X10 rain sensor
Posted: Mon May 04, 2009 7:16 am
nice to see another singaporean. well, the windows and doors are the same actually, you cant have a door that is not brown in color. how i know, I glued a thin sheet of brushed aluminium to cover the main door(the side that faces outside) because after a while my wood got suntan mark shaped of the door grill.
so anyway, I got someone came knocking on my door telling me that I cant have this type of door. for reasons like, thou it's fireproof it must be able to be chopped open by fire fighters( poor lass thought it was solid metal.) and on top of that someone complain that the metal is reflecting into someone house when the sun shines.
but besides that, I really like the look of the door. it looks like a solid armour plated door.
as for windows changing color, you can choose any color as long as it's stainless steel color.
at least 5 months to change not bad. singapore have to pay $3k to submit for approval, approval is another matter.
as for the rain sensor, I got another alternative. I coated the sensor with silicon oil thingy. and remove the access so that the silicon goes into the grooves to prevent algae growing.
on top of that I set HS to ONLY IF RAIN SENSOR = WET FOR MORE THAN 60S THEN NOTIFY. it seems to work perfectly only problem is only 1m after it rains then i know it's really raining. but better than nothing. I also just finished installed my auto windows closer. I was told that doing such a thing is illegal in singapore also. as it states "no modification to windows" in HDB law that i read somewhere.
your concept has a flaw. it doesnt work for someone staying near the sea like me. (marine parade) my house faces 45 degrees directly to the sea.
it's not even raining and it's already 81% humidity now with bright sunshine.
as for lightning protection, i used a china made X10 40A whole house filter which is also a lightning surge protector.
