Toon app: DomoticzBoard
Phoolie
Re: Toon app: DomoticzBoard
Post by Phoolie »
TerrorSource wrote:
Approved the 1.0.2 update yesterday evening in the ToonStore.
Check it out! :D
I like it :)
PeJeWe
Post by PeJeWe »
first of all i dont know if this is possible
I have my P1 port of my "slimme meter" connected to domoticz on my raspberry, can we send this data to the Toon and show the data on the screen in the DomoticzBoard app without using the energy adapter from ENECO?
TerrorSource
Post by TerrorSource »
PeJeWe wrote:first of all i dont know if this is possible
Should be possibile but not on wishlist now, so not in the near-future.
jnieuw
Post by jnieuw »
Tried the app, but could not connect. Already added the Toon ip to the "Local Networks (no username/password):" inside Domoticz setup.
Think it has to do with the SSL connection and self-signed certificate. Is it possible to ignore self-signed certificates?
current version is only using http calls (not https).
jnieuw
Post by jnieuw »
Ah, ok. Are there plans to add it to a future version?
Also username and password would be nice...
will put it on the todo list....
TerrorSource
jnieuw wrote:Tried the app, but could not connect. Already added the Toon ip to the "Local Networks (no username/password):" inside Domoticz setup.
Adding the IP address of the Toon to the “no password” settings should work. I don’t know anyone else with a self-signed certificate on Domoticz so I cannot test it out. Did you try removing the self-signed certificate? Does it work then?
witteherder
Post by witteherder »
Is it possible to add an extra switch on the Domoticzboard?
Toon 2 Rooted User
Firmware version: 5.94.7
Raspberry Pi 3B+
Domoticz 2022.1
10 Neo Coolcam PowerPlus
Domotica Beginner (need little help in beginning)
TerrorSource
witteherder wrote:Is it possible to add an extra switch on the Domoticzboard?
It is always possible technically but for what? You can already put 5 in the app.
Toonz and myself are thinking about re-doing the complete app so it retreives the switches from Domoticz without entering IDX's, but that's a long-term project.
PeJeWe
Post by PeJeWe »
Is there a option to show custom sensors like my own weather station, and place them in the dim screen?
TerrorSource
PeJeWe wrote:Is there a option to show custom sensors like my own weather station, and place them in the dim screen?
Same answer as the post before you. yes it is technically possible but not anytime soon.
witteherder
TerrorSource because i have more switches that's why my question ;-)
Toon 2 Rooted User
Raspberry Pi 3B+
Domoticz 2022.1
Hypermobile
Post by Hypermobile »
I used Dashticz..but that not available anymore on 5.13.9 unfortunate.
All Domoticz favourites were automatically visible @ ToonDashticz.
i liked it a lot.
domoticaforum.eu/viewtopic.php?f=99&amp ... 882#p84238
Blacky's Boss
Post by Blacky's Boss »
Three things that bug me:
- Icons for the groups have disappeared. Buttons work, but are grey
- The trayIcon is a bit larger then the others.
- Refresh time after pressing a button is too long.
Can these be fixed? :)
