Toon app: DomoticzBoard
justsomeguy
Re: Toon app: DomoticzBoard
Post by justsomeguy »
I am trying to install DomoticzBoard (from Github, but it is not visible. I have followed the hints on the other forum topic "custom apps on fw 5.0.4" but it didn't help. Is there anything else I should do? To be clear, the apps should be visible on the 'add tile' page, right?
Thanks!
Note that from 4.22 onwards or so the filenames need to comply to certain rules : viewtopic.php?f=103&t=12303#p89271
If that's ok it can be that the app contains errors or is not made compatible with recent firmwares.
E.g. If it is written for firmwares 3.x or 4.x it will not work on firmware 5 by default
justsomeguy
But the code from DomoticzBoard is in 5.0.4 format? If not, can somebody give me DomoticzBoard in 5.0.4. format?
justsomeguy wrote:But the code from DomoticzBoard is in 5.0.4 format? If not, can somebody give me DomoticzBoard in 5.0.4. format?
you can run this script in 5.0.4 to convert older apps. Note that images are now taking from the resource files and not from the drawables folder anymore.
for i in `find /qmf/qml/apps -name "*.qml"`
do
 sed -i 's/QtQuick 1/QtQuick 2/' $i		#change to QtQuick 2.1
 sed -i '/import Effects 1.0/d' $i		#remove effects module - can break the qml if it uses it
 sed -i 's/"\.\/drawables/"qrc:\/tsc/' $i	#change images location ./drawables/ to qrc:/
 sed -i 's/"drawables/"qrc:\/tsc/' $i		#change images location drawables/ to qrc:/
done
and restart the gui...
if it still doesn't show up you will need to check the console output
Blacky's Boss
Post by Blacky's Boss »
@TerrorSource: Is there any possibility to make DomoticzBoard 5.0.4-proof and maybe available in ToonStore?
This is the only reason for me to not update Toon.... I love Domoticzboard in all it's simplicity!!
TerrorSource
Post by TerrorSource »
Blacky's Boss wrote:@TerrorSource: Is there any possibility to make DomoticzBoard 5.0.4-proof and maybe available in ToonStore?
Well, i created this app as a "quick&dirty" copy-paste app once, didnt thought that so many users are using it :roll:
The code needs to be rebuild from scratch, not just images/lay-out. that's a nice2have while the code is a must.
I have an idea on how it should be but i lack the knowledge to do it and spare in time to learn it.
Blacky's Boss
TerrorSource wrote:i created this app as a "quick&dirty" copy-paste app once
I know :mrgreen: , but it's kind of brilliant, just because of that :mrgreen: :mrgreen:
Maybe Toonz can help out? :roll:
TerrorSource
Guys, i'm working on an "official" ToonStore release together with Toonz.
1 annoying bug left between the current state and the ToonStore release.
Downloading DomoticzBoard from my github is however NOT supported.
Github is for me to track changes in files, have others see the code and let them place PR's if they want to so the code can be improved.
Please hold on untill an "official" ToonStore release :D
hansgrave
Post by hansgrave »
Good News! I really miss DomoticzBoard since firmware v5...
Homey, rooted Toon 1 and HomeAssistent.
Blacky's Boss
I see my earlier post has been deleted. I'm sorry. I Just wanted to say thanks for doing this. Much appreciated!
I did that. It's not a dating site ;-)
TerrorSource
Version 1.0.0 of DomoticzBoard was released in the Toonstore a few minutes ago.
Changes since the last version are a lot, here's a sum-up:
- configurable ip/poort/switches
- maximum 5 switches, if you set idx value at "0" it will no longer show a unused button.
- scene1-5 is automatically retreived from Domoticz, only the used one's are shown
- a lot of code was removed
Please refresh the ToonStore and give it a try. There are a few things we have in mind to improve it but that's for long-term. It's working now, that's all that matters :D
hansgrave
Post by hansgrave »
Nice work, thanx for your effort.
I installed the app, filld in the IP, port and idx but it did't work. I can see 5 grey buttons wihthout text.
Greetz Hans
Blacky's Boss
Mine works! This is Nice!
TerrorSource
hansgrave wrote:Nice work, thanx for your effort.
Greetz Hans
Do you have username/password set up in Domoticz?
The app will check the status/name of each idx/scene every 10 secondes so that can be the case too.
