Page 3 of 3
The Bwired electricity monitor
Posted: Sat Oct 06, 2007 10:47 pm
So you are still working on this.
Put an example record in the topic, that makes it easier to analyze.
But I think your GROUP BY by is not right, make this "GROUP BY date, hour(date)"
Pieter
Posted: Sun Oct 07, 2007 9:25 pm
by tonlof
Now I get the right outputs:)
Last day...
SELECT CONCAT(DATE_FORMAT(datum, '%Y-%m-%d %H'),':00') AS tid, sum(watt) FROM energi
WHERE datum >=date_sub(current_date(),interval 1 day)
GROUP BY DATE_FORMAT(datum, '%Y-%m-%d %H')
ORDER BY DATE_FORMAT(datum, '%Y-%m-%d %H') ASC;
1 Month back...
SELECT DATE_FORMAT(datum, '%Y-%m-%d') AS tid, sum(watt) FROM energi
WHERE datum >=date_sub(current_date(),interval 30 day)
GROUP BY DATE_FORMAT(datum, '%Y-%m-%d')
ORDER BY DATE_FORMAT(datum, '%Y-%m-%d') ASC;
/Tony
Posted: Mon Oct 08, 2007 12:46 am
by tonlof
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">I also log my energy once a minute, but I'm not adding a record every minute in the database. I create one record for every hour but update it every minute.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Maybe this is a better way to shrink entry in the sql.
Do you have any hint how to úppdate to correkt hour? How is the table designed?
/Thanks Tony
Posted: Mon Oct 08, 2007 11:47 am
Hi Tony,
Yes As I told above, I'm not interested in a detailed logging, If I want that I can set an option button in my Domoticasysteem and I get readings every minute. I have 24 records a day, what I do is select the current date and hour record from my database. Lets say today hour 10, if the select finds a record I update the record with current energy consumption accumulate all the new totals like power consumption today, total etc. If the select does not find a record this means a new hour has began and I add a new record to the database.
Its all very simple.
Posted: Mon Oct 08, 2007 7:27 pm
by tonlof
Thanks Pieter.
I think I am close the total solution.
First check in the database if there is any record at this hour.
select * from energi where hour(datum) = hour(CURRENT_TIMESTAMP()) and day(datum) = day(CURRENT_TIMESTAMP())
/Tony
Posted: Mon Oct 08, 2007 8:08 pm
Right, once you got the record you can update the fields with the current reading (adding hourly usage, daily usage etc)
Posted: Sun Jan 06, 2008 6:04 pm
by zapp
Hi.
I want to try out this way of monitoring the energy meter. I have ordered every component, but instead of a tai8585 i recveived a tai8586.
I now need some electronics help on how to connect the 8586 to the mk120. any ideas appreciated? a schematics would be great.
Thanks in advance
Posted: Tue Jan 06, 2009 9:34 am
by promy
to connect the 2 boards, does it matter how the BC547 is orientated. I suppose you remove the reed contact and connect the bc547 directely to the 2 pads. Should the emitter be conencted to the the signal side of the ds2423? ro is it the collecter that provide the "low-going" pulse?
Thanks in advance!
Posted: Tue Jan 06, 2009 2:08 pm
Connect it to J11 or J27, the TAI8586 has two counters.
Posted: Tue Jan 06, 2009 2:49 pm
by promy
sorry to keep bothering you, but should the emittor or collector of the BC547 be connected to the DS2324?
thanks!
Posted: Tue Jan 06, 2009 3:23 pm
I don't know the TAI8586, it has no read contact but instead of that two optocoupler input contacts. If you connect the BC547 to one of those connectors it should be working I guess. With the TAI8585 you are right, but this a different schematic. You have to experiment with it, I think if you shortcut J11 or J27 for a moment the counter is counting +1?
Posted: Tue Jan 06, 2009 8:59 pm
by CLC
The TAI8586 has two optocoupler input contacts. To activate the optocoupler a small current is needed. You can try it with an old 1,5V battery.
I've used an amplifier (TLC271) together with a diode (BPW43) and a couple of resistors.
