Bwired Googlemaps upload data webservice
Noel
Post by Noel »
Pieter.
I'm on my way to get some zzz's now.
Will give it a test go later today :-)
take your time no hurry :-)
Sooty
Post by Sooty »
This seems to work OK from my end, but I still get a 500 error if the units is left blank.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by sooty</i>
<br />Perhaps Peiter is going to change this?
On the Time Zone subject.
I suppose that each users data would need to be "Time Zoned" then "Today" calculated on a per user basis.
Paul..
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Right Paul, if we get more global (lorenzo in Italie now)
I need to add time zone. Now I have special code for Sooty in my webservice [:D]
Sooty
Post by Sooty »
OK Pieter. I feel privileged now [:D]
Lorenzo,
You still need to remember that the units can't be blank.
Paul..
Now solve the problem, that you are gone for 1 hour!
I think the Units can be blank now! (fixed)
@ddgiel from Belgium: welcome on the map, Giel is running a script from his Synology 207+ NAS and uploading :-)
Noel
Post by Noel »
Okay. All looks fine now.
One request.Can you make the Varchar input longer? (I think that at the moment the max is 10)
I saw your update:)
The varchar is and was 25 in the database, perhaps something in my program?
Noel
Post by Noel »
I'll do some more testing later today (with a fixed string) to see if the problem is yours or mine.
ddgiel
Post by ddgiel »
A mentioned above by Bwired. HW376 (ddgiel) is online.
I have a Vantage Q-Link HA system, and using a Synology DS207+ with Perl, PHP, MySQL as Intranet interface.
Every 5 minutes I receive indoor/outdoor temperatures from the Q-Link system. These are stored in MySQL DB.
Now I transmit these data to http://www.bwired.nl/domoticaworld.asp.
My scripts are based on JFN perl scripts. (Thanks JFN).
Had some problems with perl using standard lib LWP::UserAgent, but I have also installed Squeezecenter and with those perl libs works OK.
Any questions about DS207+ integration please let me know.
Thanks ddgiel for the script on the Synology 207!
Uloading is going good with this script.
Last updates on the Bwired Webservice:
<Units> can now be blank as well
<Value> can now be Varchar 30 positions Max
Noel
Post by Noel »
lets start playing :-)
Welcome PeterPC on the googlemaps (nr 20)
If anyone needs help to make a Homeseer script just mail me and I will help.
You get some experience with XML etc along the way, so don't hesitate :-)
Good promotion to get us all on googlemaps with some realtime data!
Sooty
Post by Sooty »
I have created a configuration utility for Homeseer users that can create the xml required by just choosing up to 10 Homeseer devices and filling in the user data.
You can send a test xml to the Homeseer log to make sure its all working as expected.
It would be good if a couple of the more experienced Homeseer users could do a bit of testing before its released to the less technical users.
Paul..
Hi Paul,
tool looks good.
I'm in for testing.
Return to “Bwired Forum”
