Xanura and 6-way switch
Posted: Sat May 10, 2008 3:33 pm
I finally received the long awaited switches and wall outlets from the Niko Pure series, as introduced by Kris in http://www.domoticaforum.eu/topic.asp?TOPIC_ID=204. I liked the looks of these and the fact that the switch has indicator leds, so I decided to install them in our kitchen. I had to wait for a long time for the Dutch wall outlets to become available in this series, but they're finally here.
I ordered some 6-way switches with blue leds, as in these pictures.
My idea was to put two Xanura AIX modules on one switch (not in the same "inbouwdoos", but one behind the switch itself and one behind a wall outlet next to it). The first AIX would then switch the 4 top most buttons. The other AIX would switch the remaining two buttons.
However, internally the 6-way switch is wired in such a way that all switches share a common connection. Here's a picture of the back of the switch.
In the picture you see connection points C1 and A through F. C1 is connected to each and every switch and each switch is connected to only one of A through F. The other connections on the bottom (with the leads) are for the leds (0-24V); these can be neglected for now.
I can thus connect one AIX with its common wire (blue) on C1 and the other 4 wires on A through D. That works well. So far, so good.
But what about the other AIX? My (probably naive) thought was to connect the common wire of the second AIX to C1 as well and the brown and red wires to E and F. However, using this setup, plugging in both AIX at the same time blows a fuse in the fuse box!
My questions:
- Why does the fuse blow? I thought all these AIX connections were potential free?
- Is there a way to accomplish what I'm trying to do here, or can I use only 4 switches of the 6-way switch with Xanura modules? (The switches and leds are mounted on a PCB that can not be easily modified to change the wiring.)
Thanks a lot in advance!
Lennart
P.S. What I forgot to mention: the 6 switches are potential free momentary switches ("impulsdrukkers").
My questions:
Lennart
