delayed on power switch
Posted: Thu May 15, 2008 4:36 pm
by Willem4ever
I have some power hungry devices that need to be switched on with a (random) delay after power failure. Now when power returns the load current is too high and the automatic fuse 'switches off'
Posted: Thu May 15, 2008 4:43 pm
by Snelvuur
i would assume you dont have lots of power failures no? Also depends on what types of devices your powering. Big motors? or something else?
Posted: Thu May 15, 2008 4:57 pm
by Willem4ever
<br />i would assume you dont have lots of power failures no? Also depends on what types of devices your powering. Big motors? or something else?
Think about normal 220 volt applicances, i just want to avoid they swicth on all at the same time.
Posted: Thu May 15, 2008 6:27 pm
by Snelvuur
Well if you use homeseer for instance, i think those things should be possible. Never seen an example like that, but i know that homeseer has a recovery process. I dont know if that includes turning on/off the last known state.
But those devices should be switched with x10 modules or something similar then.
Posted: Thu May 15, 2008 6:39 pm
by Willem4ever
<br />Well if you use homeseer for instance, i think those things should be possible. Never seen an example like that, but i know that homeseer has a recovery process. I dont know if that includes turning on/off the last known state.
Not an option, should be autonomously ... or thru serial / usb
