Toon app: Afvalwijzer
Re: Toon app: Afvalwijzer
Thanks! @toonz
can you add purmerend to the afval list ?Toonz wrote:Hi all,
I enhanced the app with the waste provider 'katwijk.nl'.
As this provider is using 'https', a separate method of retrieving the data needs to be installed as posted by Marcelr earlier.
This version is reading the file '/root/waste/waste_calendar.ics' to get the waste collection dates for Katwijk.
Configuration:
You need to edit WastecollectionApp.qml at the top to select one of the five supported waste providers
And edit your zipcode/house nr (not needed for Cure Avalbeheer, Cyclus NV and Katwijk.nl).
This version is fully compatible with the thermostat_mod V1.2 posted earlier.
Currently supported:
"mijnafvalwijzer.nl"
"deafvalapp.nl"
"cure-afvalbeheer.nl"
"cyclusnv.nl"
"katwijk.nl"
Let me know if you want support for additional providers.
Regardsz,
https://afvalkalender.purmerend.nl
Yes, no problem, will be in the first next release....soonishbouke wrote: can you add purmerend to the afval list ?
A new version 4.48 is available in the ToonStore which adds support for Purmerend.
No need to update for other users.
Changelog:
- added purmerend.nl. Select provider 39 and fill in your calendar ICS number
Get you calendar ICS number by visiting afvalkalender.purmerend.nl and login with your zipcode/housenr.
Click 'Naar maand en jaar kalender'
Click 'Zet inzameldata in agenda'
Look at the link under 'Synchroniseren'and find your calendar ICS number at the end of the URL.
Kind regardz,
Changelog:
Kind regardz,
thnx gonne give it a try tonight.Toonz wrote:Hi all,
Changelog:
Kind regardz,
thnx for the effort .
Ik kan Weesp niet vinden als afval.
Graag Weesp ook toevoegen als afvalverwerker.
Hoor het geaag
Hoor het geaag
Weesp wordt al ondersteund: afvalverwerker 26 (https://inzamelkalender.gad.nl/).
zelfde procedure volgen als bij Purmerend hierboven
having an issue with mijnafvalwijzer (1 or 31) for castricum 1902GN. It should only give the weekly Tuesdays as ophaaldatum, but now gives also the weekly mondays. (is also other type of afval). Visiting the website with a normal browser gives tuesday only (as expected). Any idea?
I see what you mean, interesting case. Will have to do some debugging. Stay tuned.gerlag wrote:Hi,
Got it, they provide also data for 2021, the extra dates you see are for next year.
Will fix this in the next release (using the same provider myself so will happen quickly
I'm fairly short of memory, one year ahead is to long to remember
I'm happy you will look at it. Thanks!
version 4.49 is available in the ToonStore with a fix for mijnafvalwijzer.nl (provider 1/31).
Some cities did already put in 2021 collection data, others didn't. This version is handling both as it should.
No need to upgrade for other users.
Kind regardz,
Kind regardz,
Thanks a lot!
Volgens mij staat alles goed, waar gaat het fout[emoji848] ik blijf nl niets zien in de afvalwijzer.Toonz wrote:Weesp wordt al ondersteund: afvalverwerker 26 (https://inzamelkalender.gad.nl/).
Plaats: Weesp
Softwareversie 5.33.9
Verstuurd vanaf mijn SM-A505FN met Tapatalk
- Administrator
When i check a zipcode in Weesp it's iCal numbers are 16 digits, your photo only shows 14. 2 digits to short.genux wrote:Volgens mij staat alles goed, waar gaat het fout[emoji848] ik blijf nl niets zien in de afvalwijzer.Toonz wrote:Weesp wordt al ondersteund: afvalverwerker 26 (https://inzamelkalender.gad.nl/).
Plaats: Weesp
My guess is that you need to use https://inzamelkalender.gad.nl/ical/0457200000199604
I try to get the afvalkalender of Uden in the Afvalwijzer app.
As far as I know, Uden is not supported by the afvalverwerkers that are already implemented in the app.
Can this also be implemented in the app?
https://www.uden.nl/inwoners/afval/opha ... PK-65.html
I also downloaded the .ics file, only I cannot find how to upload the file to my Toon.
I noticed there should be a description in the Manuals section, however I cannot find it.
Can someone please help me out with this?
Thanks in advance!
Thanks in advance!
