rfxcom meter
Posted: Tue May 13, 2008 10:05 pm
by Kroonen
I want to measure the electricity. Is the rfxcom meter with pwr, product code 70087 enough??
I see it measures fase, where must you put it if you have 2 aardleks? 2 brown wires in the ring of the meter?
Does xpl-perl support the pwr, is see rfxcom meter but not special the rfxcom pwr?
rfxcom meter
Posted: Tue May 13, 2008 10:13 pm
by Snelvuur
as far as i know xpl-perl does support the rfxcom pwr, if you want to be sure ask beanz, or check the source codes (you can easily see what is supported and what not)
rfxcom meter
Posted: Tue May 13, 2008 10:25 pm
by Kroonen
If is see the developer info on the trac i only see rfxcom meter
