Page 13 of 16
Re: HS3 MQTT Plugin
Posted: Wed Jul 19, 2017 9:16 am
by raymonvdm
did you check the firewall on you`re windows 7 machine, and verified that Mosquito is actually running?
Re: HS3 MQTT Plugin
Posted: Wed Jul 19, 2017 10:01 am
by geert-jan
In the mqtt config you checked 'anonymous' and you also provide username/password.
When anonymous is checked, the username will not be send to the mqtt broker.
Can you check your broker config?
Geert-Jan
Verstuurd vanaf mijn ONEPLUS A5000 met Tapatalk
Re: HS3 MQTT Plugin
Posted: Sat Jul 22, 2017 7:38 pm
by EmilySmith1
I manually added Mosquitto in windows Firewall and now it works
Thanks
[img]
- Firewall.PNG (28.85 KiB) Viewed 22716 times
[/img]
Can HS3 MQTT plugins manipulate strings Like On,Off,Away,Open,Close etc and convert them to numbers 1,2,3,4,5....and so on
Thanks
Emily
Re: HS3 MQTT Plugin
Posted: Fri Jul 28, 2017 4:52 am
by drodegeb
I have looked through everything, but can't seem to find it. Is there a way for an MQTT message to control a Homeseer device? Not a device that is a subscription, but instead a native device like a ZWave light switch. I see Homeseer sends out a topic like "/homeseer/78/value" with 0 for off and 255 for on. But, that topic doesn't seem to control it when it's sent from outside homeseer.
Thank You,
Dave
Re: HS3 MQTT Plugin
Posted: Fri Aug 18, 2017 10:09 pm
by webmeezer
Is there a chance you'll add SSL/TLS support (ie port 8883) to the plugin?
Thanks,
Z
Re: HS3 MQTT Plugin
Posted: Sat Aug 19, 2017 10:01 am
by geert-jan
SSL/tls support is on the feature list.
Currently I am busy with refactoring the implementation to make next steps more easy/testable, next I pick up this feature.
Geert-Jan
Re: HS3 MQTT Plugin
Posted: Sat Sep 30, 2017 10:34 am
by nickneutrino
In addition to port 8883, are you intereted to integrate with IOT Core for Google Cloud Plattform.....
Because i create a device entry on the cloud and is mandatory connect with a cert key.
Re: HS3 MQTT Plugin
Posted: Sat Sep 30, 2017 11:09 pm
by rmiles7721
drodegeb wrote:I have looked through everything, but can't seem to find it. Is there a way for an MQTT message to control a Homeseer device? Not a device that is a subscription, but instead a native device like a ZWave light switch. I see Homeseer sends out a topic like "/homeseer/78/value" with 0 for off and 255 for on. But, that topic doesn't seem to control it when it's sent from outside homeseer.
Thank You,
Dave
I would like to know the same thing. I can see the MQTT topics getting sent out and when I turn a lamp off and on the corresponding lamp in HASS turns off but when I do it in the opposite direction nothing happens. I get this in my HS log:
Sep-30 5:08:25 PM MQTT Info: Received MQTT topic: /homeseer/masterbedroom/desklamp payload: 0
Re: HS3 MQTT Plugin
Posted: Sun Oct 08, 2017 1:01 pm
by critical_
rmiles7721 wrote:drodegeb wrote:I have looked through everything, but can't seem to find it. Is there a way for an MQTT message to control a Homeseer device? Not a device that is a subscription, but instead a native device like a ZWave light switch. I see Homeseer sends out a topic like "/homeseer/78/value" with 0 for off and 255 for on. But, that topic doesn't seem to control it when it's sent from outside homeseer.
Thank You,
Dave
Same here. I'd like to have a device connected to HomeSeer (like a fan, light switch, or something else) controllable from Home Assistant over MQTT without workarounds.
Re: HS3 MQTT Plugin
Posted: Wed Oct 11, 2017 9:08 am
by geert-jan
Interesting feature request, that already popped-up several times.
Makes Homeseer a bridge between MQTT and other protocols like z-wave.
It is on the feature list, but due to my limited time, what has a higher priority: TLS/SSL encryption support or this request to control HS devices via MQTT?
Geert-Jan
Re: HS3 MQTT Plugin
Posted: Wed Oct 11, 2017 12:26 pm
by raaguirr
Hi!! first of all this is a great plugin, congratulations for your work...
I have simple question, is there a way to specify other port than the default 1883?? i have my mosquitto broker running on the 10350, is there a way to configure to get to this port?
Thanks a lot
Re: HS3 MQTT Plugin
Posted: Thu Oct 12, 2017 7:23 am
by geert-jan
in the current version the port number cannot be changed. I plan to implement this together with the TLS/SSL support.
Geert-Jan
Re: HS3 MQTT Plugin
Posted: Fri Oct 13, 2017 10:09 am
by Fredrick
Hey guys,
Trying to get this plugin set up, but I'm struggling with the basics. I've got a Mosquito server set up, and I'm connected to it:
I can also see PINGREQ/PINGRESP in my Mosquito log.
I want to publish the value of some devices, but nothing seems to be sent at all from this plugin. Dont know what I'm doing wrong:
In the log (with info-logging level) this is all I get:
Any idea how I can get it to publish values? I've also tried setting up an event to manually publish device value and custom topic, but nothing is sent.
Thanks!
Re: HS3 MQTT Plugin
Posted: Mon Oct 16, 2017 7:44 am
by geert-jan
in the configuration I see that you connect anonymous to the MQTT broker, and you also supply username/password.
If the MQTT broker needs a username/password than uncheck the 'anonymous' flag.
Geert-Jan
Re: HS3 MQTT Plugin
Posted: Tue Oct 17, 2017 6:12 am
by critical_
geert-jan wrote:Interesting feature request, that already popped-up several times.
Geert-Jan
I would prefer the ability to control HS devices via MQTT. The TLS/SSL support with port changing ability can come second. A lot of us would be able to use the plugin more regularly so we can give you more feedback. Thanks you.
