Imagintronix offset on v79
kylegordon
Post by kylegordon »
Evening all,
2 weeks ago I upgraded from firmware 78 to 79 on my rfxtrx433, and all is well except data from my collection of cheap Imagintronix temp & humidity sensors. They're all reading about 50 degrees higher than before the firmware upgrade - graphs at https://www.flickr.com/photos/kylegordon/15300824363/
Is this to be expected and they all need a -50 calibration tweak, or is it a bug that needs raised?
Cheers
Kyle
b_weijenberg
Re: Imagintronix offset on v79
Post by b_weijenberg »
There is no change in V79 for the Imaginetronic, at least not intended.
What happens if you go back to V78?
Please contact support if there is really a 50 degrees offset in V79 compared to V78.
kylegordon
Yup, can confirm. Dropping back to v78 causes the sensors to return to approximately normal.
Will drop an email to the support line :-)
b_weijenberg
A special firmware has been sent Dec 1st but no response yet.
b_weijenberg
Problem cannot be reproduced.
No response from kylegordon, problem call closed.
kylegordon
Been abroad for 5 weeks. Back soon, and will try to reproduce again when I'm local to the environment.
kylegordon
Hey,
Back from holidays and all refreshed...
Tried upgrading to v83, and sadly the Imagintronix sensors are reading too high. This is from moments after the upgrade, in Domoticz
132 RFXCom CD00 0 Study Temp + Humidity Viking 02035, 02038, TSS320 70.4 C, 36 % 6 100 Remove Device Log 2015-01-23 21:04:14
117 RFXCom 5B00 0 Geekloft Temp + Humidity Viking 02035, 02038, TSS320 65.9 C, 44 % 5 100 Remove Device Log 2015-01-23 21:04:11
116 RFXCom 1F00 0 Master Bedroom Temp + Humidity Viking 02035, 02038, TSS320 69.0 C, 37 % 7 100 Remove Device Log 2015-01-23 21:04:00
Happy to run whatever diagnostics you wish.
Cheers
Kyle
emvee
Post by emvee »
Could it be that the temperatures are in Fahrenheit while the message says Celsius...
b_weijenberg
check what is received in RFXmngr
kylegordon
Hi folks,
This is the RFXmngr output from versions 78. 79 and 88, with respect to the Imagintronix/Viking sensors. All readings were taken within half an hour, and the temperature stayed around the same.
FIRMWARE 78 ======================
Packettype = TEMP_HUM
subtype = TH9 - Viking 02038, 02035 (02035 has no humidity), Proove TSS320,311501
Sequence nbr = 1
ID = 23296
Temperature = 10.7 °C
Humidity = 42
Status = Comfortable
Signal level = 6
Battery = OK
Sequence nbr = 2
ID = 19200
Temperature = 7.1 °C
Humidity = 44
Signal level = 7
Battery = OK
Sequence nbr = 3
ID = 52480
Temperature = 9.2 °C
Humidity = 40
Signal level = 7
Battery = OK
Sequence nbr = 4
ID = 7936
Temperature = 9.1 °C
Humidity = 40
Signal level = 6
Battery = OK
FIRMWARE 79 ======================
Sequence nbr = 0
ID = 23296
Temperature = 62.1 °C
Humidity = 42
Signal level = 6
Battery = OK
Sequence nbr = 1
ID = 19200
Temperature = 58.4 °C
Humidity = 44
Signal level = 7
Battery = OK
Sequence nbr = 2
ID = 52480
Temperature = 60.5 °C
Humidity = 40
Signal level = 7
Battery = OK
Sequence nbr = 3
ID = 7936
Temperature = 60.2 °C
Humidity = 40
Signal level = 6
Battery = OK
FIRMWARE 88 ======================
0A5209055B00026D2A0169
Sequence nbr = 5
ID = 23296
Humidity = 42
Signal level = 6
Battery = OK
0A5209064B0002472C0179
Sequence nbr = 6
ID = 19200
Temperature = 58.3 °C
Humidity = 44
Signal level = 7
Battery = OK
0A520907CD00025D280179
Sequence nbr = 7
ID = 52480
Humidity = 40
Signal level = 7
Battery = OK
0A5209081F00025A280169
Sequence nbr = 8
ID = 7936
Humidity = 40
Signal level = 6
Battery = OK
