Posted: Tue Oct 20, 2009 11:43 am
by ddgiel
Hi Eric
For measure gas and water consumption, i am using an induction sensor (SICK MM08-60APS-ZTK) instead of an optical monitor. The sensor is placed a 1/1000 digit.
Gas
Water
For Belgium gas/water meters it works perfectly.
Posted: Tue Oct 20, 2009 1:04 pm
by abl
Do these induction sensors work with Homeseer? And if so, how?
Posted: Tue Oct 20, 2009 2:13 pm
by erisan500
ddgiel,
got any price indication and/or addresses where they can be bought? (i'm located between Sint-Niklaas and Mechelen)
This sensor just provides a NO contact?
To what are they connected to at your place?
Greetings,
Eric
Posted: Tue Oct 20, 2009 4:08 pm
by Jeroen Bartels
@DDGiel, I have a gas meter that has no mirror to measure gas. Does this induction meter work on any gas meter or does it have to have some kind of magnet/mirror? (I don't know if mine has a magnet but I will try tonight....
Jeroen.
by the way: I have the same watermeter and there is a magnet inside that gives a pulse every 0,5 liter. You can insert a probe (Reed relais) when you remove the small plastic cap 3 cm to the right of your induction meter.
Posted: Tue Oct 20, 2009 4:52 pm
You Can try and experiment a bit, this schematic should work perfectly, is being used by a lot of Domoticans.
Posted: Tue Oct 20, 2009 9:41 pm
by erisan500
I have it working guys.
1st, I removed one of the 560 ohm resistors, and increased the distance between the sensor and the gasmeter.
2nd, the fake pulses turned out to be noise on the powerline.
Need to find a way to solve that damn noise. Would a UPS help ?
Thanks for the suggestions though.
Greetings,
Eric
Posted: Tue Oct 20, 2009 11:08 pm
Yeah!!
I don't know the exact word for it but did you try a "coil" on the powerline just in front of the sensor print.
