OTG with Arduino and Openhab
jappiedepappie
Post by jappiedepappie »
I'm planning to start using the OTG soon. However, I want it integrated in my Openhab setup. Here's where I need help.
My idea of setup is:
OTG connected via serial interface with Arduino.
My arduino is connected via WiFi to my network and Openhab
The communication between arduino and openhab will be MQTT.
The questions I have is:
Has anyone already a similar setup?
What do I need to connect the OTG with my Arduino?
Please let me know if more information is needed.
Thanks already everyone for taking the time to read/respond!
/Jasper
“Intellectual growth should commence at birth and cease only at death.”
― Albert Einstein
jappiedepappie
Re: OTG with Arduino and Openhab
Anyone willing to help me out, or point me in the right direction?
/Jasper
― Albert Einstein
jappiedepappie
Nobody who can help with the OTG <-> Arduino connection?
― Albert Einstein
If you're so anxious to get a response, posting in the correct forum might be a good idea. I check the Opentherm Gateway Forum almost daily. This one, not so much.
If the Arduino and OTGW are close together, you can just rip IC2 out of the OTGW and hook up the serial interfaces of the two at TTL level. All you have to do then is write the Arduino code to translate the hex messages of interest produced by the OTGW to MQTT.
