Page 4 of 4
Re: New Source 2.22 version available for beta users.
Posted: Fri Jun 15, 2012 9:22 pm
Ok thought so :)
I reported this bug several time to Plugwise, but still in there!
Posted: Sun Jun 17, 2012 9:51 pm
by PietjeNL
Problem is with the driver, not with the source.
Basically if u download the driver from ftdi site it has some problems now and then.
U need to remove all ftdi drivers with the program ftdi has on there site, and then install the source again with the drivers that come with it.
Or just use /comport=com<number>
Had the same problem here, fixed it by removing all drivers like above.
Posted: Mon Jun 18, 2012 8:36 pm
did not work for me, i always used Plugiwse drivers?
Posted: Mon Jun 18, 2012 8:44 pm
by Rene
Last night the source couldn't find the stick again, while it was started using the /comport parameter. I restarted the Source to no avail. Once I disconnected the stick and connected it again, the Source could find the stick again. I never had these kind of problems until the last beta.
Posted: Mon Jun 18, 2012 10:23 pm
by labium
if i see al this driver problems i cant understanad why a request from me to plugwise to sell a serial port version of the stick is bounced with the remark , "it is a lot of extra testing"'.
How simpler how better , its is not only the first law in finance but also in computing.
Posted: Thu Jun 21, 2012 8:43 pm
by Juande
Hi All
I upgraded to version Beta 2.22 20120620 and since then the standalone web server is no longer working. I'm receiving constantly an error:Failed to listen on prefix 'http://*:8080/' because it conflicts with an existing registration on the machine.
There is no other service than plugwise listening on port 8080.
However if I run Source instead, webserver works
Any idea?
Thx
Posted: Fri Jun 22, 2012 3:35 am
by Scazy
Well try Fixio Driver Finder. This program can identify which driver your system needs and it would download it.
