Report Bugs Plugwise Beta Source April 2009
I don't think 20090525.3 exists. I have 20090525.0 installed en when I try to update it says no updates are available. Are you sure your version is 20090525.3 instead of 20090515.3?
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by rklootwijk</i>
<br />I don't think 20090525.3 exists. I have 20090525.0 installed en when I try to update it says no updates are available. Are you sure your version is 20090525.3 instead of 20090515.3?
I'm sure
In the top right corner it says: V20090525.3
After I had the "update reference not set" error I downloaded the update using the link in Reinder's post and installed it. For some reason after installation, there were two versions of Plugwise on my PC... one on drive C and this new one on drive D. I probably made a mistake and installed the update on the wrong drive (D:).
So I uninstalled the new version on drive D:, re-dowloaded the update of Reinder's post and installed it replacing the version on drive c:. The source software is running fine, except for the error when trying to update. The version mentioned in the upper right corner is V20090525.3.
I'm sure
Ik heb net geupgrade naar versie 20090529.1 en kreeg de volgende foutmelding bij het toevoegen van een nieuwe module:
Also updated to 20090529.1 using the updates button. It went fine this time.
It's working not fine for me.
Updating homeseer plugin is not working fine. sometimes i get
"ERROR: Cannot query http://localhost:8080/statistics.xml: Kan geen gegevens lezen uit de transportverbinding: De externe host heeft een verbinding verbroken."
Sorry error message is dutch
gr Ruud
gr Ruud
@Ruud: It's working fine for me. Are you still getting those error messages?
@Rene,
The forgot the use "Try Catch Finally" So you got an error message.
Yes, it is obvious they did not catch an exception there!
@ Rene,
Yes i still get "ERROR: Cannot query http://localhost:8080/statistics.xml: Kan geen gegevens lezen uit de transportverbinding: De externe host heeft een verbinding verbroken."
not the whole time en the plugin is still functioning normal.
Gr Ruud
ps i'm using the source, not the server
Gr Ruud
Seems the webserver of the source disconnects. Does restarting the source or running the webserver only, make a difference?
New beta update available V20090602.0
Reported bugs solved!
@ Rene.
The problem stays
Gr Ruud
The problem stays
Gr Ruud
New Beta en still some times "3-6-2009 7:59:12 - Plugwise - ERROR: Cannot query http://localhost:8080/statistics.xml: Kan geen gegevens lezen uit de transportverbinding: De externe host heeft een verbinding verbroken." both on server or source.
Are you running both Plugwise and Homeseer on the same server?
