Not possible to upgrade firmware
Posted: Sun Sep 20, 2015 12:16 pm
Hallo,
I've got he OTGW from the webshop (KIWI) completely soldered with RS232 interface
I connected the supply and the RS232 to my laptop, as soon the power goes on I get the follwing messages, as expected:
Opentherm gateway diagnostics - Version 1.1
1. LED test
2. Bit timing thermostat
3. Bit timing boiler
4. Delay symmetry
5. Voltage levels
6. Idle times
Enter test number: : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : : :
This maybe looks good, but this is all what I get out of it.
First of all, I can't use the diagnostics. Input from keyboard aren't exepted. Nor in OTmonitor or in terminal (Terraterm / hyperterm)
I tried to install the OTGW firmware using OTmonitor.
I can select the *.hex file and press program.
It tries to put the gateway into self-programming mode. After 1-2 sec. I'm asked to reset the module myself.
Then I do this, I get the messaged : "could not put gateway into self-programming mode".
It looks like the communication is ok... no funny characters.
Although, the 20x :::: don't look ok to my.
I don't see anybody in this forum using the OTGW on a "real" RS232 port (oldfashioned fysical build into laptop). Does the gateway work ok with this??
Or does the PIC need any self-programming code that wasn't installed??
Any help is welcome!
Lennard Mens
1. LED test
4. Delay symmetry
5. Voltage levels
6. Idle times
Lennard Mens
