Page 34 of 44
Posted: Mon Jun 03, 2019 9:44 am
by mAiden
hansgrave wrote:Last week i run the update script on two Toons: once from the second last firmware and once from firmware 4.16.8.
The update from the second last firmware went smooth but by the update from firmware 4.16.8 the proces hang at some point.
Following the instructions from mAiden did the job to get a working Toon back, thanx.
No problem. Fine that my instructions help you
Posted: Mon Jun 03, 2019 8:38 pm
by Ojp
Hi everyone,
Today I updated the Boxx from 4.13.6 to 4.22.7 using the script. It worked as a charm!
I am not sure to upgrade to version 5 or higher. Are some interesting features to take the risk?
Adios.
Posted: Mon Jun 03, 2019 11:43 pm
by TerrorSource
Ojp wrote:Hi everyone,
Today I updated the Boxx from 4.13.6 to 4.22.7 using the script. I worked as a charm!
Adios.
Why not upgrade to the latest firmware? Booting the Toon/Boxx is a bit faster with 5.x.x firmware.
Posted: Tue Jun 04, 2019 9:24 am
by Toonz
TerrorSource wrote:Ojp wrote:Hi everyone,
Adios.
My 2 cents: I read a lot of complaints about delays when taking the Toon out of dim state with firmware 5 on a Toon 1.
I personally prefer 4.x on a Toon 1, feels faster.....booting speed is less relevant for me.
If you have a Toon 2 I would certainly move to version 5 due to better Wifi performance.
Posted: Thu Jun 06, 2019 5:53 pm
by adval40
yesterday i have updated my firmware with the update script
update failed
i saw into the logfile disk full
which files may i delete ?
Posted: Thu Jun 06, 2019 9:52 pm
by TheHogNL
cleanup /mnt/data/update/*
Posted: Thu Jun 06, 2019 9:57 pm
by adval40
this dir is empty
Posted: Fri Jun 07, 2019 6:40 pm
by TheHogNL
Then please check /HCBv2/tmp/opkg-cache
Posted: Fri Jun 07, 2019 7:10 pm
by adval40
I has remove the files in this cache dir i have 30mb free
after reboot he did'nt start up
the display hangs in the boot process
no ssh connection possible
Posted: Fri Jun 07, 2019 7:40 pm
by adval40
I will try make a new connection via serial
Posted: Fri Jun 07, 2019 8:04 pm
by TheHogNL
Removing the files in /HCBv2/tmp/opkg-cache will never hurt your toon. So the reason why ssh isn't working anymore is not because of this.
What was the previous firmware you where on and to which firmware where you updating to?
Posted: Sat Jun 08, 2019 11:40 am
by whizzz63
TheHogNL wrote:Removing the files in /HCBv2/tmp/opkg-cache will never hurt your toon. So the reason why ssh isn't working anymore is not because of this.
I had the same problem. Still trying to repair via a serial connection....
Posted: Sat Jun 08, 2019 2:50 pm
by TheHogNL
whizzz63 wrote:TheHogNL wrote:Removing the files in /HCBv2/tmp/opkg-cache will never hurt your toon. So the reason why ssh isn't working anymore is not because of this.
From which firmware?
Posted: Sat Jun 08, 2019 4:00 pm
by whizzz63
5.5.7
Posted: Sat Jun 08, 2019 4:13 pm
by TheHogNL
That is the to firmware I guess
I mean what was the firmware before you started the update
