Page 53 of 86
Re: Toon app: Afvalwijzer
Posted: Mon Jan 27, 2020 6:03 pm
by sanderjohan
Toonz wrote:sanderjohan wrote:Hi Toonz,
It seems dat veldhoven.nl (29) stopped working in 2020. Is it possible to fix this?
Thanks in advance.
that's because you need to manually download the ics file once a year and save it on Toon as /root/waste/waste_calendar.ics.
But now the good News: I believe I can now retrieve the calendar online, no need to manually download anymore.
Stay tuned for the new release today or tomorrow.
Hi Toonz,
That sounds great.
Thanks.
Posted: Mon Jan 27, 2020 9:02 pm
by Toonz
Hi all (sander
Version 4.36 is available in the ToonStore.
Changelog:
- changed veldhoven.nl (29) from manual to automatic retrieval of the waste calendar
(enter housenr and zipcode in the settings screen (letters in capitals))
no need to update for other cities.
Posted: Tue Jan 28, 2020 8:46 pm
by sanderjohan
Toonz wrote:Hi all (sander
Changelog:
Wow, installed the new version and it works great.
Thanks alot.
Posted: Mon Feb 10, 2020 12:34 pm
by TerrorSource
I've created a list of all cities and their waste providers.
This list is based on "best effort" and can have some errors.
Do not point to Toonz if this list has a city in it which says that it should work but it doesn't, send me a message instead so i can fix the errors in this list.
https://docs.google.com/spreadsheets/d/ ... edit#gid=0
Posted: Mon Feb 24, 2020 12:37 am
by memo1996
Wanneer is Gemeente Almere aan de beurt?
Posted: Mon Feb 24, 2020 11:25 am
by Toonz
There is no queue of cities to add to the app. I just do this on request.
Luckily Almere was easy to add...…
Version 4.37 is available in the ToonStore.
Changelog:
- added Almere.nl (select provider 38 and enter zipcode and housenr in the settings screen)
no need to update for existing users.
Posted: Mon Feb 24, 2020 12:30 pm
by memo1996
Hoe kan ik deze instellen?
Heb jij een instructie ?
Posted: Mon Feb 24, 2020 12:44 pm
by TerrorSource
memo1996 wrote:Hoe kan ik deze instellen?
Did you already update the Afvalkalender? If so, fill in your zipcode, house number and check the ? after "Afvalverwerker".
Posted: Mon Feb 24, 2020 12:45 pm
by memo1996
Nee nog niet gedaan.
Zodra ik thuis ben zal ik dit even doen.
Alvast bedankt!
Posted: Mon Feb 24, 2020 3:30 pm
by Toonz
TerrorSource wrote:I've created a list of all cities and their waste providers.
Amersfoort is already supported quite some time as well (Rova, provider 14). Didn't check the rest of the list
Posted: Mon Feb 24, 2020 10:11 pm
by memo1996
Zojuist geprobeerd en het werkt inderdaad alleen GFT restafval zie ik helaas niet dan zienik een streep (-).
Morgen dus 25-02-2020 is de ophaaldag voor GFT restafval maar dit zie ik helaas niet.
Wat wel klopt is plastic en karton ophaal data.
Posted: Mon Feb 24, 2020 11:06 pm
by Toonz
can you send me a pm with your zipcode? I will add the description for gft then....
Posted: Tue Feb 25, 2020 11:31 am
by memo1996
Zipcode: 1335RE
Posted: Tue Feb 25, 2020 12:45 pm
by Toonz
memo1996 wrote:Zipcode: 1335RE
Looks fine over here. Did you select afvalverwerker 38 in the settings screen and entered your zipcode and housenr in the same screen?
Posted: Tue Feb 25, 2020 1:52 pm
by memo1996
Jah dat ik het gedaan inderdaad anders zou ik geen gegeven zien. Ik mis alleen RFT dus restafval
