Page 4 of 4
Stealth product sheet.
Posted: Sun Oct 18, 2009 9:15 pm
by j.hoekstra
Keeping the Stealth next to a circle I doubt that they use the same print, the Stealth print seems to be bigger. I'm not gonna open one up just for kicks.
I'm using a stealth in my Bathroom now, built in a watertight box to power my washingmachine, it switches on in the morning before the low tarif ends to do the laundry.
Posted: Mon Oct 26, 2009 10:36 pm
by daromer
The first thing i did was to open one up to inspect. They look the same and are the same on the milimeter. Only differense is that it got a longer board to hold the "jacket" dont know the word.
So its kinda easy to modify a circle to be the same as a stealth. Just ordered another 10 circle that all will me modified.
Posted: Tue Oct 27, 2009 12:18 am
by Cariba
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by daromer</i>
<br />The first thing i did was to open one up to inspect. They look the same and are the same on the milimeter. Only differense is that it got a longer board to hold the "jacket" dont know the word.
Can you post a picture of that? How will you connect to the board when you're missing the jacks?
Posted: Tue Oct 27, 2009 1:43 pm
by daromer
I just make some new brackets to hold the cables. will test to do one when i get the other ones.
http://luno.mine.nu/bild.jpg
Sorry for the lousy picture. took it with my cellphone.
But as you can see they are almost the same except for the shape of the mainboard.
I will put up more when i looked over them more.
Edit: But i must state that it aint legal to do this and install it afterwards. It is only approved as it is!.
Posted: Tue Nov 03, 2009 11:23 pm
by chrisvdbeek
Wow. That's interesting! Do you have more pics?
I am using 1 stealth by the way, but cannot connect it to the source. Does someone else have these problems?
Chris
Posted: Thu Nov 05, 2009 3:07 pm
by daromer
I use 1 stealth connected without problem. I first connect them in a virtualized environment then i use POL.py to read them.
Will get back with more pictures later on.
(I also work on a project like plugwise, though with some other functionalities.)
Re: Stealth product sheet.
Posted: Thu Jan 07, 2010 12:54 am
by agerritsen
Posted: Thu Jan 07, 2010 1:20 am
by Rene
Looks good!
Posted: Fri Jan 08, 2010 12:40 am
by YogiBear75
I'm interested. But I want to know about the price first ofcourse ?
Yogi
Resetting Stealth
Posted: Wed Jan 27, 2010 12:57 pm
by wusel
I'm pondering about putting some Stealth' behind the fuses into my fuse box to get whole circuit consumption (kitchen, basement, garden, washing machine/dryer in the basement). Unfortunately, from what information is available, Stealth still seems to lack a reset button -- switching a whole circuit there times off-on to reset a Stealth doesn't sound comforting neither does having an electrician to do this by rewiring. Does anyone here know if "The Stealth’s functions and specifications are identical to those of the Circle" extend to it's resetting procedure?
-kai
