Proliphix imt350 series
Re: Proliphix imt350 series
Would this type of thermostat work on my Nefit Smartline HR heater?
Now i have a Nefit Moduline 30 thermostat
No it wont work, you need to put it on the potential free input
Agree, Nefit is the worst hvac to buy for Domotica, I have on
Any other options for a thermostat for my Nefit?
I was not very clear
, it can work but you need to put it on a different connector on your Nefit Hvac.
Check if you have it
I have the proliphix on my Nefit smartline to
http://www.domoticaforum.eu/viewtopic.php?f=23&t=3961
i buy my proliphix thermostats at smarthome , they have much lower shipping costs then proliphix itself.
isnt there an easy way to ad an fahrenheid to celsius formula in the hs scripts.
labium
labium
Why do you (still) need that when the plugin will support Celsius soon. (read the other replies in this topic)
Cause I can't imagine using a Proliphix without having either the Plugin, or knowing the API.
A little update on the Plugin I was working on. Yesterday I sent the IMT350 back to its owner (thanks Akatar!).
I added some additional code to the Plugin to make the humidity readings more accessible (everybody who owns a IMT series thermostat will want that) and now that this has been tested and working fine, I will return the code to Homeseer so it can be made available in the updater.
http://blog.hekkers.net/2011/02/13/prol ... -finished/
Can someone tell me if imt350 will work with my HR heater AGPO-Ferroli MegaLux 6 with built in boiler.
I don't know where to look for compatibility. Perhaps someone can explain.
I'll order one too if it's going to work with HS and my heater. I'm also interested in sharing shipping costs...
HS-Proliphix works great with NT20e
Robert, the Proliphix plugin works great with the NT20e in Celcius.
Glad that the WEB-stat works in C-degrees now.
And Installing was a piece of cake !
Thanks a lot.
Verkenner
Thanks a lot.
Verkenner
Best regards, Verkenner
Thanks for the info, have fun with it!
Proliphix at Smarthome
Herbus, you can spent your money here
http://www.smarthome.com/3053T/Programm ... 20e/p.aspx
RGRDS, Verkenner
RGRDS, Verkenner
I would not buy the NT20 if you go for new, go for the 350. But somehow they are hard to get.
I'm trying to figur out what is going on with Proliphix for a while now. Looks like they made a B2B deal or something like that.
Not selling to europe, not telling anything about the 350 model protocol. Trying to change some things in the protocol to close it up again, at least they think. The 350 model protocol is open again thanks to Digit and also supported in the Homeseer plugin available free at Homeseer. proliphix is also not reacting to my mails while I got 2 demo NT20 models last year.
Second hand NT20 check here
shop.ebay.nl/i.html?LH_AvailTo=146& ... =proliphix
- Willem4ever
- Global Moderator
Are you sure this is the right link ?
edit: link adjusted by bwired
My mistake, link updated
