Toon app: DomoticzBoard
Phoolie
Re: Toon app: DomoticzBoard
Post by Phoolie »
I installed it and it works very good :)
I found 2 little problems, the name of switch 4 won't be displayed & the icon/button of switch 5 won't be displayed.
TerrorSource
Post by TerrorSource »
Phoolie wrote:I installed it and it works very good :)
Can you check if it works after rebooting your Toon?
Phoolie
Post by Phoolie »
No, that won't works. I also changed de devices, but the problem stays on switch 4 & 5
TerrorSource
Got the same issue also now. will check asap.
hansgrave
Post by hansgrave »
TerrorSource wrote:
hansgrave wrote:Nice work, thanx for your effort.
I installed the app, filld in the IP, port and idx but it did't work. I can see 5 grey buttons wihthout text.
Greetz Hans
Do you have username/password set up in Domoticz?
The app will check the status/name of each idx/scene every 10 secondes so that can be the case too.
Strange, just check and now it works :D
Also with de issue as discribed by the other users.
Homey, rooted Toon 1 and HomeAssistent.
TerrorSource
Already found the issue of switch4.
Need to look into the issue of switch 5.
New release will be created soon.
EDIT:
Both issues are typo's in the code. Will create a new version asap.
Any other issues or things you guys want to be changed at this moment? (NO feature requests).
Phoolie
Post by Phoolie »
TerrorSource wrote:Already found the issue of switch4.
EDIT:
No, for now it works very good when you've fixed the issues.
For later it would be nice if you could change the dimming state of lights. But that's more a feature than a change :)
EDIT:
On the right side, I have 2 groups & 3 scenes. When I pres the scene the button color change. Is it possible to change that, so it only changes for groups and not for scenes?
fluxdensity
Post by fluxdensity »
Love the program and the fact it is in the ToonStore.
The problem I have and I guess it is on the edge of feature request... is that when a switch is used the app (DomoticzBoard) stays active.
The down side of this is that the screen will not dim after its regular time out.
Regards and thanks
TerrorSource
EDIT:
EDIT:
Correct, you need to use "Groups" in Domoticz. Scene's are a lot harder to state-change via the Domoticz API.
fluxdensity wrote:Hi,
Regards and thanks
You need to close the app after using it. That's with every app as far as i know.
TerrorSource wrote:You need to close the app after using it. That's with every app as far as i know.
This isn't correct. In QT all qml apps are running all the time (loaded at startup)
My Toons go into dim state properly after having used the switches.
Would be interested to see the qt log of fluxdensity after having used the switches.
TerrorSource
version 1.0.1 is in the Toonstore.
fixes switch4 and switch5 typo's
hansgrave
Post by hansgrave »
TerrorSource wrote:version 1.0.1 is in the Toonstore.
Thanx again, this app let rise the WAF for my domotica projects :D
hansgrave wrote:Thanx again, this app let rise the WAF for my domotica projects :D
Teaser: Beware, the WAF will go through the roof with the next version ;-)
hansgrave
Post by hansgrave »
Exciting, can,t wait 8)
TerrorSource
Approved the 1.0.2 update yesterday evening in the ToonStore.
Check it out! :D
