Re: Rooting Toon (or boxx)
Posted: Sat Nov 16, 2019 10:25 pm
Thank you. I got another toon that was root for me. That ssh password I can change with command passwd.
Domotica - Home Automation Forum
https://www.domoticaforum.eu/
That is because some other rooted toons still have the modified busybox on them (http://files.domoticaforum.eu/uploads/T ... r4_qb2.ipk) which contains the passwd command. I never advice to install this busybox as there are situations which it will brick your Toon.Knol010 wrote:Thank you. I got another toon that was root for me. That ssh password I can change with command passwd.
For the Toon1 there is the cron package (you can find it on http://files.domoticaforum.eu/index.php ... on/ipk/qb2 ). Crontab is on a linux system used for timed tasks https://www.computerhope.com/unix/ucrontab.htmelmex wrote:i am trying to figure out how to run a daily job on a rooted toon. I want to restart it everyday at 02:00.
Can someone help me out
Why do you quote that ehoco website? He isn't part of this forum and only copy pastes from uspalermo wrote:Hi,
As you can see I`m new to this forum. Also a Toon user. Currently I have Toon (Not Rooted) on the wall.
I bought one from Marktplaats and was determined to root this one. Ans use this one in a other room. Haven't worked that one out yet.
First have to root the toon. So I have a RBPI 4 connected the JTAG dupont cables according this ehoco.nl/toon-openmaken-en-de-seriele-k ... ansluiten/
So I started up the RBPI and executed the following command : "sudo python . --jtag-available --jtag-hardware rpi3" but I`m receiving an error right away.
INFO:__main__:Starting up...
INFO:__main__:Written private and public key pair to ./id_rsa and ./id_rsa.pub, respectively
CRITICAL:__main__:[Errno 2] could not open port /dev/serial0: [Errno 2] No such file or directory: '/dev/serial0'
The console was connected to my windows computer, so I assumed that the console should be connected to the RBPI rebooted the Pi and try`d again. Still no sigaar.
with lusb the FT232RL is clearly available. Am I missing a step!?
Soo cool.TheHogNL wrote:We fake the connection to the service center. Without that, the toon keeps annoying you that there is no connection to the service center. But rest asure that there is no connection anymore
Maybe the root password is something else than that you think it is. Just hit 'restore password' in the TSC menu. This will reset your root password to be 'toon'.
Yes ofcourse. You can use the 'zon op toon' native app (enable it using the toon subscription feature button in TSC menu). But that requires an additional kWh meter to be installed (just like eneco does). You have the option of a wireless qubino (zwave) kWm meter or analog using the old school led sensor on a small kWh meter or using the S0 port on such a kWm meter. Read in viewtopic.php?f=95&t=11969palermo wrote: Soo cool.happy man tonight Thanks.
Ps, i have solarpanels on the roof, can I see that information asswell ?
palermo wrote:Currently I own Toon with the solar module.
This Toon i rooted was actually for fun. But i can check if this works.
Thanks TheHogNL
Greatly appreciated
I downloaded the zip file from github. in map assets i see u-boot.bin file, which directory do i need? rootToon like the script?That means that u-boot.bin isn't in the current directory from where you have started openocd. Did you download it? You need the u-boot.bin made for the Toon ofcourse. Why not use the toonrooter script?
pi@raspberrypi:~/rootToon $ telnet localhost 4444
Trying ::1...
Trying 127.0.0.1...
Connected to localhost.
Escape character is '^]'.
Open On-Chip Debugger
> soft_reset_halt
requesting target halt and executing a soft reset
target halted in ARM state due to debug-request, current mode: Supervisor
cpsr: 0x800000d3 pc: 0x00000000
MMU: disabled, D-Cache: disabled, I-Cache: disabled
> reset halt
JTAG tap: imx27.etb tap/device found: 0x1b900f0f (mfg: 0x787 (<unknown>), part: 0xb900, ver: 0x1)
JTAG tap: imx27.cpu tap/device found: 0x07926121 (mfg: 0x090 (Chip Express), part: 0x7926, ver: 0x0)
srst pulls trst - can not reset into halted mode. Issuing halt after reset.
cpsr: 0x600000d3 pc: 0xa1f205b0
MMU: disabled, D-Cache: disabled, I-Cache: enabled
NOTE! Severe performance degradation without fast memory access enabled. Type 'help fast'.
> load_image u-boot.bin 0xa1f00000
couldn't open u-boot.bin
I tried the scrip on github but its not working:TheHogNL wrote:Why not going the easy way and use the toonrooter? https://github.com/ToonSoftwareCollective/ToonRooter
root@raspberrypi:/home/pi# sudo apt install python-serial python-cryptography
Pakketlijsten worden ingelezen... Klaar
Boom van vereisten wordt opgebouwd
De statusinformatie wordt gelezen... Klaar
python-cryptography is reeds de nieuwste versie (2.6.1-3+deb10u2).
python-serial is reeds de nieuwste versie (3.4-4).
0 opgewaardeerd, 0 nieuw geïnstalleerd, 0 te verwijderen en 0 niet opgewaardeerd.
root@raspberrypi:/home/pi# git clone https://github.com/martenjacobs/ToonRooter.git
fatal: destination path 'ToonRooter' already exists and is not an empty directory.
root@raspberrypi:/home/pi# cd ToonRooter
root@raspberrypi:/home/pi/ToonRooter# sudo python . --jtag-available
INFO:__main__:Detected JTAG hardware 'rpi3'
