Toon app: Afvalwijzer
Smiggel
Re: Toon app: Afvalwijzer
Post by Smiggel »
Toonz wrote:Thanks for the pm. The app is working fine but your waste provider started to use new waste descriptions.
First they put a space after :'gft' and secondly they started using 'pbd' instead of 'pmd'.
You can easily fix this yourself by adding the following two lines to the function wasteTypeMijnafvalwijzer(shortName) in /qmf/qml/apps/wastecollection/WastecollectionApp.qml:
                        case "gft ": return 3;
                        case "pbd": return 2;
Will include this in a future release but none planned for now.
after saving the changes and restarting the gui you need to go to the settings page and press 'opslaan' to refresh the file (or wait till the next refresh)
Regardz,
Ah check. Will update the app later. Thanks for checking it out!
Updated the script, and it works now! :) Thanks for the help!
MyZ
Post by MyZ »
First of all, great app! Thumbs up.
Installed a week ago. Got everything working with manual dates in text file. The only thing not working is the icon in dim state. For example tomorrow is a "paper waste day", but no icon is appearing on the dim screen.
Running the latest stable version of Toon. Any ideas?
MyZ wrote:First of all, great app! Thumbs up.
Hmmm, normally the waste icon will only show up after 18:00 the day before (or at another hour of you have a different setting for that in the config screen).
Did you use the standard values for the waste types (0 through 9)? If not, you need to create your own waste icons as well.
MyZ
Post by MyZ »
I'm using the standard codes 0-4, and is working. Did set the time at "17". Is it possible that it is interfering with other apps?
mAiden
Post by mAiden »
@rickvnl
For Twente Milieu you can generate a ical file maybe with this one
https://github.com/Timendus/afvalkalender
Test it on my own Toon, its work here.
hdok
Post by hdok »
For gemeente Venlo one can generate an ical using the following link:
https://www.venlo.nl/trash-removal-cale ... ode/number
Would really appreciate if this one can be added..
Will add both.... (second half of August)
Rudolf
Post by Rudolf »
I'm trying to use extra dates / custom icons with this app but it's not working; could you please take a look at my config and point out what's wrong.
Obviously I'm missing something...
eneco-001-037311:~# cd /qmf/qml/apps/wastecollection
eneco-001-037311:/qmf/qml/apps/wastecollection-3.6# ls -l
-rw-r--r--    1 root     root          5417 Mar 27 18:26 Changelog.txt
-rw-r--r--    1 root     root          1797 Mar 27 18:26 EditTextLabel4421.qml
-rw-r--r--    1 root     root         49816 Mar 27 18:26 WastecollectionApp.qml
-rw-r--r--    1 root     root         17513 Mar 27 18:26 WastecollectionConfigurationScreen.qml
-rw-r--r--    1 root     root          1179 Mar 27 18:26 WastecollectionListDatesScreen.qml
-rw-r--r--    1 root     root          5075 Mar 27 18:26 WastecollectionTile.qml
drwxrwxr-x    2 root     root          1424 Aug  9 10:45 drawables
drwxrwxr-x    2 root     root           304 Mar 29 05:32 lang
-rw-r--r--    1 root     root           126 Mar 27 18:26 qmldir
-rw-r--r--    1 root     root           209 Aug 10 11:01 userSettings.json
-rw-r--r--    1 root     root             3 Mar 27 18:26 version.txt
-rw-r--r--    1 root     root           229 Mar 27 18:26 wastecollection.js
eneco-001-037311:/qmf/qml/apps/wastecollection-3.6# cat userSettings.json
{"Afvalverwerker":"1","Postcode":"xxxxxx","Huisnummer":"xx","Straatnummer":"0","ICSnummer":"0","DisplayIconVanafUur":18,"ExtraDatumsFile":"file:///root/waste.txt","ExtraDatumsIconsFolder":"file:///root/icons/"}
eneco-001-037311:/qmf/qml/apps/wastecollection-3.6# vi userSettings.json
eneco-001-037311:/qmf/qml/apps/wastecollection-3.6# cat /root/waste.txt
2018-08-11,A
2018-01-12,A
2018-01-13,A
2018-01-15,A
2018-01-26,C
2018-01-28,A
2018-02-03,A
2018-02-05,A
2018-03-22,A
2018-04-06,A
2018-04-14,A
2018-04-24,A
2018-04-26,A
2018-04-28,A
2018-05-13,D
2018-06-20,A
2018-06-27,C
2018-07-27,A
2018-09-19,A
2018-09-30,C
2018-10-13,A
2018-10-23,A
2018-10-28,C
2018-12-05,A
2018-12-08,A
2018-12-22,A
eneco-001-037311:/qmf/qml/apps/wastecollection-3.6# ls -l /root/icons/
-rw-r--r--    1 root     root          8227 Aug  9 10:16 A.png
-rw-r--r--    1 root     root          5850 Aug  9 10:16 B.png
-rw-r--r--    1 root     root          8693 Aug  9 10:16 C.png
-rw-r--r--    1 root     root          7355 Aug  9 10:16 D.png
-rw-r--r--    1 root     root          7492 Aug  9 10:16 Metal.png
-rw-r--r--    1 root     root            73 Aug  9 10:48 iconLabels.txt
eneco-001-037311:/qmf/qml/apps/wastecollection-3.6# cat /root/icons/iconLabels.txt
{ "A": "Verjaardag", "B": "Afspraak", "C": "Trouwdag", "D": "Trouwdag" }
Looks fine at first sight. Question: do you actually use waste provider 1, and just put 'x''s for your zipcode/housenr to hide your address?
If you don't use waste provider 1 (mijnafvalwijzer.nl) you should select waste provider 0 (zero).
Will test with your data as well next week
Rudolf
Post by Rudolf »
Address hidden on purpose; provider 1 works fine for me.
If I point extraDates-file to a non-existing file it shows proper dates; if I point to the actual file nothing is shown.
madpatrick
Post by madpatrick »
Hi Toonz,
I've upgraded the app from 3.6 to 4.3 and i noticed that the iconlabels are not working any more.
I'm not seeing the text in the screen, but only a " - "
This is my content of iconlabels.txt
{"A": "Verjaardag", "B": "Trouwdag"}
mAiden
Post by mAiden »
madpatrick wrote:Hi Toonz,
Its the path to custom icons correct?
madpatrick
mAiden wrote: Its the path to custom icons correct?
The path was not adjusted and still good.
Somehow today the text was displayed again after a restart of Toon (had already done a restart yesterday)
Gleno0hh
Post by Gleno0hh »
Got the same problem. Not fixed after a couple of reboots. Waste is displayed fine, custom dates arn't.
I will for sure look into the issues reported here with the custom dates/labels and probably change the logic of the app to make it more robust.
One other thing to mention: the app will only start collecting data 5 minutes after the Toon gui (more specifically, the waste collection app) has started.
This has been done on purpose to not delay the lengthy startup process of the gui itself.
Unfortunately, I have to take care of some unexpected private stuff after returning from leave.
Then my first priority is creating the new resources files for 4.18.
After that I will focus on the wastecollection app.
Kind regardz,
