As the tittle says....how do i test if the FGSS-101 really works?
I held it above steaming water for about a minute but nothing.
I've lith 2-3 matches right next to it and nothing.
What is the best way to check if they aren't malfuntioning?
Gr
Michiel
How to test fibaro smoke sensor? FGSS-101
Re: How to test fibaro smoke sensor? FGSS-101
Take a small piece of paper and light it up! Do it under the detector and it will start function.DrDoo wrote:As the tittle says....how do i test if the FGSS-101 really works?
Gr
Michiel
Oke will try that
Wan't to make sure they work off course
Thanks
Thanks
You also could consider buying a can of test gas. It's specially designed for testing smoke detectors. Google should help you finding a supplier.
Herbus (Jos)
After burning an old newspaper they work
