Page 21 of 44
Posted: Mon Nov 26, 2018 5:10 pm
by gielie
TheHogNL wrote: However, there is not really need to update from 4.13.7. No big changes for which you need to update.
Yeah i know, dont fix if it aint broken, but still, id like to have TSC menu option in it and also the change to deactivate the unused standard toon apps.
Gonna try tonight, will report back if i have a problem.
Posted: Tue Nov 27, 2018 9:00 pm
by hayman
TheHogNL wrote:Please paste the complete log
>> 2018-11-24 18:56:17 +0000 (pid 4439) prepare-error-opkg-download-download 'opkg failed to download'
>> 2018-11-27 18:52:01 +0000 (pid 31910) upgrade-qb2.sh qb2 uni 4.22.7 prepare
>> 2018-11-27 18:52:01 +0000 (pid 31910) prepare
>> 2018-11-27 18:52:02 +0000 (pid 31910) preparing
>> Hotfix for writing System Time to RTC
Hardware Clock before: Tue Nov 27 18:52:02 2018 0.000000 seconds
Hardware Clock after : Tue Nov 27 18:52:02 2018 0.000000 seconds
>> configured opkg feeds:
src/gz base http://feed.hae.orig/feeds/qb2/uni/4.22.7
src/gz oebase http://feed.hae.orig/feeds/qb2/oe/2.6.3 ... 17-splash2
src/gz oekern http://feed.hae.orig/feeds/qb2/oe/2.6.36-R10-h27-no6
>> opkg --download-only update
>> monitoring /mnt/data/update for threshold 5000
Downloading http://feed.hae.orig/feeds/qb2/uni/4.22.7/Packages.gz.
Inflating http://feed.hae.orig/feeds/qb2/uni/4.22.7/Packages.gz.
Updated list of available packages in /var/lib/opkg/base.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.22.7/Packages.sig.
Signature check passed.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.3 ... ackages.gz.
Inflating http://feed.hae.orig/feeds/qb2/oe/2.6.3 ... ackages.gz.
Updated list of available packages in /var/lib/opkg/oebase.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.3 ... ckages.sig.
Updated list of available packages in /var/lib/opkg/oekern.
> Exit code: 0
>> opkg --download-only upgrade
/tmp/update.status.vars: Downloading 0% (1/166)
Downloading http://feed.hae.orig/feeds/qb2/uni/4.22 ... ut_qb2.ipk.
/tmp/update.status.vars: Downloading 0% (1/166) hcb-netcon
Downloading http://feed.hae.orig/feeds/qb2/uni/4.22 ... er_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.3 ... r2_qb2.ipk.
/tmp/update.status.vars: Downloading 1% (3/166) happ-pwrusage
/tmp/update.status.vars: Downloading 10% (19/166) libhcb-drv
/tmp/update.status.vars: Downloading 12% (22/166) happ-kpi
/tmp/update.status.vars: Downloading 14% (25/166) hcb-rrd
/tmp/update.status.vars: Downloading 15% (27/166) hcb-comm
/tmp/update.status.vars: Downloading 18% (32/166) www-resources
/tmp/update.status.vars: Downloading 22% (38/166) libhcb-xml
Downloading http://feed.hae.orig/feeds/qb2/uni/4.22 ... er_all.ipk.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.3 ... 09_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.3 ... 12_qb2.ipk.
/tmp/update.status.vars: Downloading 22% (39/166) tenant-eneco-nl
/tmp/update.status.vars: Downloading 23% (41/166) firmware-ma
Downloading http://feed.hae.orig/feeds/qb2/uni/4.22 ... 22_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.3 ... r0_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.22 ... os_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.3 ... q2_qb2.ipk.
/tmp/update.status.vars: Downloading 26% (46/166) qt-gui
/tmp/update.status.vars: Downloading 32% (55/166) hcb-bxtproxy
/tmp/update.status.vars: Downloading 34% (59/166) firmware-zwave-ctrlr
/tmp/update.status.vars: Downloading 35% (61/166) hdrv-zwave
/tmp/update.status.vars: Downloading 38% (65/166) happ-eventmgr
Downloading http://feed.hae.orig/feeds/qb2/uni/4.22 ... -0_qb2.ipk.
/tmp/update.status.vars: Downloading 39% (67/166) base-qb2-uni
/tmp/update.status.vars: Downloading 41% (70/166) happ-usermsg
/tmp/update.status.vars: Downloading 48% (82/166) happ-weather
/tmp/update.status.vars: Downloading 48% (83/166) libhcb-boxtalk
/tmp/update.status.vars: Downloading 64% (109/166) happ-smartplug
/tmp/update.status.vars: Downloading 65% (111/166) hcb-log
/tmp/update.status.vars: Downloading 71% (121/166) easyenergy
/tmp/update.status.vars: Downloading 72% (123/166) hdrv-p1
/tmp/update.status.vars: Downloading 73% (124/166) hdrv-hue
/tmp/update.status.vars: Downloading 82% (140/166) happ-thermstat
/tmp/update.status.vars: Downloading 83% (141/166) qmf-tenantize
/tmp/update.status.vars: Downloading 84% (143/166) firmware-ba
/tmp/update.status.vars: Downloading 88% (150/166) libhcb-base
/tmp/update.status.vars: Downloading 91% (154/166) happ-scsync
/tmp/update.status.vars: Downloading 91% (155/166) libhcb-com
/tmp/update.status.vars: Downloading 94% (159/166) sysvinit
/tmp/update.status.vars: Downloading 96% (163/166) hcb-config
/tmp/update.status.vars: Downloading 97% (164/166) www-jquery-ui
/tmp/update.status.vars: Downloading 100% (166/166) hcb-watchdog
Collected errors:
* opkg_download_pkg: Package easyenergy is not available from any configured src.
* opkg_install_pkg: Failed to download easyenergy. Perhaps you need to run 'opkg update'?
> Exit code: 255
>> 2018-11-27 18:54:15 +0000 (pid 31910) prepare-error-opkg-download-download 'opkg failed to download'
her you go ,hoop this will help thanks
Posted: Tue Nov 27, 2018 10:43 pm
by TheHogNL
Please run 'opkg remove easyenergy'
Posted: Fri Nov 30, 2018 7:05 pm
by hayman
its work thanks
Posted: Sat Dec 01, 2018 10:20 am
by mAiden
Your log file also said that he is stuck on it. Try to read log files properly, here you get a lot of information from Linux. ;)
Collected errors:
> Exit code: 255
If you had read this, you would have known that removing it would help.
Posted: Sat Dec 01, 2018 11:22 am
by TheHogNL
mAiden wrote: If you had read this, you would have known that removing it would help.
Should normally not happen. Easyenergy is not part of the original sources for the Toon so it's weird that the Eneco update script was failing on this part. Removing the package was indeed the solution
Posted: Fri Dec 14, 2018 2:34 pm
by Stephan296
I try to update with this script from 4.8.25 but none option doesn't work.
Every time i get this error in the log-file:
Package tenant-eneco-nl is not available from any configured src.
After that the update quits.
Posted: Fri Dec 14, 2018 3:15 pm
by mAiden
Stephan296 wrote:I try to update with this script from 4.8.25 but none option doesn't work.
Can you post the full log?
Maybe we can see where its going wrong. :)
Posted: Fri Dec 14, 2018 3:22 pm
by Stephan296
>> 2018-12-14 13:16:49 +0000 (pid 7015) upgrade-qb2.sh qb2 ene 4.10.6 prepare
>> 2018-12-14 13:16:49 +0000 (pid 7015) prepare
>> 2018-12-14 13:16:49 +0000 (pid 7015) preparing
Hardware Clock before: Fri Dec 14 13:16:49 2018  0.000000 seconds
Hardware Clock after : Fri Dec 14 13:16:49 2018  0.000000 seconds
src/gz base http://feed.hae.orig/feeds/qb2/ene/4.10.6
src/gz oebase http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/Packages.gz.
Inflating http://feed.hae.orig/feeds/qb2/ene/4.10.6/Packages.gz.
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/Packages.sig.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni/Packages.gz.
Inflating http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni/Packages.gz.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni/Packages.sig.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-R10-h27-no6/Packages.gz.
Inflating http://feed.hae.orig/feeds/qb2/oe/2.6.36-R10-h27-no6/Packages.gz.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-R10-h27-no6/Packages.sig.
> Exit code: 0
/tmp/update.status.vars: Downloading 0% (1/158)
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/hcb-netcon_1.346-master_qb2.ipk.
/tmp/update.status.vars: Downloading 0% (1/158) hcb-netcon
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/happ-pwrusage_1.674-master_qb2.ipk.
/tmp/update.status.vars: Downloading 1% (3/158) happ-pwrusage
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/libhcb-drv_1.342-master_qb2.ipk.
/tmp/update.status.vars: Downloading 11% (20/158) libhcb-drv
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/happ-kpi_1.406-master_qb2.ipk.
/tmp/update.status.vars: Downloading 13% (22/158) happ-kpi
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/hcb-rrd_2.159-master_qb2.ipk.
/tmp/update.status.vars: Downloading 15% (25/158) hcb-rrd
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/hcb-comm_1.184-N-master_qb2.ipk.
/tmp/update.status.vars: Downloading 16% (27/158) hcb-comm
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/libhcb-xml_1.111-master_qb2.ipk.
/tmp/update.status.vars: Downloading 21% (36/158) libhcb-xml
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/qt-gui_1.8075-ene-release-4.10_qb2.ipk.
/tmp/update.status.vars: Downloading 26% (43/158) qt-gui
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni/wpa-supplicant-cli_2.6-r0_qb2.ipk.
/tmp/update.status.vars: Downloading 26% (44/158) wpa-supplicant-cli
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/hcb-bxtproxy_1.349-master_qb2.ipk.
/tmp/update.status.vars: Downloading 31% (52/158) hcb-bxtproxy
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/hdrv-zwave_1.1284-master_qb2.ipk.
/tmp/update.status.vars: Downloading 35% (58/158) hdrv-zwave
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/base-qb2-ene_4.10.6-1196-0_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/flash-gui_1.651-ene-qeio_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/flash-lite-adobe_4.0.3-54-fb0_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/flash-qwidget-diy_1.161-qeio_qb2.ipk.
/tmp/update.status.vars: Downloading 36% (59/158) base-qb2-ene
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/happ-eventmgr_1.212-master_qb2.ipk.
/tmp/update.status.vars: Downloading 38% (63/158) happ-eventmgr
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/happ-usermsg_1.87-master_qb2.ipk.
/tmp/update.status.vars: Downloading 41% (67/158) happ-usermsg
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/happ-weather_1.147-master_qb2.ipk.
/tmp/update.status.vars: Downloading 48% (79/158) happ-weather
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/libhcb-boxtalk_1.123-master_qb2.ipk.
/tmp/update.status.vars: Downloading 49% (80/158) libhcb-boxtalk
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni/wpa-supplicant_2.6-r0_qb2.ipk.
/tmp/update.status.vars: Downloading 50% (82/158) wpa-supplicant
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/happ-smartplug_1.203-master_qb2.ipk.
/tmp/update.status.vars: Downloading 65% (105/158) happ-smartplug
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/hcb-log_1.79-master_qb2.ipk.
/tmp/update.status.vars: Downloading 66% (107/158) hcb-log
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/hdrv-p1_1.724-master_qb2.ipk.
/tmp/update.status.vars: Downloading 73% (118/158) hdrv-p1
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/hdrv-hue_1.221-master_qb2.ipk.
/tmp/update.status.vars: Downloading 73% (119/158) hdrv-hue
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/happ-thermstat_1.1919-release-4.10_qb2.ipk.
/tmp/update.status.vars: Downloading 82% (133/158) happ-thermstat
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/libhcb-base_1.293-master_qb2.ipk.
/tmp/update.status.vars: Downloading 88% (143/158) libhcb-base
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/happ-scsync_1.267-master_qb2.ipk.
/tmp/update.status.vars: Downloading 90% (146/158) happ-scsync
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/libhcb-com_1.124-N-master_qb2.ipk.
/tmp/update.status.vars: Downloading 91% (147/158) libhcb-com
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r14-uni/wpa-supplicant-passphrase_2.6-r0_qb2.ipk.
/tmp/update.status.vars: Downloading 92% (149/158) wpa-supplicant-passphrase
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/hcb-config_1.331-master_qb2.ipk.
/tmp/update.status.vars: Downloading 96% (155/158) hcb-config
Downloading http://feed.hae.orig/feeds/qb2/ene/4.10.6/../../POOL/hcb-watchdog_1.69-master_qb2.ipk.
/tmp/update.status.vars: Downloading 100% (158/158) hcb-watchdog
Collected errors:
 * opkg_download_pkg: Package tenant-eneco-nl is not available from any configured src.
 * opkg_install_pkg: Failed to download tenant-eneco-nl. Perhaps you need to run 'opkg update'?
> Exit code: 255
>> 2018-12-14 13:17:40 +0000 (pid 7015) prepare-error-opkg-download-download 'opkg failed to download'
Posted: Fri Dec 14, 2018 3:35 pm
by TheHogNL
Seeing some weird stuff.. your toon wants to download flash-gui package but from 3.0.0 that is already gone.
How did you update to 4.8.25 earlier?
You could try a force update to 4.19.10 (use option -v 4.19.10).
Posted: Fri Dec 14, 2018 3:40 pm
by Stephan296
I had update earlier with the same script to that version, but after that i pussed by mistake at my Toon the update button (sorry) and after that i cant access by ssh anymore.
After that i rooted it again to get the ssh option.
Also with the option -v 4.19.10 is going wrong.
Can i restore it or something?
>> 2018-12-14 13:34:01 +0000 (pid 2299) upgrade-qb2.sh qb2 ene 4.19.10 prepare
>> 2018-12-14 13:34:01 +0000 (pid 2299) prepare
>> Overriding HCB_FLAV to uni!
>> 2018-12-14 13:34:02 +0000 (pid 2299) preparing
Hardware Clock before: Fri Dec 14 13:34:02 2018  0.000000 seconds
Hardware Clock after : Fri Dec 14 13:34:02 2018  0.000000 seconds
src/gz base http://feed.hae.orig/feeds/qb2/uni/4.19.10
src/gz oebase http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r17-splash2
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/Packages.gz.
Inflating http://feed.hae.orig/feeds/qb2/uni/4.19.10/Packages.gz.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/Packages.sig.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r17-splash2/Packages.gz.
Inflating http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r17-splash2/Packages.gz.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r17-splash2/Packages.sig.
> Exit code: 0
>> opkg --download-only install base-qb2-uni tenant-eneco-nl
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/base-qb2-uni_4.19.10-1264-0_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/tenant-eneco-nl_1.76-master_all.ipk.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r17-splash2/psplash-toon_0.1+git0+14c8f7b705de944beb4de3f296506d80871e410f-r15-q09_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r17-splash2/psplash_0.1+git0+14c8f7b705de944beb4de3f296506d80871e410f-r15-q12_qb2.ipk.
> Exit code: 0
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/hcb-netcon_1.388-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/happ-pwrusage_1.747-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r17-splash2/zip_2.32-r2_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/libhcb-drv_1.381-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/happ-kpi_1.473-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/hcb-rrd_2.169-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/hcb-comm_1.194-N-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/www-resources_1.38-master_qb2.ipk.
/tmp/update.status.vars: Downloading 19% (32/158) www-resources
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/libhcb-xml_1.121-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/firmware-ma_1.135-master_all.ipk.
/tmp/update.status.vars: Downloading 23% (38/158) firmware-ma
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/qt-gui_1.8697-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r17-splash2/wpa-supplicant-cli_2.6-r0_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/hcb-bxtproxy_1.413-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/firmware-zwave-ctrlr_1.29-master_qb2.ipk.
/tmp/update.status.vars: Downloading 34% (56/158) firmware-zwave-ctrlr
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/hdrv-zwave_1.1535-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/happ-eventmgr_1.225-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/happ-usermsg_1.102-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/happ-weather_1.174-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/libhcb-boxtalk_1.138-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r17-splash2/wpa-supplicant_2.6-r0_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/happ-smartplug_1.258-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/hcb-log_1.91-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/hdrv-p1_1.924-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/hdrv-hue_1.266-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/happ-thermstat_1.2090-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/firmware-ba_1.47-master_all.ipk.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r17-splash2/qmf-tenantize_1.1-r0_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r17-splash2/qttools-tools-lrelease_5.3.1-21-add-x-tools_qb2.ipk.
/tmp/update.status.vars: Downloading 83% (134/158) qmf-tenantize
/tmp/update.status.vars: Downloading 84% (136/158) firmware-ba
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/libhcb-base_1.339-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/happ-scsync_1.342-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/libhcb-com_1.144-N-master_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r17-splash2/wpa-supplicant-passphrase_2.6-r0_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/oe/2.6.36-base-r17-splash2/sysvinit_2.86-r63-q2_qb2.ipk.
/tmp/update.status.vars: Downloading 93% (151/158) sysvinit
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/hcb-config_1.414-hotfix-b405-FTIM-117-Issues-with-updating-to-4-19-5_qb2.ipk.
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/www-jquery-ui_1.28-master_qb2.ipk.
/tmp/update.status.vars: Downloading 97% (156/158) www-jquery-ui
Downloading http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/hcb-watchdog_1.95-master_qb2.ipk.
Collected errors:
 * opkg_download: Failed to download http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/firmware-ma_1.135-master_all.ipk: HTTP response code said error.
 * opkg_install_pkg: Failed to download firmware-ma. Perhaps you need to run 'opkg update'?
 * opkg_download: Failed to download http://feed.hae.orig/feeds/qb2/uni/4.19.10/../../POOL/qt-gui_1.8697-master_qb2.ipk: HTTP response code said error.
 * opkg_install_pkg: Failed to download qt-gui. Perhaps you need to run 'opkg update'?
 * opkg_download_pkg: Package base-qb2-ene is not available from any configured src.
 * opkg_install_pkg: Failed to download base-qb2-ene. Perhaps you need to run 'opkg update'?
> Exit code: 255
>> 2018-12-14 13:35:47 +0000 (pid 2299) prepare-error-opkg-download-download 'opkg failed to download'
The Toon shows at my display software 4.9.23....
Posted: Fri Dec 14, 2018 4:39 pm
by mAiden
@TheHogNL,
Will it help if he runs opkg update? Maybe Toon wil fix himself then, pick up the corrupt package again.
Im not sure about it, therefore the question
Posted: Fri Dec 14, 2018 8:58 pm
by TheHogNL
No don't use opkg update if you don't know what you are doing
Posted: Fri Dec 14, 2018 9:01 pm
by TheHogNL
Stephan296 wrote:I had update earlier with the same script to that version, but after that i pussed by mistake at my Toon the update button (sorry) and after that i cant access by ssh anymore.
Send me a PM to help you using teamviewer. Send me your whatsapp 06-number in that PM.
Posted: Sun Dec 16, 2018 3:34 pm
by alcomys
When try to use the update script i got this as output on toon.
what is wrong ?
(first try) eneco-xxx-xxxxxx:~# ./update-rooted.sh -f
sh: ./update-rooted.sh: not found
(second try) eneco-xxx-xxxxxx:~# sh update-rooted.sh -f
sh: can't open 'update-rooted.sh'
thanks
