Page 4 of 6
Re: OTGW and Orange Pi Zero one device.
Posted: Tue Sep 11, 2018 3:31 am
by cyril
Hi, Annope! It's very strange behavior. Can you show otmonitor log file? Also is there errors in otmonitor?
Posted: Tue Sep 11, 2018 9:03 am
by anoppe
Let me turn on logging again and I'll get back in a few hours so the logs contain some data. (I disabled it to increase my sd-cards lifespan
Posted: Tue Sep 11, 2018 1:45 pm
by anoppe
@Cyril I've attached the logfile. AS you can see the OTmonitor receives the wrong values from the boiler...:
09:36:30.035412 T10181473 Write-Data Room temperature: 20.45
09:36:30.184469 BD0181473 Write-Ack Room temperature: 20.45
09:37:10.297974 T1018011E Write-Data Room temperature: 1.12
09:37:10.389887 BD018011E Write-Ack Room temperature: 1.12
09:37:51.517397 T901802AE Write-Data Room temperature: 2.68
09:37:51.675247 B501802AE Write-Ack Room temperature: 2.68
09:38:31.781551 T9018030A Write-Data Room temperature: 3.04
09:38:31.874404 B5018030A Write-Ack Room temperature: 3.04
09:39:12.049757 T10180400 Write-Data Room temperature: 4.00
09:39:12.151855 BD0180400 Write-Ack Room temperature: 4.00
09:39:52.310061 T1018147A Write-Data Room temperature: 20.48
09:39:52.457198 BD018147A Write-Ack Room temperature: 20.48
Posted: Wed Sep 12, 2018 11:48 am
by cyril
Hi! It looks like OTGW receives this values from thermostat. Try to change mode of the otmonitor to monitor mode, so OTGW will no affects to transmisson between thermostat and boiler.
Posted: Wed Sep 12, 2018 2:11 pm
by anoppe
Thanks, I've applied your suggestion. Let me see what happens...
Posted: Wed Sep 12, 2018 8:59 pm
by cyril
Overall, I presume, even if you try to turn back to original OTGW board, you cannot solve your issue. Obviously, this problem occurs after you install new thermostat, so... source of the problem - new thermostat. If you turn to ''Thermostat compatibility'' topic of this forum, you can see that all thermostat working differently and you cannot change this situation without changing OTGW firmware. I cannot help with it, because it require very deep knowing of programming.
Posted: Thu Sep 13, 2018 11:29 am
by anoppe
Hey Cyril,
Thank you for your clear and honest answer.
Btw: The adjustment you suggested earlier didn't fix the behaviour.
Posted: Sun Sep 16, 2018 11:09 am
by bruce_miranda
Does anyone know what happens to the OT link if the Orange Pi is powered off or hangs. Is there a path through the circuit on the OTGW board to allow the OT messages to go through?
I am concerned about putting a device in between my heating system that ultimately relies on an SD Card, and all the joy that brings with it.
Posted: Mon Sep 17, 2018 1:10 pm
by anoppe
@bruce_miranda: I've had sd-card issues with my device, however: I discovered that the heatingsystem and its original thermostat keeps functioning fine, als long as the OPI has power...
Posted: Tue Sep 18, 2018 9:13 am
by bruce_miranda
I can see how there is very little dependency on the OPI, because it simply acting as the serial port monitor for the OTGW board, which is running it's own PIC. But I guess I will need to think about how I monitor the power of the OPI itself.
Is there a way to run this board in a pure sniffer/monitor mode. So rather than sat in the middle of the OT bus, it is simply listening?
Posted: Wed Sep 19, 2018 7:24 am
by cyril
Nor this board nor original OTGW cannot working this way.
Posted: Wed Sep 19, 2018 9:39 am
by hvxl
Because the Opentherm protocol uses current levels for the communication from boiler to thermostat, it is not possible to just attach to the bus and monitor it. A monitoring device has to sit in the OT bus. However, in monitor mode the OTGW passes on the signals in both directions completely in hardware. This is not affected by bugs in the firmware. As long as the OTGW has power and is set to monitor mode, it is as close to a pure sniffer as you can get.
Posted: Mon Oct 08, 2018 4:28 pm
by paulockenden
I could have SWORN I previously had Cyril's board talking to Domoticz, but now I'm getting errors:
2018-10-08 15:22:42.002 Status: OTGW: HTTP/1.1 500 Internal Server Error
2018-10-08 15:22:42.002 Status: OTGW: Content-Type: text/plain;charset=utf-8
2018-10-08 15:22:42.002 Status: OTGW: Content-Length: 428
2018-10-08 15:22:42.002 Status: OTGW: Connection: close
2018-10-08 15:22:42.002 Status: OTGW: *** INTERNAL SERVER ERROR (BEGIN #105) ***
2018-10-08 15:22:42.002 Status: OTGW: port: 8080
2018-10-08 15:22:42.002 Status: OTGW: socket: sock11bc0b8
2018-10-08 15:22:42.002 Status: OTGW: peerhost: 192.168.xx.xx
2018-10-08 15:22:42.002 Status: OTGW: peerport: 44836
2018-10-08 15:22:42.002 Status: OTGW: rawtime: 1539008561
2018-10-08 15:22:42.002 Status: OTGW: time: Mon Oct 08 14:22:41 UTC 2018
2018-10-08 15:22:42.002 Status: OTGW: errorinfo: can't read "uri": no such variable
2018-10-08 15:22:42.002 Status: OTGW: while executing
2018-10-08 15:22:42.002 Status: OTGW: "regexp {^([^?]*)(\?.*)?$} $uri _ path query"
2018-10-08 15:22:42.002 Status: OTGW: (procedure "getrequest" line 7)
2018-10-08 15:22:42.002 Status: OTGW: invoked from within
2018-10-08 15:22:42.002 Status: OTGW: "getrequest $port $socket $peerhost $peerport"
2018-10-08 15:22:42.002 Status: OTGW: *** INTERNAL SERVER ERROR (END #105) ***
2018-10-08 15:22:42.002 Status: OTGW: Connection reset!
I'm probably doing something stupid. Anyone got more of a clue that me?
Within Domoticz I've simply used the IP address of the Orange Pi Zero, and port 8080.
I could swear I had this all working a couple of weeks ago.
Ta.
P.
Posted: Mon Oct 08, 2018 8:15 pm
by paulockenden
Don't worry - sussed it - I was being a muppet!
Posted: Tue Oct 09, 2018 9:58 am
by bruce_miranda
So what was it? How are you connecting Domoticz to this?
