Toon app: ToonStore
Re: Toon app: ToonStore
no, that is done fully automatic when the first update is coming from github for that app
"makkelijker kunnen we het niet maken"
pbtinus
Post by pbtinus »
hello,
I'm a new Toon user and justed rooted my Toon 1 today, everything went well except the toonstore, it stays empty.
If I manually install the 4.0 version through opkg ( opkg install http://files.domoticaforum.eu/uploads/T ... r0_qb2.ipk ) then the toonstore is filled but I can't install any apps ( only manually when downloading the IPK files )
if I install the 5.0 version :
curl -Nks https://raw.githubusercontent.com/IgorY ... -rooted.sh -o /root/update-rooted.sh
and then
sh /root/update-rooted.sh
no errors and after a reboot an empty toonstore.... what am I doing wrong?
thanks in advance
Oh, my Toon has the latest firmware 5.15.6 installed
what firmware is your Toon running?
Only firmware 5.x.x is supported with ToonStore version 5.
Recent versions of most apps are only fw5 compatible.
So my guess is that you are running on an older firmware.
If so, you have two choices :upgrade the Toon firmware or manually install the last versions of the apps which were compatible with older firmwares (see the Changelogs for that).
Post by TheHogNL »
pbtinus wrote: sh /root/update-rooted.sh
Did you run that with -f option? That is the first thing you need to do after rooting a Toon. You probably are missing some key rooted toon patches.
a small update (bugfix) of ToonStore is released in ToonStore. The auto update functionality for installed apps didn't work after a qui restart, only after going to the settings screen and enter an update time.
Changelog version 5.0.1:
- bugfix for the auto update timer, now working as expected
No need to update if you don't use the auto update functionality.
Kind regards,
glsf91
Post by glsf91 »
If I choose to install 1 app and to delete 1 app then Toonstore shows Bijwerken (0) instead of 2. Bug?
I did not test if the add end delete are going to succeed.
glsf91 wrote:If I choose to install 1 app and to delete 1 app then Toonstore shows Bijwerken (0) instead of 2. Bug?
That's a feature. The number is showing the net number of applications to be added to your Toon.
Reason is that we blocked adding more then 3 applications in one run.
This to prevent memory issues , specifically on a Toon 1, by installing too many apps.
In your example, pressing 'Bijwerken (0)' will actually remove one app and install the other.
Hope this clarifies.
Kind regards,
glsf91
Post by glsf91 »
Kind regards,
Ok thanks. It was a little bit confusing.
version 5.0.3 of the ToonStore is available in the ToonStore.
Changelog:
- when installing and deleting apps at the same time, the apps to be deleted were not actually deleted.
Kind regardz,
version 5.0.6 of the ToonStore is now available in the ToonStore.
You can now receive notifications of app updates.
You have to enable this functionality in the settings screen ('Instellingen').
Changelog:
- added functionality to send a notification when a new app has been added to the ToonStore.
- added functionality to send a notification when a new version of an installed app is available.
- in the settings screen two switches have been added to switch both types of notification on or off.
Kind regardz,
Bruce the boss
Post by Bruce the boss »
Okay but how do I update the store........ Sorry but I'm new and have to learn a lot :)
Verstuurd vanaf mijn SM-G950F met Tapatalk
Bruce the boss wrote:Okay but how do I update the store........ Sorry but I'm new and have to learn a lot :)
:D ToonStore is the first app in the list of apps in the ToonStore :D
Bruce the boss
Yes yes I know and I still have version 5.0.3 and don't see any option to update as with the other apps......
press the refresh button on the screen or wait up to 24 hours to refresh automatically
hi all,
a new version 5.0.7 is available in the ToonStore with improved notification functionality.
Changelog:
- repo is refreshed every 3 hours now.
- notifications are now also shown when not using auto-update functionality.
Kind regardz,
