I can't download the file from: http://files.domoticaforum.eu/uploads/T ... uImage-nfs[/b]
Because the server gives acces from only known extensions, could you put .txt after it or .zip.
Gonna give it a go after I can download the kernel
U-Boot> tftpboot 0xA1000000 toon/uImage-nfs
Using FEC device
TFTP from server 192.168.5.199; our IP address is 192.168.5.198
Filename 'toon/uImage-nfs'.
Load address: 0xa1000000
Loading: #################################################################
done
Bytes transferred = 2510541 (264ecd hex)
U-Boot> bootm
## Booting kernel from Legacy Image at a1000000 ...
Image Name: Linux-2.6.36-R07-h21
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2503348 Bytes = 2.4 MiB
Load Address: a0008000
Entry Point: a0008000
Verifying Checksum ... Bad Data CRC
ERROR: can't get kernel image!
U-Boot>
dhcp
setenv serverip 192.168.5.199
setenv autoload no
setenv bootfile toon/uImage-nfs
setenv bootargs console=${console},${baudrate} rootwait root=/dev/nfs nfsroot=192.168.5.199:/srv/tftpboot/toon/rootfs,v3,tcp,nolock rw ip=dhcp
run bootargs; nand read ${loadaddr} kernel; bootm ${loadaddr}
/srv/tftpboot/toon/rootfs *(rw,sync,no_root_squash,no_subtree_check)
/srv/tftpboot/toon *(rw,sync,no_root_squash,no_subtree_check)
Well the booting went fine, but now little bit stuck on the attaching of ubi.marcelr wrote:So it's working now?
U-Boot>
BOOTP broadcast 1
DHCP client bound to address 192.168.5.198
U-Boot> setenv serverip 192.168.5.199
U-Boot> tftpboot 0xa1000000 toon/uImage-nfs
Using FEC device
Loading: *#################################################################
done
U-Boot> setenv bootargs ubi.mtd=4
U-Boot> setenv bootargs ${bootargs} root=/dev/nfs rw nfsroot=192.168.5.199:/srv/tftpboot/toon/rootfs,v3,nolock,tcp console=ttymxc0,115200 loglevel=8
U-Boot> setenv bootargs ${bootargs} mtdparts=mxc_nand:512K@0x00100000(u-boot-env)ro,1536K(splash-image),3M(kernel),3M(kernel-backup),119M(rootfs)
U-Boot> setenv bootargs ${bootargs} ip=192.168.5.198:192.168.5.199:192.168.5.199:255.255.255.0:toon::off
U-Boot> nand read ${loadaddr} kernel
NAND read: device 0 offset 0x300000, size 0x300000
3145728 bytes read: OK
U-Boot> bootm
Image Name: Linux-2.6.36-R10-h27
Data Size: 1944336 Bytes = 1.9 MiB
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.36-R10-h27 (jbraam@dvl) (gcc version 4.5.3 20110223 (prerelease) (GCC) ) #1 PREEMPT Tue Oct 25 20:03:05 CEST 2016
CPU: ARM926EJ-S [xxxxxxx] revision 4 (ARMv5TEJ), cr=xxxxxxxxxx
CPU: VIVT data cache, VIVT instruction cache
Machine: Prodrive B.V ED2.0
Memory policy: ECC disabled, Data cache writeback
On node 0 totalpages: 32768
free_area_init_node: node 0, pgdat c03a119c, node_mem_map c03c5000
Normal zone: 256 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 32512 pages, LIFO batch:7
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Kernel command line: ubi.mtd=4 root=/dev/nfs rw nfsroot=192.168.5.199:/srv/tftpboot/toon/rootfs,v3,nolock,tcp console=ttymxc0,115200 loglevel=8 mtdparts=mxc_nand:512K@0x00100000(u-boot-env)ro,1536K(splash-image),3M(kernel),3M(kernel-backup),119M(rootfs) ip=192.168.5.198:192.168.5.199:192.168.5.199:255.255.255.0:toon::off
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 126092k/126092k available, 4980k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffa00000 - 0xffe00000 ( 4 MB)
vmalloc : 0xc8800000 - 0xf4000000 ( 696 MB)
lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.init : 0xc0008000 - 0xc0022000 ( 104 kB)
.text : 0xc0022000 - 0xc0367000 (3348 kB)
.data : 0xc037e000 - 0xc03a17a0 ( 142 kB)
Hierarchical RCU implementation.
RCU-based detection of stalled CPUs is disabled.
Verbose stalled-CPUs detection is disabled.
NR_IRQS:272
MXC IRQ initialized
MXC GPIO hardware
Console: colour dummy device 80x30
Calibrating delay loop (skipped) preset value.. 199.88 BogoMIPS (lpj=999424)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
Configured for LCD: TM070RDH11
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Switching to clocksource mxc_timer1
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
msgmni has been set to 246
io scheduler noop registered (default)
imx-fb imx-fb.0: PreserveUBootFramebuffer(1): xres=800, yres=480 [skip _update_lcdc]
imx-fb imx-fb.0: PreserveUBootFramebuffer(2): xres=800, yres=480 [skip _update_lcdc]
Console: switching to colour frame buffer device 100x30
imx-fb imx-fb.0: fb0: DISP0 BG fb device registered successfully.
imx-fb imx-fb.0: PreserveUBootFramebuffer(3): xres=800, yres=480 [skip _update_lcdc]
imx-fb imx-fb.0: fb1: DISP0 FG fb device registered successfully.
Serial: IMX driver
imx-uart.0: ttymxc0 at MMIO 0x1000a000 (irq = 20) is a IMX
console [ttymxc0] enabled
imx-uart.1: ttymxc1 at MMIO 0x1000b000 (irq = 19) is a IMX
imx-uart.2: ttymxc2 at MMIO 0x1000c000 (irq = 18) is a IMX
NAND device: K9F1G08U0E detected, disabling sub-page writes
NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit)
Scanning device for bad blocks
RedBoot partition parsing not available
5 cmdlinepart partitions found on MTD device mxc_nand
Creating 5 MTD partitions on "mxc_nand":
0x000000100000-0x000000180000 : "u-boot-env"
0x000000180000-0x000000300000 : "splash-image"
0x000000300000-0x000000600000 : "kernel"
0x000000600000-0x000000900000 : "kernel-backup"
0x000000900000-0x000008000000 : "rootfs"
UBI: attaching mtd4 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: max. sequence number: 243713
UBI: attached mtd4 to ubi0
UBI: MTD device name: "rootfs"
UBI: MTD device size: 119 MiB
UBI: number of good PEBs: 952
UBI: number of bad PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 952
UBI: number of PEBs reserved for bad PEB handling: 9
UBI: max/mean erase counter: 687/255
UBI: image sequence number: 64857957
UBI: background thread "ubi_bgt0d" started, PID 309
at25 spi0.0: 32 KByte at25640B eeprom, pagesize 64
spi_imx spi_imx.0: probed
FEC Ethernet Driver
fec_enet_mii_bus: probed
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
mxc-ehci mxc-ehci.0: initializing i.MX USB Controller
mxc-ehci mxc-ehci.0: portsc setup 1: 0x80000000
mxc-ehci mxc-ehci.0: Work around for USB enabled
ULPI transceiver vendor/product ID 0x0424/0x000d
mxc-ehci mxc-ehci.0: Freescale On-Chip EHCI Host Controller
mxc-ehci mxc-ehci.0: new USB bus registered, assigned bus number 1
mxc-ehci mxc-ehci.0: irq 56, io mem 0x10024000
mxc-ehci mxc-ehci.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: Freescale On-Chip EHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.36-R10-h27 ehci_hcd
usb usb1: SerialNumber: mxc-ehci.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mxc-ehci mxc-ehci.2: initializing i.MX USB Controller
mxc-ehci mxc-ehci.2: portsc setup 1: 0x80000000
mxc-ehci mxc-ehci.2: Work around for USB enabled
mxc-ehci mxc-ehci.2: Freescale On-Chip EHCI Host Controller
mxc-ehci mxc-ehci.2: new USB bus registered, assigned bus number 2
mxc-ehci mxc-ehci.2: irq 55, io mem 0x10024400
mxc-ehci mxc-ehci.2: USB 2.0 started, EHCI 1.00
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: Freescale On-Chip EHCI Host Controller
usb usb2: Manufacturer: Linux 2.6.36-R10-h27 ehci_hcd
usb usb2: SerialNumber: mxc-ehci.2
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
input: TSC2007 Touchscreen as /devices/virtual/input/input0
rtc-isl1208 1-006f: chip found, driver version 0.3
rtc-isl1208: dev (254:0)
rtc-isl1208 1-006f: rtc core: registered rtc-isl1208 as rtc0
i2c /dev entries driver
tmp431 0-004c: Could not read configuration register (-5)
imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
Registered led device: led0
Registered led device: led1
adt7410 0-0048: adt7410 temperature sensor registered.
adt7410 0-0049: adt7410 temperature sensor registered.
nf_conntrack version 0.5.0 (1970 buckets, 7880 max)
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 17
Bridge firewalling registered
rtc-isl1208 1-006f: setting system clock to 2018-02-26 20:18:00 UTC (1519676280)
usb 2-1: new high speed USB device using mxc-ehci and address 2
usb 2-1: New USB device found, idVendor=148f, idProduct=5370
usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 2-1: Product: 802.11 n WLAN
usb 2-1: Manufacturer: Ralink
usb 2-1: SerialNumber: 1.0
eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=1:10, irq=-1)
IP-Config: Complete:
device=eth0, addr=192.168.5.198, mask=255.255.255.0, gw=192.168.5.199,
host=toon, domain=, nis-domain=(none),
bootserver=192.168.5.199, rootserver=192.168.5.199, rootpath=
Looking up port of RPC 100003/3 on 192.168.5.199
PHY: 1:10 - Link is Up - 100/Full
Looking up port of RPC 100005/3 on 192.168.5.199
VFS: Mounted root (nfs filesystem) on device 0:13.
Freeing init memory: 104K
/bin/sh: can't access tty; job control turned off
/ # ubiattach -p /dev/mtd4 -O 2048
ubiattach: error!: UBI is not present in the system
printenv
Using FEC device
done
U-Boot> bootm
U-Boot>
Using FEC device
done
Bytes transferred = 2503412 (2632f4 hex)
U-Boot> bootm
OK
Starting kernel ...
Linux version 2.6.36-R07-h21 (marcelr@laptop46.wfw.wtb.tue.nl) (gcc version 4.5.3 20110223 (prerelease) (GCC) ) #1 PREEMPT Wed Feb 24 19:02:12 CET 2016
CPU: ARM926EJ-S [41069264] revision 4 (ARMv5TEJ), cr=00053177
free_area_init_node: node 0, pgdat c04b2a14, node_mem_map c04da000
Memory: 124984k/124984k available, 6088k reserved, 0K highmem
.init : 0xc0008000 - 0xc0025000 ( 116 kB)
.text : 0xc0025000 - 0xc044d000 (4256 kB)
.data : 0xc046a000 - 0xc04b3020 ( 293 kB)
NR_IRQS:272
MXC IRQ initialized
MXC GPIO hardware
Calibrating delay loop... 199.88 BogoMIPS (lpj=999424)
cfg80211: Calling CRDA to update world regulatory domain
TCP reno registered
msgmni has been set to 244
Serial: IMX driver
UBI: logical eraseblock size: 129024 bytes
UBI: sub-page size: 512
UBI: VID header offset: 512 (aligned 512)
UBI: data offset: 2048
UBI error: validate_ec_hdr: bad VID header offset 2048, expected 512
UBI error: validate_ec_hdr: bad EC header
UBI error: ubi_io_read_ec_hdr: validation failed for PEB 0
UBI error: ubi_init: cannot attach mtd4
dhcp
setenv bootargs ubi.mtd=4,2048
bootm
mount -a
cat /proc/devices | grep ubi0
mknod /dev/ubi0 c 252 0
mkdir /mnt/rootfs
mount -t ubifs ubi0:rootfs /mnt/rootfs
chmod +x /mnt/rootfs/bin/busybox
chroot /mnt/rootfs
