Page 3 of 3
Re: Latest additions to RFXtrx433 firmware
Posted: Fri Feb 28, 2014 12:31 pm
by labtec
b_weijenberg wrote:You can create a KD101 Output device with a different ID. Using the RFXtrx433 you can pair this KD101 with the Output device and assign another ID.
Thanks for your reply...................but I don't understand how to do this.
So I start with creating a KD101 output device, HS Unit Code, free to choose? Adress for the KD101, free to choose?
Posted: Fri Feb 28, 2014 12:43 pm
by labtec
I have create an output device, HS2 Unit code M1, adress 01 01.
In HS2 I see a device M1 with a panic and learn button, how can I pair the KD101 with this output device.
I tried to set the KD101 in learn mode (red led is on) and then send from HS2 with the learn button from the M1 device.............nothing happend I get
an error in the HS2 log "28-2-2014 11:37:36 RFXCOM (DeviceCmd) error unknown device: 35"
by b_weijenberg
Yes, select a random HS code and a random ID in the KD101 configuration.
see chapter 8.26 in the RFXCOM HS3 User Guide.pdf
or chapter 6.9 in the HS2 RFXCOM User Guide.pdf
Posted: Fri Feb 28, 2014 12:49 pm
by b_weijenberg
KD101 transmit is only supported by the RFXtrx433!
KD101 receive is supported by the RFXCOM receiver version 53 or later.
KD101 and SA30 receive and transmit is supported by the RFXtrx433
Posted: Fri Feb 28, 2014 12:57 pm
by labtec
b_weijenberg wrote:KD101 transmit is only supported by the RFXtrx433!
Oke, I have a RFXCOM LAN receiver/transmitter, so it is not possible to use KD101 transmit?
Posted: Fri Feb 28, 2014 1:04 pm
by labtec
labtec wrote:b_weijenberg wrote:KD101 transmit is only supported by the RFXtrx433!
Will there be an KD101 update for the LAN version? otherwise the only way is to buy the RFXtrx USB version
Posted: Fri Feb 28, 2014 1:13 pm
by b_weijenberg
The transmitter and RFXmitter have no user flash memory and cannot be updated.
For the moment no updates are foreseen for the RFXLAN.
Posted: Fri Feb 28, 2014 1:17 pm
by labtec
b_weijenberg wrote:The transmitter and RFXmitter have no user flash memory and cannot be updated.
So for now it is better to choose for the USB RFXtrx433? for this version there are frequently updates foreseen? and the RFXLAN
version is not supported any more?
To bad I recently choose for the LAN version
Thanks
Posted: Fri Feb 28, 2014 1:34 pm
by b_weijenberg
There are plans but due to other development activities this is not on the short term.
Posted: Fri Feb 28, 2014 1:44 pm
by labtec
b_weijenberg wrote:For the moment no updates are foreseen for the RFXLAN.
Thanks, the only "problem" is my 868.95MHz Visonic slave receiver in my LAN version, I have some Visonic devices.
Posted: Fri Feb 28, 2014 2:03 pm
by b_weijenberg
The Homeseer plug-ins support multiple interfaces so no problem to keep the RFXLAN and add the RFXtrx433.
The RFXLAN receiver perfoms a bit better for Oregon sensors. Enabling the same protocol in both receivers is possible except when using an OWL sensor. There is a small difference in the reported values due to rounding. Best is to enable te Oregon protocol only in the RFXLAN in this situation. If OWL is not used you can enable this protocol in both.
Posted: Fri Feb 28, 2014 3:38 pm
by labtec
Hi Bert,
Thanks, so there are possibilities
