[Hardware] Choice of server hardware
Posted: Tue Jan 13, 2015 2:29 pm
by raymonvdm
There are a lot of options regarding the choice of hardware to use with domotica and i`m looking for a new hardware setup. I`m currently running HomeSeerPro(2) on a Asus EEE Box B202 machine with 2GB ram and 128GB SSD it is working but the machine is slow sometimes which can result in slow response and when a sensor is activated it can take some time for the lights to go on.
When i startup HomeSeer on my laptop (Core I5) it is started within seconds and much faster then the EEE Box, but i need this laptop for work :twisted: I don`t want to buy a complete controller like Vera Edge, Fibaro HC2, Fibaro HCL because they are too closed for my needs. I would like to buy a "cheap" hardware pc platform with "full" power cpu resources to run my Domotica software on
In my quest for the new box i found the following solution and would like to know if it is fast enough for HomeSeer (or OpenHAB since i`m using both)
GIGABYTE BRIX GB-BXBT-2807 as i also found (dutch) out that is seems to be as slow as a Intel Atom CPU (which the B202 has)
Note:
  • I already tested DomotiGa on a RaspberryPI (B) but it has too few ports for all my interfaces, even using multiple USB Hubs.
  • I`m also running OpenHAB / Domotiga on another B202 using Ubuntu Server 14.04
Re: [Hardware] Choice of server hardware
Posted: Tue Jan 13, 2015 10:12 pm
by mhn
Hi.
I run Homeseer on Intel NUCs. HS2 runs on an "old" Celeron.
For HS3 I bourght one with Core 13-4010U. HS3 isn't daily use yet.
I am very satisfied with the NUCs for HS.
Regards
Morten
Posted: Wed Jan 14, 2015 2:10 pm
by abl
I'm also looking to refresh my hardware, so am very interested in this topic.
For my domotica to work I would need a serial port (don't like as much the usb->serial converters as I understood these are not that stable; I couldn't find one of these on the Intel NUC's or am I wrong?
Posted: Wed Jan 14, 2015 3:28 pm
by mhn
You are right NUCs are USB only.
I use them with a powered USB hub. I have no serial devices.
Regards
Morten
Posted: Wed Jan 14, 2015 4:13 pm
by raymonvdm
I`m also using a Powered USB Hub on my B202 because RS232 ports are rare on systems these days
