android app TOON
- Starting Member
Re: android app TOON
Marcel,
There’s no rush, but if you want to, I would be very grateful as this is way above my head.
Martin
Martin
I'll look into it, but it will take time. It requires a rebuild of lighttpd and libssl. The latter is a rather nasty one.
My phone reports the app is malware. I've got a Samsung S7 with android 7.0.
If I ignore and install the app doesn't seem to work with my rooted toon with Firmware 4.10. It can't make a connection.
I can ready Toon from the browser just fine.
first i say great work
On my local network it work fine but from the internet i not can connect how i have to set my hackt toon to work from outside my network
Toon solarpannels
- Starting Member
Funfair,FunFair wrote:My phone reports the app is malware. I've got a Samsung S7 with android 7.0.
Are you on the same lan with your (wifi) phone?
- Starting Member
The firewall of your internet router is in between and you need to use the external IP address.ams123 wrote:first i say great work
First you have to port forward port 80 in your router from the Toon IP address to the external IP address and then set the external IP address in the app.
I do not recommend this as this is not a secure connection. Everybody can access your Toon. SSL and Authentication is not yet implemented.
Personally, I use a VPN connection between my phone and local lan.
@Martin101010
openssl/libssl (the latest and greatest) is more or less ready. Turned out to be a no-brainer
lighttpd is next in line, but not until the weekend ..
- Starting Member
That's good News, but no stress.marcelr wrote:@Martin101010
Verstuurd vanaf mijn SM-G950F met Tapatalk
- Starting Member
I also wrote an Android app for the rooted Toon, which can be found here:
https://github.com/fabianblom/Toon-Android
I wrote this app a couple of months ago not knowing that there was already an app created for the rooted Toon.
This app works on my rooted toon but it is possible that it's not compatible with every version.
Please let me know if there are any questions.
not work for mevlabianski wrote:I also wrote an Android app for the rooted Toon, which can be found here:
Toon solarpannels
Here not working too, software version Toon is 4.8.25vlabianski wrote:I also wrote an Android app for the rooted Toon, which can be found here:
I'm running on 4.10.6 and it's not working either.vlabianski wrote:I also wrote an Android app for the rooted Toon, which can be found here:
Also, on github I see the following about external connections: [/quote]Host a webservice within your network that accepts only requests that contains the Api-Key. Use a port forwarding rule to forward to the script.[/quote]
Do you have an example of how to run a webservice/script like that?
- Starting Member
Okay, it supposed to work when you fill in the following in the settings screen when youre connected to the same network as your Toon or VPN ofcourse (uncheck redirection service checkbox):
Toon URL: http://ipaddress:port, for example http://192.168.1.1:12345
After entering this information you need to kill the app and restart it.
I have succesfully tested the app on my own phone.
I created the following script to redirect traffic to Toon when the http header filled in the app matches the one on the webservice (check redirection service checkbox and enter token in the settings screen on the app):
https://pastebin.com/0JpGV1T7
It's simple but it does the job.
Is the app crashing or is it just not showing any data?
It's working better now; the app shows the correct data.
(The example in the app doesn't mention http://, I left it out because I thought it wasn't required...)
But it crashes right away, all the time...
- Starting Member
Thanks for the feedback.
I suspect it crashes because the app expects the device info to be in format device2_1/device2_2 etc
while a lot of people probably use 3_1/3_2 (see https://goo.gl/oizDi8).
I will see if I can do something about it in the evening/tomorrow because I'm currently at work.
