Toon firmware - update script
jumperone
Post by jumperone »
I have the tone with Version: 2.0 - ThehogNL - 24-3-2018 upgrade from version 2.9.26 upgrade to 4.10.6.
    failled / Bus error.
OPKG Do Not Work / Bus error / orange screen with 2 points
I have looked this up
eneco-001-xxxxxx:~# cat /proc/mtd
dev: size erasesize name
mtd0: 00080000 00020000 "u-boot-env"
mtd1: 00180000 00020000 "splash-image"
mtd2: 00300000 00020000 "kernel"
mtd3: 00300000 00020000 "kernel-backup"
mtd4: 07700000 00020000 "rootfs"
eneco-001-xxxxxx:~# df -h
Filesystem Size Used Available Use% Mounted on
ubi0:rootfs 103.3M 102.9M 420.0K 100% /
tmpfs 61.4M 112.0K 61.3M 0% / var/volatile
I see this in a different Toon
ubi0:rootfs 103.3M 52.8M 50.4M 51%
Also i check the diskusage. full disk
flas:245:respawn:/usr/bin/startflash >/dev/null 2>&1
the line adjusted after
qtqt:245:respawn:/usr/bin/startqt >/dev/null 2>&1
How do I get the disk modified again?.
I have the toon with Version: 2.0 - ThehogNL - 24-3-2018 upgrade from version 2.9.26 upgrade to 4.10.6. Update failled / Bus error
OPKG Do Not Work / Bus error / orange screen with 2 points.
What can I do
Post by TheHogNL »
You need to find why your disk is full. I send you a PM to help you with a teamviewer session if you like
jumperone
Post by jumperone »
TheHogNL wrote:You need to find why your disk is full. I send you a PM to help you with a teamviewer session if you like
Oke. I have windows 7 pro . which team viewer needs to install.What else do I have to do.
What can I do
michel30
Post by michel30 »
I was also checking my size of the Toon, not that it is full but maybe for the future if it needs an cleanup?
Filesystem Type Size Used Available Use% Mounted on
ubi0:rootfs ubifs 103.3M 62.6M 40.7M 61% /
tmpfs tmpfs 61.6M 460.0K 61.2M 1% /var/volatile
/mnt/data/qmf/var/hcb_rrd# 19.1M
/usr/lib/Qt-5.3.1/lib# 27.7M
/squish/lib# 14.3M
has Toon 3 different databases?
Post by TheHogNL »
Just install the newest teamviewer, send me the code and password for teamviewer in a private message and I will remote assist you. However not possible tonight. Maybe saterday morning.
Post by TheHogNL »
I have just put version 2.5 of the script in the first post. This one will resume and the last step if the script fails or gets canceled. Also it will show progress when upgrading. Also some minor fixes.
wbmk
Post by wbmk »
Hi TheHogNL,
Thanx for putting this script together... however it does not work for me. This is the output i recieve when executing:
sh update-rooted-v2.5.sh
Version: 2.5 - ThehogNL - 5-4-2018
Unable to determine your current running version!
DEBUG information:
Detected: 4.11.6
Available: <html>
<head><title>504 Gateway Time-out</title></head>
<body bgcolor="white">
<center><h1>504 Gateway Time-out</h1></center>
<hr><center>nginx/1.10.2</center>
</body>
</html>
base-qb2-uni - 4.11.6-1205-0
END DEBUG information
Can you help me? Thanx in advance
Post by TheHogNL »
Can you try again? Sometime the source where the existing versions is stored is not available resulting in that error.
RDNZL
Post by RDNZL »
I also had the issue above, after a few tries it continues.
I tested v2.5 of the script, but it doesn't seem to help to which version you can upgrade.
I was on 4.8.25 but 4.14.7 is not allowed, it doesn't tell which versions are.
Also got error denied messages after which it doesn't seem to finish, it just hangs on last line for >15 minutes after which I breaked it.
I doesn't tell which file to tail for verbose output either.
I liked 2.0 more.
./update.sh
Detected an unclean abort of previous running update script. Do you want me to resume (yes) or restart (no)?
no
You are currently running version 4.8.25
Which version do you want to upgrade to?
4.9.23
Alright, I will try to upgrade to 4.9.23
Upgrade script downloaded. We need to download the upgrade files first. No upgrade is done yet. Do you want me to download the files (yes) or quit (anything else)?
yes
Waiting to finish. Sometimes this takes a minute or two ...
Done preparing.
Are your sure you want to upgrade to 4.9.23 (yes)? This is the last moment you can stop the upgrade. Answer with 'yes' will start the upgrade.
yes
Starting the upgrade now! Just wait a while... It can take a few minutes.
./update.sh: line 479: sleep: Permission denied
./update.sh: line 479: sleep: Permission deniede or two .
./update.sh: line 479: sleep: Permission deniede or two ..
./update.sh: line 479: sleep: Permission deniede or two ...
^Citing to finish. Sometimes this takes a minute or two ..
Regards, Ron.
Post by TheHogNL »
fyi, jumperone had an issue with a full disk. After making some free space opkg didn't work as a file which it uses was corrupt due to the disk being full. After recovering that file from another toon, it worked again and the update to 4.10.6 and later 4.13.7 worked fine.
Post by TheHogNL »
RDNZL wrote:I also had the issue above, after a few tries it continues.
I liked 2.0 more.
The 'sleep' is part of the progress message. Don't know why it gave that error in your situation.
I removed the log message location because a lot of people got confused by that. I replaced that with the progress message.
I think the update finished fine, as the real upgrade is started seperatly in another background process. However, canceling the script causes the iptables not to be restored. So check your iptables file before rebooting.
Also the reason I'm not showing the allowed versions anymore is because the list is too long to show. It is better just to upgrade to the well known versions which are talked about in the forums then use a random version.
EDIT: after rethinking this post I did some modifications, it is now on github: https://github.com/IgorYbema/update-rooted
jumperone
Post by jumperone »
I want to thank TheHogNL for its input.
With the speed he had.
To get the Toon right again.
I followed him in full admiration
with the Team Viewer.
He even updated the tone after 4.13.7.
The Toon now works for 100%
Thank you again
What can I do
wbmk
Post by wbmk »
@TheHogNL
Thank you for your great support!
I retried it a couple of times, and now it is running...
Thanx again!
gielie
Post by gielie »
I'd like to upgrade my Toon, im on version 4.9 and i have some questions.
1) I have the openVPN disabeled do i have to restore this?
#ovpn:2345:respawn:/usr/sbin/openvpn --config /etc/openvpn/vpn.conf --verb 0 >/dev/null 2>&1_
2) Im on 4.9 so i have to update to 4.10.6 first before i can go to 4.13, right?
3) I have a cron running which reapairs the ip tables after a restart, can keep this in place.
4) The previous time i upgraded from 4.8 to 4.9 i had to reinstall the toon store with all its settings for the waste and buienradar, will this info be stored with this update or do i have to do this again.
My toon is working great but still i like to upgrade.
Post by TheHogNL »
1) not necessary, the script will start the vpn (and stop it) when needed
2) yes, the script will force this for you if necessary
3) yes, the script will restore your iptables file also. Keeping the crontjob is just an extra failsafe (actually it helped a few already who had some issue's with the script)
4) the script will after upgrade, fix all the necessary files and reinstall toonstore
Return to “Toon Firmware”
