Toon App: DoorCam
oepi-loepi
Re: Toon App: DoorCam
Post by oepi-loepi »
Nog even wachten op de laatste goedkeuing, er komt weer een nieuwe versie aan (zat nog een klein foutje in). Jouw verzoek is ook gelijk meegenomen in 1.3.3
Arnout2000
Post by Arnout2000 »
Installed the new version. Happy that the tile now only displays the word ‘Doorcam’. Great! Thanks!
newwolf
Post by newwolf »
Heyy, one little question...
Is the start post info still relevant?
Because when I look at github there's only mentioned to create "ShowDoorCamToon" and a value, but the timer etc in blocky isn't noticed at all.
Thanks for creating the app :wink:
oepi-loepi
Got a little bit confused.. What information on Github?
newwolf
Post by newwolf »
This info:
https://github.com/oepi-loepi/doorcam/b ... ngelog.txt
But managed to get it working with Domoticz and Toon but using dzVents script from here:
https://www.domoticz.com/forum/viewtopi ... 91#p231191
Thanks for reply that quick
oepi-loepi
aha, didn't remember i added that in the changelog.. Good that it works now.
Techie
Post by Techie »
@oepi-loepi, I think there is a typo somewhere, 1.3.4 won't install. The log shows:
19/02/2023 19:25:54 Installing: doorcam-1.3.4
19/02/2023 19:25:54 Can not find doorcam 1.3.4 in github!
oepi-loepi
solved
Techie
Post by Techie »
Works, thnx! Awesome app!
And as a feature request: you've created the option to upload the HA-token in the userSettings. Perhaps a button to use/import the key from the HA-controller app would be benificial? This would reduce the need to save the token on 2 locations.
When used it is located in /mnt/data/tsc/homeassistant.token.txt.
oepi-loepi
ok, good advice. Let me think about that..
Jesse
Post by Jesse »
Hi, I have purchased the Reolink doorbell and configured the app as described in the opening post. When I open the doorcam app for the first time after rebooting Toon, the doorcam image is displayed. However, when I close the app and open it again it shows: No Connection To Camera
I have configured this URL (as described here):
http://192.168.xxx.xxx/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&user=USERNAME&password=PASSWORD
I configured the HTTP stream because the HTTPS stream doesn't work at all (it does in the browser)
I have no problems with opening the HTTP steam with my browser. Also, when I press F5 the page reloads without any problems
(The connection to my Home Assistant works. The doorcam app opens when I change the value of the helper to 200 and closes when I change the value to 100)
EDIT: When I restart the GUI (killall qt-gui), the doorcam works again (for once). For now, I'm running a script that executes the SSH command 5 minutes after the bell rings.
oepi-loepi
Looks like the timer to refresh the image is to fast. I have seen it before. Can hou slow the timer?
Doorcamfullscreen line 21
Jesse
Post by Jesse »
You can slow down the timer by increasing the number, right? I tried both (increasing and decreasing) but no luck. I also changed the number in line 19 because I am using cgiMode, but no luck either.
Should the green bar at the bottom of the screen count down? Because the bar stays at 100% all the time.
EDIT: Ok, it's working now. I changed the setting from cgiMode to JPG mode and now it works.
I thought JPG mode didn't work, but I think I was still testing with HTTPS earlier.
Arnout2000
Since a couple of weeks, after my doorbell is pressed, my Toon thermostat resets.
Not always, sometimes I see the camera image, but very frequently I see the reset screen instead of the camera image.
Any idea what causes this?
oepi-loepi
It shouldn’t and nothing is changed in the software. Maybe it is a memory problem or shortage when getting the images. Coul d you do a hard reset by a full restart? Power cycle your toon.
