Your memory usage is ok. What apps do you have installed?PeJeWe wrote:
what can i do to solve this?
Spontaneous restarts, why?
Re: Spontaneous restarts, why?
My rooted Toon 1 with latest firmware also reboots spontaneous. When I removed the afvalkalender app my problems were gone.
i am running toonstore app, buienradar, afvalkalender, DomoticzBoard.TheHogNL wrote:Your memory usage is ok. What apps do you have installed?PeJeWe wrote:
all toon subscription features are off in TSC.
Hier hetzelfde gedonder met de Toon....met regelmaat spontane herstarts, vandaag al 2x zag ik.
Ik heb geen extra app`s geïnstalleerd, alleen de klok, gas vandaag, stroom vandaag en stroom gebruik nu.
Ik word er zo langzamerhand droevig van.
i had this morning also 2 spontaneous restarts
top results:
df status
top results:
Mem: 122920K used, 3276K free, 420K shrd, 0K buff, 37020K cached
CPU: 0% usr 38% sys 0% nic 61% idle 0% io 0% irq 0% sirq
Load average: 0.95 0.56 0.49 1/139 18753
PID PPID USER STAT VSZ %VSZ %CPU COMMAND
753 1 root S 179m 145% 13% /qmf/sbin/qt-gui -platform linuxfb -plugin Tslib
18749 18618 root R 3232 3% 13% top
777 1 root S 39920 32% 9% {hdrv_zwave} HCBv2 hdrv_zwave [OK] [C4025F76 SIS 3.67] [S1|N1]
756 1 root S 23164 18% 4% {hcb_netcon} HCBv2 hcb_netcon [OK] [S1|N1]
757 1 root S 301m 244% 0% {hcb_comm} HCBv2 hcb_comm [OK] [18 clients] [S1|N1]
766 1 root S 25528 20% 0% {hcb_config} HCBv2 hcb_config [OK] [S1|N1]
770 1 root S 24496 19% 0% {hdrv_hue} HCBv2 hdrv_hue [OK] [S1|N1]
759 1 root S 23608 19% 0% {happ_pwrusage} HCBv2 happ_pwrusage [OK] [S1|N1]
762 1 root S 23508 19% 0% {happ_thermstat} HCBv2 happ_thermstat [OK] [ON/OFF] [S20|N1]
771 1 root S 23336 18% 0% {hdrv_p1} HCBv2 hdrv_p1 [OK] [C:OK E:OP (P1) G:OP (P1) ] [S1|N1]
768 1 root S 23108 18% 0% {hcb_rrd} HCBv2 hcb_rrd [OK] [S1|N1]
760 1 root S 23076 18% 0% {happ_scsync} HCBv2 happ_scsync [OK] [S1|N1]
763 1 root S 22932 18% 0% {happ_usermsg} HCBv2 happ_usermsg [OK] [S1|N1]
758 1 root S 21968 17% 0% {happ_eventmgr} HCBv2 happ_eventmgr [OK] [S1|N1]
761 1 root S 21344 17% 0% {happ_smartplug} HCBv2 happ_smartplug [OK] [S1|N1]
769 1 root S 21312 17% 0% {hcb_watchdog} HCBv2 hcb_watchdog [OK] [S20|N1]
764 1 root S 17672 14% 0% {hcb_bxtproxy} HCBv2 hcb_bxtproxy [OK] [S:0:3:38 R:0:0 Q:0 (PRD)] [S1|N1]
778 1 root S 14120 11% 0% /usr/sbin/lighttpd -D -m /usr/lib/lighttpd -f /qmf/etc/lighttpd/lighttpd.conf
767 1 root S 12080 10% 0% {hcb_log} HCBv2 hcb_log [OK] [S1|N1]
1211 1 root S 4176 3% 0% /usr/sbin/wpa_supplicant -B -P /var/run/wpa_supplicant.wlan0.pid -i wlan0 -c /etc/network/wpa_s
18618 18596 root S 3408 3% 0% -sh
702 1 root S 3296 3% 0% /sbin/syslogd -n -C64 -m 20
755 1 root S 3232 3% 0% {tsc} /bin/sh /usr/bin/tsc
1238 1 root S 3232 3% 0% udhcpc -b -R -i eth0 -A 5 -p /var/run/udhcpc.eth0.pid -H eneco-001-289077
704 1 root S 3232 3% 0% /sbin/klogd -n
18616 18597 root S 3232 3% 0% sh -c /usr/libexec/sftp-server
1251 1 root S 3232 3% 0% udhcpc -R -n -p /var/run/udhcpc.wlan0.pid -i wlan0 -x hostname:eneco-001-289077 -t 2
18739 755 root S 3100 2% 0% sleep 5
1300 1 root S 2748 2% 0% /usr/sbin/chronyd -r
18596 695 root S 2740 2% 0% /usr/sbin/dropbear -r /etc/dropbear/dropbear_rsa_host_key -p 22
18597 695 root S 2440 2% 0% /usr/sbin/dropbear -r /etc/dropbear/dropbear_rsa_host_key -p 22
695 1 root S 2268 2% 0% /usr/sbin/dropbear -r /etc/dropbear/dropbear_rsa_host_key -p 22
18617 18616 root S 2128 2% 0% /usr/libexec/sftp-server
Filesystem 1K-blocks Used Available Use% Mounted on
ubi0:rootfs 105740 80076 25664 76% /
tmpfs 63096 388 62708 1% /var/volatile
Check 'uptime' command if it is really rebooted or only qt-gui restarted please
uptime resultTheHogNL wrote:Check 'uptime' command if it is really rebooted or only qt-gui restarted please
20:36:31 up 1 day, 14:29, load average: 0.46, 0.51, 0.47
i did not a update (auto update is off) or a manual reboot
22:00 uur derde herstart van vandaag.... ik ga hem vannacht eens de hele nacht van het stroom halen.
Weet je in elk geval zeker dat-ie niet herstart ...
Voor de rest wordt de situatie daar niet anders van.
Vandaag nog geen herstarts gezien... dus wie weet heeft het even geholpen.marcelr wrote:Weet je in elk geval zeker dat-ie niet herstart ...
Ook mijn Toon2 heeft last van dit issue. Geen directe aanleiding op basis waarvan ik een indicatie kan geven over een mogelijke oorzaak. Probleem lijkt ontstaan te zijn na update Toonstore van afgelopen week en aansluitende installatie van NL Alert. Uninstall van de app heeft geen effect op het ongewenst opnieuw opstarten van de Toon. Graag jullie analyse en mogelijke oplossing.
En is het niet postnl app toevallig?
Helemaal correct. PostNL app verwijderd en de Toon2 werkt weer als een zonnetje.
Dankjewel TheHogue
Dankjewel TheHogue
