Monitoring Phonecalls
Edwin2008
Post by Edwin2008 »
With a siemens (ISDN SX255) pbx you could use the M34 USB device and in the application provided you are able to see all incoming and outgoing calls including which number they are trying to reach
<br />Is there no phone in on the Fritz?
idea is to use the Fritz as router and DECT PABX
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Chak, There is also a Fritz box with Dect support, so you can connect your dect phones directly
flexer
Post by flexer »
Like Digit, I also use a Fritz!Box 7170 ADSL/ISDN/VOIP/WLAN router. I'm very happy with it's numerous capabilities. I use Homeseer as my Domotica system, and I would like to display the caller list of the Fritz!Box in a Homeseer webpage. Has somebody already got this working?
I've a working Telnet session to the Fritz!box on port 1012 and I can monitor the calls in this Telnet session and log the output to a diskfile. However, some programming needs to be done to get the information from this diskfile into Homeseer. I'm open for any suggestions...
Dickr43
Post by Dickr43 »
I also use a 7170 and would like to know how you achieved the monitoring through Telnet. Do you have any instructions on how to do this available?
CLC
Post by CLC »
<br />[Chak, There is also a Fritz box with Dect support, so you can connect your dect phones directly
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">The FRITZ!Box Fon WLAN 7270 http://www.avm.de/en/Produkte/FRITZBox/ ... /index.php
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by dickr43</i>
<br />I also use a 7170 and would like to know how you achieved the monitoring through Telnet. Do you have any instructions on how to do this available?
This should get you going:
http://wehavemorefun.de/fritzbox/Hilfsp ... amm_melden
flexer
Post by flexer »
Dick, enable the telnet server by using an to the Fritz!Box attached telephone to send the dial sequence #96*7* . If you use the web interface hereafter, you will get a message "The modifications to your FRITZ!Box are not supported by the manufacturer", but you can ignore this. Next, start a telnet session (use PuTTY for this...) to port 1012 on your Fritz!Box and all your in- & outgoing calls will appear in the telnet session screen.
Dickr43
Post by Dickr43 »
Just got back from skiing, will try this tomorrow! Thanks a lot.
Don't forget to dial #96*5* also, cause that is what activates call monitoring (from what i read elsewhere). I just can't remember what @$#$~! codes i dialed anymore to get it working :-). Just try it if it doesn't work without...
flexer
Post by flexer »
Nobody who already included the Fritz!Box call logfile in a Homeseer webpage?
Flexer
pleaseask
Re: Monitoring Phonecalls
Post by pleaseask »
@ Edwin2008.
Edwin i have read your post of 08 dec 2008 where you are mentioning the M34 USB stick from Siemens.
I all so got the M34 usb stick from siemens. It seems that there is a SDK available.
Do you have such SDK for the M34?
Homeseer 3 Pro on Windows 10 / Zwave
Edwin.
Was anyone succesful in connection to a ziggo cable modem epc2203?
I want to get to the logs.
I have a Fritzbox behind my Ziggo modem, working perfect receiving call log etc.
Accessing the modem must be technically possible. You will need the admin codes, thees are not available. I'm also using the Fritzbox.
