Page 3 of 24
Re: Toon firmware: issues (and solutions)
Posted: Tue Mar 28, 2017 2:49 pm
by QuasaR
I don't know if klaphekje has been able to downgrade but I can supply the packages from any released version you need.
(Currently backed up : 3.2.18, 3.0.29, 3.3.0, 3.6.3, 3.7.7).
Posted: Tue Mar 28, 2017 7:30 pm
by marcelr
Do you know if is it possible to disable processes like hue, smartplug, weather etc to free up resources? or does that crash the system?
Yes, you may want to edit
/HCBv2/qml/qb/base/Globals.qml for that. This qml code loads all apps, including some that you apparently don't want. You can just disable that in that file.
It shouldn't crash the system, since these apps aren't loaded in standalone mode either. And that mode just works.
and as a last resort, is it possible to roll back the update?
Yes, the packages updated in 3.7.9 are in the table below (AFAIK, and never mind the layout, emacs is a pain when it comes to tabs. But that's the way it is). Note that not all packages are updated every update. So, you may need packages from several earlier releases to roll back the last update.
Oh, and the base package overwrites the iptables.conf. It's easily patched (5 minutes of work). Just unpack the .ipk. It's a tar.gz archive, then unpack data.tar.gz, edit /etc/iptables.conf (or wherever it resides) according to the rooting manual, and repack in reverse order. Make sure to keep the package names the same. Only then install base.<whatever> and your toon remains open.
Install date Package Version
3.7.9:
base-qb2-ene 3.7.9-1067-0
ca-certificates 20160104-r0_all
firmware-ba 1.43
firmware-ma 1.94
happ-kpi 1.318-master
happ-pwrusage 1.561-ene-master
happ-scsync 1.213-ene-master
happ-smartplug 1.153-master
happ-thermstat 1.1117-ene-master
happ-weather 1.115-master
hcb-bxtproxy 1.133-master
hcb-config 1.283-master
hcb-netcon 1.288-master
hcb-rrd 2.140-master
hdrv-p1 1.609-ene-master
hdrv-zwave 1.905-master
libhcb-base 1.244-master
libhcb-boxtalk 1.108-master
libhcb-com 1.109-TN-master
libhcb-drv 1.304-master
libhcb-xml 1.95-master
qt-gui 1.6755-ene-release-ene-3.7
x11vnc 0.9.13-r2
3.6.3:
base-qb2-ene 3.6.3-1022-0
happ-eventmgr 1.164-master
happ-kpi 1.295-master
happ-pwrusage 1.553-ene-master
happ-scsync 1.196-ene-master
happ-smartplug 1.146-master
happ-thermstat 1.852-ene-master
happ-usermsg 1.48-master
happ-weather 1.111-master
hcb-bxtproxy 1.107-master
hcb-comm 1.165-TN-master
hcb-config 1.264-master
hcb-log 1.65-master
hcb-rrd 2.138-master
hcb-upnp 1.87-master
hcb-watchdog 1.44-master
hdrv-hue 1.86-master
hdrv-zwave 1.850-master
libhcb-base 1.232-master
libhcb-boxtalk 1.107-master
libhcb-com 1.108-TN-master
libhcb-drv 1.295-master
libhcb-xml 1.93-master
libuuid 2.18-r36.0
qt-gui 1.6144-ene-develop
3.5.4:
base-qb2-ene 3.5.4-1005-0
glibc-patch-dns 2.10.1-r37.2
happ-pwrusage 1.469-ene-master
happ-scsync 1.185-ene-master
happ-thermstat 1.816-ene-master
happ-weather 1.106
hcb-config 1.259-master
hdrv-p1 1.479-master
qt-gui 1.5958-ene-release-3.5
3.4.4:
base-qb2-ene 3.4.4-990-0
firmware-ba 1.40
happ-eventmgr 1.161-master
happ-kpi 1.276-master
happ-pwrusage 1.460-ene-master
happ-scsync 1.163-ene-master
happ-smartplug 1.118
happ-thermstat 1.784-ene-master
hdrv-zwave 1.767-3-4-qubino-smart-meter
kernel 2.6.36-R10-h25
kernel-image 2.6.36-R10-h25
kernel-module-fat 2.6.36-R10-h25
kernel-module-msdos 2.6.36-R10-h25
kernel-module-rt5370sta 2.6.36-R10-h25
kernel-module-rt5370sta-cfg 2.6.36-R10-h25
kernel-module-rtl8191su 2.6.36-R10-h25
kernel-module-vfat 2.6.36-R10-h25
kernel-module-zwave300 2.6.36-R10-h25
qt-gui 1.5738-release-3.4-ene
3.3.8:
base-qb2-ene 3.3.8-981-0
firmware-ma 1.88
flash-gui 1.651-ene-qeio
happ-kpi 1.261-master
happ-scsync 1.150-ene-fix-AET-1312-send-message-to-gui-on-new-ma-firmware-available
happ-smartplug 1.114
happ-thermstat 1.744-ene-master
happ-usermsg 1.44
hcb-bxtproxy 1.96-master
hcb-config 1.240-master
hdrv-p1 1.452-master
hdrv-zwave 1.636-master
qt-gui 1.5498-develop-ene
3.2.18:
1458995634 kernel-image 2.6.36-R10-h23
1456853211 dropbear 2015.71-r0
1456593605 kernel-module-zwave300 2.6.36-R10-h23
1456593584 kernel-module-vfat 2.6.36-R10-h23
1456593560 kernel-module-rtl8191su 2.6.36-R10-h23
1456593532 kernel-module-rt5370sta 2.6.36-R10-h23
1456593506 kernel-module-rt5370sta-cfg 2.6.36-R10-h23
1456593467 kernel-module-pl2303 2.6.36-R10-h23
1456593450 kernel-module-msdos 2.6.36-R10-h23
1456593434 kernel-module-ftdi-sio 2.6.36-R10-h23
1456593419 kernel-module-fat 2.6.36-R10-h23
1456593387 kernel 2.6.36-R10-h23
1456591493 qt-gui 1.5077-release-3.2.9-with-dateselectorcomponent-hotfix
1456591029 openvpn 2.3.6-r2.1
1456590928 base-qb2-ene 3.2.18-962-0
3.1.x:
1450714980 happ-smartplug 1.105
1450714975 hdrv-zwave 1.598-master
1450714741 happ-kpi 1.146-master
3.0.29:
1450216896 hcb-watchdog 1.4
1450216894 hcb-config 1.218
1450216889 lighttpd-mod-hcb-web 1.4.33-26
1450216885 happ-scsync 1.112
1450216883 happ-thermstat 1.618-master
1450216875 hdrv-hue 1.62-eneDevices
1450216873 hdrv-p1 1.393
1450216855 happ-weather 1.96
1450216853 lighttpd 1.4.33-17
1450216850 libpcre 7.6-r8
1450216845 happ-usermsg 1.36
1450216840 qt-libs 5.3.1-06-setpos
1450216405 happ-eventmgr 1.14
1450216389 hcb-bxtproxy 1.85-master
1450216383 firmware-ma 1.74
1450216346 libhcb-xml 1.83
1450216345 hcb-comm 1.160-TN
1450216342 hcb-rrd 2.125
1450216340 flash-gui 1.648-ene-qeio
1450216330 libhcb-drv 1.272
1450216326 flash-qwidget-diy 1.161-qeio
1450216310 boot-logos 1.64-ene
1450216305 happ-pwrusage 1.431
1450216299 hcb-netcon 1.246
2.9.x
1429820837 firmware-zwave-ctrlr 1.8-4.55-NrNfNm-noeep
1418163197 jansson 1.3-r1.0
1418163194 hcb-upnp 1.73
1418163158 libhcb-base 1.171
1411237415 tzdata-americas 2011b-r8.0
1406916468 libhcb-boxtalk 1.85
1400823958 hcb-log 1.52
1383330079 flash-lite-adobe 4.0.3-55-fb0
1372181861 wpa-supplicant-passphrase 2.0-r3
1372181859 firmware-ba 1.35
1372181811 initscripts 1.2-r6-runlvls
1372181807 chrony 1.27-r1
1372181804 wpa-supplicant-cli 2.0-r3
1372181638 wpa-supplicant 2.0-r3
first release:
1346244072 gnupg 1.4.10-r3
1346244072 gpgv 1.4.10-r3
1346244072 libbz2 1.0.6-r0
1346244072 libopkg 0.1.8??r7-gcv
1346244072 opkg 0.1.8??r7-gcv
1346244072 opkg-collateral 1.0-r3
1346244072 readline 5.2-r8
1346244071 glibc-binary-localedata-en-us 2.10.1-r37.1
1346244071 glibc-binary-localedata-fr-fr 2.10.1-r37.1
1346244071 glibc-localedata-i18n 2.10.1-r37.1
1346244071 glibc-localedata-iso14651-t1 2.10.1-r37.1
1346244071 glibc-localedata-iso14651-t1-common 2.10.1-r37.1
1346244071 glibc-localedata-translit-circle 2.10.1-r37.1
1346244071 glibc-localedata-translit-cjk-compat 2.10.1-r37.1
1346244071 glibc-localedata-translit-compat 2.10.1-r37.1
1346244071 glibc-localedata-translit-font 2.10.1-r37.1
1346244071 glibc-localedata-translit-fraction 2.10.1-r37.1
1346244071 glibc-localedata-translit-narrow 2.10.1-r37.1
1346244071 glibc-localedata-translit-neutral 2.10.1-r37.1
1346244071 glibc-localedata-translit-small 2.10.1-r37.1
1346244071 glibc-localedata-translit-wide 2.10.1-r37.1
1346244071 gpgme 1.1.4-r5
1346244071 locale-base-en-us 2.10.1-r37.1
1346244071 locale-base-fr-fr 2.10.1-r37.1
1346244071 makedevs 1.0.0-r10
1346244071 pth 2.0.2-r2
1346244071 samba-nmbd 3.0.20-r8
1346244071 sysvinit 2.86-r63
1346244071 sysvinit-inittab 2.86-r63
1346244071 sysvinit-pidof 2.86-r63
1346244071 sysvinit-utils 2.86-r63
1346244070 glibc-binary-localedata-de-de 2.10.1-r37.1
1346244070 glibc-binary-localedata-en-gb 2.10.1-r37.1
1346244070 glibc-binary-localedata-es-es 2.10.1-r37.1
1346244070 glibc-binary-localedata-it-it 2.10.1-r37.1
1346244070 libnl2 1:2.0-r2
1346244070 locale-base-en-gb 2.10.1-r37.1
1346244070 locale-base-es-es 2.10.1-r37.1
1346244070 locale-base-it-it 2.10.1-r37.1
1346244070 wireless-tools 29-r5
1346244069 glibc-binary-localedata-nl-nl 2.10.1-r37.1
1346244069 locale-base-de-de 2.10.1-r37.1
1346244069 locale-base-nl-nl 2.10.1-r37.1
1346244069 www-jquery-ui 1.8.21-16
1346244069 www-resources 1.16
1346244068 libhcb-com 1.91-TN
1346244063 curl 7.21.2-r5.0
1346244063 directfb 1.2.8-r1.0
1346244063 glibc-gconv 2.10.1-r37.1
1346244063 glibc-gconv-iso8859-1 2.10.1-r37.1
1346244063 gnutls 2.10.4-r11.0
1346244063 iptables 1.4.9.1-r7.1
1346244063 libcurl 7.21.2-r5.0
1346244063 libgcrypt 1.4.1-r0
1346244063 libgpg-error 1.4-r7.1
1346244063 pointercal 0.0-r22
1346244063 tslib-calibrate 1.0-r28.7hae
1346244063 tzdata-europe 2011b-r8.0
1346244062 freetype 2.4.3-r1
1346244062 joe 3.1-r3
1346244062 jpeg 8b-r1
1346244062 less 436-r1
1346244062 libnetfilter-conntrack 0.0.101-r0
1346244062 libnfnetlink 1.0.0-r0.0
1346244062 libpng12 1.2.44-r3.0
1346244062 libstdc++ 4.5-r33.1???
1346244062 libsysfs 2.1.0-r3
1346244062 ncurses 5.7???r16
1346244062 ncurses-libncurses 5.7???r16
1346244062 ncurses-libtinfo 5.7???r16
1346244062 ncurses-terminfo 5.7???r16
1346244062 ncurses-terminfo-base 5.7???r16
1346244062 tslib 1.0-r28.7hae
1346244062 tslib-conf 1.0-r28.7hae
1346244062 wget 1.12-r8.2
1346244060 i2c-tools 3.0.3-r0
1346244060 module-init-tools 3.12-r6
1346244060 module-init-tools-depmod 3.12-r6
1346244060 modutils-initscripts 1.0-r3
1346244060 mtd-utils 1.4.1-r0
1346244060 netbase 4.21-r50
1346244060 openssl 0.9.8m-r14.1
1346244060 update-modules 1.0-r10
1346244059 base-files 3.0.14-r100
1346244059 base-passwd 3.5.20-r1
1346244059 busybox 1.18.3-r42.1
1346244059 busybox-mountall 1.18.3-r42.1
1346244059 busybox-syslog 1.18.3-r42.1
1346244059 glibc 2.10.1-r37.1
1346244059 libcrypto 0.9.8m-r14.1
1346244059 libgcc 4.5-r33.1???
1346244059 libssl 0.9.8m-r14.1
1346244059 lzo2 2.03-r0
1346244059 openssl-conf 0.9.8m-r14.1
1346244059 zlib 1.2.3-r7.0
1346244058 update-rc.d 0.7-r2
Posted: Fri Mar 31, 2017 11:21 pm
by klaphekje
QuasaR wrote:I don't know if klaphekje has been able to downgrade but I can supply the packages from any released version you need.
I tried and bricked my Toon... It does not boot anymore. i'll try to fix that somewhere this week.
Posted: Sun Apr 02, 2017 12:01 pm
by Toonz
Is there a changelog of some sorts for the new FW version? In other words, worth the trouble of upgrading?
Posted: Sun Apr 02, 2017 9:40 pm
by marcelr
Toonz wrote:Is there a changelog of some sorts for the new FW version? In other words, worth the trouble of upgrading?
AFAIK: no, the only publicly available information is given at Eneco's toon forum.
klaphekje wrote:I tried and bricked my Toon... It does not boot anymore. i'll try to fix that somewhere this week.
Strange, this risk should only exist if you replace the bootloader and/or the kernel. The bootloader is unreachable for the installer, FW 3.7.9 had no kernel upgrade, so I assume that you didn't try to install an older one? Anyway, if you need any help, just yell.
Posted: Sat Apr 08, 2017 6:23 pm
by klaphekje
It seems you are right again. The Toon was not bricked at all. The screen just did'nt lit up anymore and the iptables config was reverted to default. So i had a black screen and no SSH access anymore.
The serial console however still worked. OPKG had a lot of errors regarding dependencies. I tried to fix that be hand but without succes.
At this point it boots halfway and then it "hangs". I can start qt manually (/usr/bin/startqt) but then it won't remember any settings, so i start with an empty screen after each reboot.
I can't find a usefull log so i have no idea where to start. So... any ideas?
Posted: Sat Apr 08, 2017 8:52 pm
by marcelr
klaphekje wrote:I can't find a usefull logs so i have no idea where to start. So... any ideas?
All software for toon is started in /etc/inittab.
In a rooted toon, this file looks like this (hasn't changed essentially, since its introduction back in the first linux distro, until systemd came along):
# /etc/inittab: init(8) configuration.
# $Id: inittab,v 1.91 2002/01/25 13:35:21 miquels Exp $
# The default runlevel.
# Boot-time system configuration/initialization script.
# This is run first except when booting in emergency (-b) mode.
si::sysinit:/etc/init.d/rcS
# What to do in single-user mode.
# /etc/init.d executes the S and K scripts upon change
# of runlevel.
# Runlevel 0 is halt.
# Runlevel 1 is single-user.
# Runlevels 2-5 are multi-user.
# Runlevel 6 is reboot.
l0:0:wait:/etc/init.d/rc 0
l1:1:wait:/etc/init.d/rc 1
l2:2:wait:/etc/init.d/rc 2
l3:3:wait:/etc/init.d/rc 3
l4:4:wait:/etc/init.d/rc 4
l5:5:wait:/etc/init.d/rc 5
l6:6:wait:/etc/init.d/rc 6
# Normally not reached, but fallthrough in case of emergency.
z6:6:respawn:/sbin/sulogin
# HCBv2 static stuff
# Commented-out VPN access for the service center. Uncomment if you want
# to use it. See /etc/openvpn/README for further instructions.
#ovpn:235:respawn:/usr/sbin/openvpn --config /etc/openvpn/vpn.conf --verb 0 >/dev/null 2>&1
qtqt:245:respawn:/usr/bin/startqt >/dev/null 2>&1
# added tty for direct serial access
gett:235:respawn:/sbin/getty -L 115200 ttymxc0 vt102
# WARNING: auto-managed by '/etc/init.d/HCBv2 inittabwrap' with '/HCBv2/etc/start.d/*'
# lines containing 'inittabwrap' will be removed automagically.
netc:235:respawn:/etc/init.d/HCBv2 inittabwrap hcb_netcon
comm:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_comm
even:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_eventmgr
kpik:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_kpi
pwru:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_pwrusage
scsy:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_scsync
smar:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_smartplug
ther:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_thermstat
user:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_usermsg
weat:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_weather
bxtp:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_bxtproxy
conf:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_config
logl:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_log
rrdr:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_rrd
upnp:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_upnp
watc:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_watchdog
hueh:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_hue
p1p1:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_p1
zwav:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_zwave
ligh:345:respawn:/etc/init.d/HCBv2 inittabwrap lighttpd
# end of 'inittabwrap' section.
Then, after a reboot, check which of the toon-specific executables actually run You can use the top command for this.
Mem: 120548K used, 5160K free, 0K shrd, 0K buff, 12952K cached
CPU: 5% usr 4% sys 0% nic 90% idle 0% io 0% irq 0% sirq
Load average: 0.45 0.40 0.35 1/150 20746
PID PPID USER STAT VSZ %MEM %CPU COMMAND
692 1 root S 39708 32% 3% HCBv2 hdrv_zwave [OK] [E9E6F8F5 SIS Z-Wave 3.67] [S1|N1]
22603 1 root S 163m 133% 2% /HCBv2/sbin/qt-gui -platform linuxfb -plugin Tslib
20728 20492 root R 3048 2% 1% top
681 1 root S 22060 18% 1% HCBv2 hcb_rrd [OK] [S1|N1]
27345 1 root S 12576 10% 0% /usr/bin/x11vnc-bin -shared -forever -rawfb map:/dev/fb0@800x480x32 -pipeinput UINPUT:touch,touch_alw
659 1 root S 350m 286% 0% HCBv2 hcb_comm [OK] [21 clients] [S1|N1]
673 1 root S 22220 18% 0% HCBv2 hcb_config [OK] [S1|N1]
658 1 root S 21676 17% 0% HCBv2 hcb_netcon [OK] [S1|N1]
691 1 root S 21636 17% 0% HCBv2 hdrv_p1 [OK] [Z:OK E:OP (P1) G:OP S:OP] [S1|N1]
682 1 root S 15044 12% 0% HCBv2 hcb_upnp [OK] [S20|N1]
680 1 root S 12292 10% 0% HCBv2 hcb_log [OK] [S1|N1]
690 1 root S 22720 18% 0% HCBv2 hdrv_hue [OK] [S1|N1]
668 1 root S 22664 18% 0% HCBv2 happ_thermstat [OK] [S20|N1]
662 1 root S 21868 17% 0% HCBv2 happ_pwrusage [OK] [S30|N1]
661 1 root S 21552 17% 0% HCBv2 happ_kpi [OK] [S1|N1]
689 1 root S 21464 17% 0% HCBv2 hcb_watchdog [OK] [S20|N1]
660 1 root S 21144 17% 0% HCBv2 happ_eventmgr [OK] [S1|N1]
667 1 root S 20636 16% 0% HCBv2 happ_smartplug [OK] [S1|N1]
665 1 root S 20508 16% 0% HCBv2 happ_scsync [OK] [S1|N1]
670 1 root S 20432 16% 0% HCBv2 happ_usermsg [OK] [S1|N1]
671 1 root S 14440 11% 0% HCBv2 happ_weather [OK] [S20|N1]
672 1 root S 13824 11% 0% HCBv2 hcb_bxtproxy [OK] [S:0:4263:2733 R:0:0 Q:0 (PRD)] [S1|N1]
702 1 root S 13512 11% 0% /HCBv2/bin/lighttpd -D -m /HCBv2/lib/lighttpd -f /HCBv2/etc/lighttpd/lighttpd.conf
14624 1 root S 3488 3% 0% wpa_supplicant -B -i wlan0 -P /var/run/wpa_supp-wlan0.pid -c /etc/network/wpa_supplicant.wlan0.conf -
14667 1 root S 3472 3% 0% /usr/sbin/nmbd -s /etc/samba/smb.conf
20492 20483 root S 3048 2% 0% -sh
598 1 root S 2876 2% 0% /bin/sh /root/read_temp.sh toon_t
657 1 root S 2876 2% 0% /sbin/getty -L 115200 ttymxc0 vt102
614 1 root S 2872 2% 0% /sbin/syslogd -n -O /var/log/messages -s 128 -b 1 -m 20
616 1 root S 2872 2% 0% /sbin/klogd -n
14590 1 root S 2872 2% 0% udhcpc -b -R -i eth0 -A 5 -p /var/run/udhcpc.eth0.pid -H toon
14683 1 root S 2872 2% 0% udhcpc -b -R -i wlan0 -A 5 -p /var/run/udhcpc.wlan0.pid -H toon
20703 598 root S 2740 2% 0% sleep 60
14753 1 root S 2616 2% 0% /usr/sbin/chronyd -r
20483 611 root S 2336 2% 0% /usr/sbin/dropbear -r /etc/dropbear/dropbear_rsa_host_key -p 22
611 1 root S 2164 2% 0% /usr/sbin/dropbear -r /etc/dropbear/dropbear_rsa_host_key -p 22
1 0 root S 1600 1% 0% init [5]
3 2 root SW 0 0% 0% [ksoftirqd/0]
... snip ...
All HCBv2-related stuff should be there. If not, start checking what's missing.
Then, I'm not sure what you actually did with the rollback, but it could very well be that some packages from different versions do not really work together very well. So, it may be interesting to find out which version of each package you use (if not the ones supplied in a _single_ FW update), and then correct if necessary.
Posted: Sun Apr 09, 2017 4:37 pm
by klaphekje
The only thing missing is the qt-gui but unfortunately, starting it manually is no option because it always starts with blank tiles. Maybe it is possible to add an argument to point to a config file?
Do some of you also run on 3.7.9? I would like to compare the package versions.
My packages:
base-files - 3.0.14-r100
base-passwd - 3.5.20-r1
base-qb2-ene - 3.7.9-1067-0
boot-logos - 1.64-ene
busybox - 1.18.3-r42.1
busybox-mountall - 1.18.3-r42.1
busybox-syslog - 1.18.3-r42.1
ca-certificates - 20160104-r0
chrony - 1.27-r1
curl - 7.21.2-r5.0
directfb - 1.2.8-r1.0
dropbear - 2015.71-r0
firmware-ba - 1.43
firmware-ma - 1.94
firmware-zwave-ctrlr - 1.7-4.55-NrNfNm-noeep
flash-gui - 1.651-ene-qeio
flash-lite-adobe - 4.0.3-54-fb0
flash-qwidget-diy - 1.161-qeio
freetype - 2.4.3-r1
glibc - 2.10.1-r37.1
glibc-binary-localedata-de-de - 2.10.1-r37.1
glibc-binary-localedata-en-gb - 2.10.1-r37.1
glibc-binary-localedata-en-us - 2.10.1-r37.1
glibc-binary-localedata-es-es - 2.10.1-r37.1
glibc-binary-localedata-fr-fr - 2.10.1-r37.1
glibc-binary-localedata-it-it - 2.10.1-r37.1
glibc-binary-localedata-nl-nl - 2.10.1-r37.1
glibc-gconv - 2.10.1-r37.1
glibc-gconv-iso8859-1 - 2.10.1-r37.1
glibc-localedata-i18n - 2.10.1-r37.1
glibc-localedata-iso14651-t1 - 2.10.1-r37.1
glibc-localedata-iso14651-t1-common - 2.10.1-r37.1
glibc-localedata-translit-circle - 2.10.1-r37.1
glibc-localedata-translit-compat - 2.10.1-r37.1
glibc-localedata-translit-fraction - 2.10.1-r37.1
glibc-localedata-translit-narrow - 2.10.1-r37.1
glibc-localedata-translit-neutral - 2.10.1-r37.1
glibc-localedata-translit-small - 2.10.1-r37.1
glibc-patch-dns - 2.10.1-r37.2
gnupg - 1.4.10-r3
gnutls - 2.10.4-r11.0
gpgv - 1.4.10-r3
happ-eventmgr - 1.164-master
happ-kpi - 1.318-master
happ-pwrusage - 1.561-ene-master
happ-scsync - 1.213-ene-master
happ-smartplug - 1.153-master
happ-thermstat - 1.1117-ene-master
happ-usermsg - 1.48-master
happ-weather - 1.115-master
hcb-bxtproxy - 1.133-master
hcb-comm - 1.165-TN-master
hcb-config - 1.283-master
hcb-log - 1.65-master
hcb-netcon - 1.288-master
hcb-rrd - 2.140-master
hcb-upnp - 1.87-master
hcb-watchdog - 1.44-master
hdrv-hue - 1.86-master
hdrv-p1 - 1.609-ene-master
hdrv-zwave - 1.905-master
i2c-tools - 3.0.3-r0
initscripts - 1.2-r6-runlvls
iptables - 1.4.9.1-r7.1
jansson - 1.3-r1.0
joe - 3.1-r3
jpeg - 8b-r1
kernel - 2.6.36-R10-h25
kernel-image - 2.6.36-R10-h25
kernel-module-fat - 2.6.36-R10-h25
kernel-module-ftdi-sio - 2.6.36-R10-h25
kernel-module-msdos - 2.6.36-R10-h25
kernel-module-pl2303 - 2.6.36-R10-h25
kernel-module-rt5370sta - 2.6.36-R10-h25
kernel-module-rtl8191su - 2.6.36-R10-h25
kernel-module-vfat - 2.6.36-R10-h25
kernel-module-zwave300 - 2.6.36-R10-h25
less - 436-r1
libcrypto - 0.9.8m-r14.1
libcurl - 7.21.2-r5.0
libgcc - 4.5-r33.1+svnr170443
libgcrypt - 1.4.1-r0
libgpg-error - 1.4-r7.1
libhcb-base - 1.244-master
libhcb-boxtalk - 1.108-master
libhcb-com - 1.109-TN-master
libhcb-drv - 1.304-master
libhcb-xml - 1.95-master
libnetfilter-conntrack - 0.0.101-r0
libpcre - 7.6-r8
libpng12 - 1.2.44-r3.0
libssl - 0.9.8m-r14.1
libstdc++ - 4.5-r33.1+svnr170443
libsysfs - 2.1.0-r3
libuuid - 2.18-r36.0
lighttpd - 1.4.33-17
lighttpd-mod-hcb-web - 1.4.33-26
locale-base-de-de - 2.10.1-r37.1
locale-base-en-gb - 2.10.1-r37.1
locale-base-es-es - 2.10.1-r37.1
locale-base-it-it - 2.10.1-r37.1
locale-base-nl-nl - 2.10.1-r37.1
lzo2 - 2.03-r0
makedevs - 1.0.0-r10
module-init-tools-depmod - 3.12-r6
modutils-initscripts - 1.0-r3
mtd-utils - 1.4.1-r0
ncurses-libncurses - 5.7+20110115-r16
ncurses-libtinfo - 5.7+20110115-r16
openssh-sftp-server - 7.3p1-r10.0
openssl - 0.9.8m-r14.1
openssl-conf - 0.9.8m-r14.1
openvpn - 2.3.6-r2.1
opkg - 0.1.8+svns635-r7-gcv
opkg-collateral - 1.0-r3
pointercal - 0.0-r22
qt-gui - 1.6755-ene-release-ene-3.7
qt-libs - 5.3.1-06-setpos
qt-squish - 5.3.1-5.1.1-03-setpos-4
samba-nmbd - 3.0.20-r8
sysvinit-inittab - 2.86-r63
sysvinit-utils - 2.86-r63
tslib-conf - 1.0-r28.7hae
tzdata-americas - 2011b-r8.0
update-modules - 1.0-r10
wget - 1.12-r8.2
wireless-tools - 29-r5
wpa-supplicant - 2.0-r3
wpa-supplicant-cli - 2.0-r3
wpa-supplicant-passphrase - 2.0-r3
www-jquery-ui - 1.8.21-16
www-resources - 1.16
x11vnc - 0.9.13-r2
zlib - 1.2.3-r7.0
Posted: Sun Apr 09, 2017 10:06 pm
by marcelr
I don't have 3.7.9 running, but I compared my list with yours. Apart from a lot of old stuff (from the initial install of my toon, version 1.9.10) that has been removed, only one file stands out: qt-squish - 5.3.1-5.1.1-03-setpos-4
It's probably not a package that has been installed lately. Can you check its installation date? I can't find it anywhere in my lists, not sure what it does.
While you're at it, can you also check the contents of /HCBv2/config/config_qt-gui.xml? This file should hold your tile configuration.
Posted: Mon Apr 10, 2017 8:17 am
by QuasaR
marcelr wrote:I don't have 3.7.9 running, but I compared my list with yours. Apart from a lot of old stuff (from the initial install of my toon, version 1.9.10) that has been removed, only one file stands out: qt-squish - 5.3.1-5.1.1-03-setpos-4
That package is already in 3.0.29 release. It hasn't changed since.
If you know the previous firmware versions we might be able to track in which version it was introduced.
Posted: Tue Apr 11, 2017 5:58 pm
by klaphekje
The contents of the qt-gui config seem to be in the state i left them when it still worked. There are several tiles defined, but they do not show up.
What do you make of this:
eneco-001:~# /HCBv2/sbin/qt-gui
[hxml] libhcb_xml v0.1 r95 (Sep 16 2016 14:47:44) [master#5f72a810bf] (ezxml 0.8.6)
[hbxt] libhcb_boxtalk v0.1 r108 (Sep 16 2016 14:48:00) [master#3304abef08]
[hcom] libhcb_com v0.1 r109 (Sep 16 2016 14:48:13) [master#10e07c208f] (OpenSSL 0.9.8m)
[hdrv] libhcb_drv v0.1 r304 (Oct 18 2016 15:08:54) [master#63d8ae157a]
[hbas] libhcb_base v0.1 r244 (Sep 26 2016 15:17:41) [master#59edff2eb6]
QIconvCodec::convertToUnicode: using Latin-1 for conversion, iconv_open failed
QIconvCodec::convertFromUnicode: using Latin-1 for conversion, iconv_open failed
This application failed to start because it could not find or load the Qt platform plugin "directfb".
Available platform plugins are: linuxfb.
Reinstalling the application may fix this problem.
Aborted
Starting qt via the "/usr/sbin/startqt"
does work.
Offcourse reinstalling "qt-gui" or "directfb" does not work -_-"
Posted: Tue Apr 11, 2017 8:45 pm
by marcelr
Starting qt via the "/usr/sbin/startqt" does work.
Makes sense.
/usr/sbin/startqt adds two cli arguments to qt-gui:
exec /HCBv2/sbin/qt-gui -platform linuxfb -plugin Tslib
Platform info (directfb, so framebuffer support) and a plugin to enable the touchscreen (Tslib), qt-gui by itself lacks this information and therefore gives you the error.
If startqt works and gives you "normal" behaviour, the problem may be in /etc/inittab.
What is the _exact_ line in inittab for starting qt-gui?
Posted: Fri Apr 14, 2017 10:07 pm
by klaphekje
Your comments about qt-gui / startqt pointed me in the right direction.
My inittab looks like this after the update:
# of runlevel.
qtqt:245:respawn:/usr/bin/startsquish >/dev/null 2>&1
#Aanvulling serial console 22-2-2017
I don't know where the "squishserver" is for but i commented that line out and simply added:
Two problems are solved now, qt-gui works again and the extreme lag i experienced after the upgrade to 3.7.9 is gone by commenting out the squishserver line.
Thanks again for the help!
Posted: Sat Apr 15, 2017 9:40 am
by marcelr
klaphekje wrote:I don't know where the "squishserver" is for
Apparently it's a piece of code that's being used for field testing. My toons don't have it, they were never used in field tests. It enables remote debugging/controlling of (in this case) Qt applications. From your picture, it's clear that it serves its data on port 4322. Most likely, your /etc/default/iptables.conf has an extra line for that port.
Installation size is quite something: 14.4 MiB. Possibly it replaces the standard qt library (which is ~12.4 MiB). If not, you will likely have issues in memory usage ...
Posted: Sun Aug 20, 2017 1:04 pm
by homesweethome
I rooted my Toon with the info i got on this board, thanks for the very detailed 'how to's', it went nice and easy, even bought a 'test Toon' as well on MP
One thing i can't figure out, my SSH connection to Toon is no problem, but only no problem if i connect Toon with UTP, if UTP cable is disconnected and i want to make SSH connection via WiFi, there's no connection possible, when i connect UTP cable all is well and SSH connection is even possible via WiFi ip adres, same behavior has my test Toon. (no SSH connection possible via WiFi, no problem via cable)
Can some point me in the right direction?
