Rooting Toon (or boxx)
Re: Rooting Toon (or boxx)
mAiden wrote:Other error i got..
Inittab is fixed, thanks guys!
INIT: Id "qtqt" respawning too fast: disabled for 5 minutes
Looks like the install wasn't completed. You could try to run the update script from TheHogNL again, forcing a reinstall of version 4.18.8.
New resource file is available so should work...
mAiden
Post by mAiden »
Hi Toonz,
This is what i got, when i try it:
2018-07-25 08:38:42 (1.21 MB/s) - `update-rooted.sh' saved [19684/19684]
eneco-001-xxxxxx:~# sh update-rooted.sh -f 4.18.8
Version: 2.94  - ThehogNL - 19-7-2018
Only fixing files.
FIXING: Downloading resources.rcc TSC mod for this version 4.18.8.
FIXING: Now installing latest toonstore app. This fixes some files also.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps//toonstore-1.1.4/toonstore_1.1.4-r0_qb2.ipk.
Package toonstore (1.1.5-r0) installed in root is up to date.
FIXING: Now installing latest busybox mod. This is necessary to enable console output again which is disabled in 4.10 by Eneco.
sh: 4: unknown operand
Custom busybox install not necessary for this firmware.
eneco-001-xxxxxx:~#
Other trys:
eneco-001-xxxx:~# ./update-rooted.sh -f 4.18.8
-sh: ./update-rooted.sh: Permission denied
eneco-001-xxxx:~# chmod -x update-rooted.sh
eneco-001-xxxxx:~#
Post by TheHogNL »
First read what the options are doing: https://github.com/IgorYbema/update-rooted
You are trying -f with a version number. That is invalid. -f is for fixing after an install and doesn't need a version number. You probably mean -v 4.18.8 (force version 4.18.8).
And the permissions denied is because you are now running it as "./update-script.sh" instead of "sh update-script.sh" (and you did make the file executable).
And an empty /etc/inittab .. how did you manage to do that?? It looks you are doing stuff on linux without understanding what you are doing :-)
TerrorSource
Post by TerrorSource »
TheHogNL wrote:First read what the options are doing: https://github.com/IgorYbema/update-rooted
Empty inittab can happen when an upgrade was unsuccessful and you did not check it before rebooting :)
@mAiden, maybe a better idea to improve you're linux skills a bit more before you do anything else on the Toon?
mAiden
Post by mAiden »
I think my Linux skills are ok, with certificate for it.
I got a LPI certificate for it.
Inittab goes empty indeed due to a failed update.
I have fixed already, Toon start up normally. Thank you for the support.
Screenshot Toon:
http://prntscr.com/kasgt1
Ierlandfan
Post by Ierlandfan »
He posted, got support, he solved it and in the end, that's the whole meaning of this board.
Thanx for helping him!
mAiden wrote:I have fixed already, Toon start up normally. Thank you for the support.
Good to hear you're up and running again :) .
As we have heard about a few similar cases before I would like to understand why these updates fail (in this case a genuine firmware update).
Not enough disk space before the update starts? Does the fact that a Toon is rooted is relevant?
Has anyone been able to look into the root cause?
Post by TheHogNL »
mAiden wrote: Inittab goes empty indeed due to a failed update.
Update doesn't do anything with inittab :-)
But nice that it is working now!
Question remains why the inittab file can get empty in some cases....
aabre
Post by aabre »
Toonz wrote:Question remains why the inittab file can get empty in some cases....
maybe mAiden is not very familiar with the vi editor ?
TerrorSource
Maybe true but he isn't the first one with this issue after updating. already seen 3-4 persons before who had exactly the same issue with inittab.
Post by TheHogNL »
It is possible that after (manually) editing the inittab file (to disable openvpn) you forget to 'sync' to the disk and reboot to soon. This will result in a corrupted or empty file.
However this is not part of the upgrade (the upgrade never touches the inittab) and only part of the manually rooting process.
mAiden
Post by mAiden »
I do not like vi, indeed. Use much more often and prefer nano.
That is no excuse. inittab must be empty for a reason. Will view the log files on Saturday or Sunday. Maybe I find something in it.
mAiden
Post by mAiden »
Find this in the update log.
HCBv2 startables changed, writing /etc/inittab.
>> Done, scheduling reboot in 2 secs...
>> 2018-07-23 17:35:37 +0200 (pid 1453) executed
Is almost certain that this has destroyed my inittab.
Post by TheHogNL »
Impossible. This is part of the HCBv2 startup script which is called by the eneco update script just before the script is finished (this is what you see in the log).
The part of the HCBv2 script responsible:
                                printline "startables changed, writing $INITTAB_FILE."
                                echo "$INITTAB_CONTENT_NEW" > $INITTAB_FILE.new
                                # file was created ok? (non-zero size)
                                if [ -s $INITTAB_FILE.new ]
                                then
                                        # force-rename removes old file, still more atomic than direct write
                                        mv -f $INITTAB_FILE.new $INITTAB_FILE
                                        # so repeated calls to it_writeifchanged() work:
                                        INITTAB_CONTENT_ONDISK="$INITTAB_CONTENT_NEW"
                                else
                                        printline "ERROR: Writing $INITTAB_FILE failed! Disk full/read-only?"
                                fi
This has a zero-file-size check in it. If the new created inittab.new file is zero, it will not overwrite the real inittab.
There must be another reason for this to happen.
Return to “Toon Rooting”
