Toon app: Buienradar
Re: Toon app: Buienradar
Hi HenkJan,
These files contain your longitude/latitude coordinates to collect the rain prediction data for the next 2 hours. You can set these coordinates by clicking on the rain tile.
If you don't use that nothing to worry about.
hanplo
Post by hanplo »
Toonz wrote:
Matt88 wrote:Same problem here: Toonstore lists the new Buienradar app as available. Installation starts, Toon restarts, but there is no new Buienradar app. Tried to update and reinstall it but it would not install trought the store.
You will meed to manually install cron first as posted above.
After that install buienrader again via Toonstore.
Happy Xmas
OK, I never have done that. My Toon was rooted be Terrorsource. If I do the thing with the cron-file, the problem with the traffic app is also solved?
TerrorSource
Post by TerrorSource »
Happy Xmas
Send me a message and I’ll fix it for you :)
ams123
Post by ams123 »
ok the problem is i install and reinstall Buienradar but keep the same the Temp not chance only get a new tem after reinstall and stay on that temp all the time
Toon solarpannels
Rudolf
Post by Rudolf »
That's probably because the cron-tasks were not installed properly.
Make sure cron is installed and check the jobs, it's supposed look like this:
toon:~# crontab -e
# crontab for root
#      The time and date fields are:
#             field          allowed values
#             minute         0-59
#             hour           0-23
#             day of month   1-31
#             month          1-12 (or names, see below)
#             day of week    0-7 (0 or 7 is Sunday, or use names)
SHELL=/bin/sh
*/5 * * * * /root/bin/buienradar_get_data_5min.sh
2 */1 * * * /root/bin/buienradar_get_data_hourly.sh
ams123
Post by ams123 »
than my install not works
Toon solarpannels
ams123
Post by ams123 »
i still need help buienrader not update the temp
:~# opkg install cron_3.0pl1-r8_qb2.ipk
Installing cron (3.0pl1-r8) to root...
Configuring cron.
System startup links for /etc/init.d/cron already exist.
Toon solarpannels
ams123 wrote:i still need help buienrader not update the temp
Configuring cron.
You can resolve this by following the steps to configure cron described by Rudolf two posts above.
Or you can wait a couple of days. I have the new buienradar version 8.3.0 ready which works via https directly without the need for these cron jobs.
You will need to have a certificate added to Toon to get it to work.
I just need to decide whether to do this automatically from within the buienradar app itself or through the buienradar install script in ToonStore.
Regardz,
hanplo
Post by hanplo »
@Toonz
I think it's beter to do it in the Toon app. The Traffic information app doesn’t work either, it looks like it is due to the same issue
hanplo wrote:@Toonz
Traffic app (fileinfo from ToonStore) is working fine here, not using https (source data is coming from http://xml.fileindex.nl/ ).
Maybe you have to change your filter settings within the app?
hanplo
Post by hanplo »
@Toonz
The problem with the Traffic app was indeed a filter issue. Problem solved. Terrorsource tried to solve the problem with the Buienradar app, did not succeed and is searching for a solution. Of possible can you inform us when the new Buienradar app will be released.
Screamhouse
Post by Screamhouse »
for me restarting cronjob did the trick. Mine is also rooted by TerrorSource.
Please read the full message before enthusiastically pressing any buttons :-).
The wait is over. Buienradar 8.3.0 is released on ToonStore.
This version will work directly via https with the buienradar website.
In order to get this working we had to install SSL certificates on Toon.
To do this properly we had to upgrade ToonStore to 1.1.0 first.
So, if you are still on an earlier version of ToonStore please update ToonStore first to version 1.1.0.
Only after restart of Toon proceed with the update of the Buienradar app via ToonStore 1.1.0.
In Buienradar 8.2.1 we introduced an https workaround via cron. This is not needed anymore.
The buienradar 8.3.0 installer will remove these from /root/crontab if existing.
Warning: if you have edited /var/cron/crontab directly, those jobs will be removed.
Our installer is taking the entries from /root/crontab and applies these to the cron daemon.
As always any feedback is welcome,
Kind regardz,
Toonz & Marcelr
ams123
Post by ams123 »
Toonz wrote:Hi all,
Toonz & Marcelr
great work Toon And Marcel your the best
Toon solarpannels
Post by TheHogNL »
Toonz wrote: Other cron jobs for the waste collection app will stay untouched.
Nice work!
However my other cron jobs where removed also:
@reboot cp /root/iptables.conf /etc/default/iptables.conf
@reboot cp /root/passwd /etc/passwd
Not a big deal for me but maybe you can look into this.
