How to switch from normal to reduced heating with OTGW
Posted: Tue Nov 17, 2015 6:25 am
by rpav
Hi folks,
first of all, thank you for patience to answ. newbies questions.
As most of us, I would like to use OTGW to very elementary control of my boiler.
The task is switch to the "reduced heating mode" remotely.
Does anybody know how to easy do that?
I try commands: CS=10, CH=0, but the boiler has still central heating 2 enable. Any way how to manipulate with CH2?
Thank you,
rp
Re: How to switch from normal to reduced heating with OTGW
Posted: Tue Nov 17, 2015 10:43 am
by rpav
OK, so I will try to answer myself
I believe that switch boiler from "normal" heating mode to "reduced" heating mode (in the meaning of QAA73 button) means change Status from 00010011 to 00000010 (bits for CH and CH2) and decrease CS and CS2 to appropriate level.
With current version of OTGW we can manipulate with CH and CS, but there is not way how to manipulate with CH2 and CS2.
If I'm right, this will be my user wish for the next release of otgw.
Thank you!!
--rp
Posted: Tue Nov 17, 2015 3:33 pm
by Bororo
Your need to check if your boiler can accept such comand from OTGW.
Please check this link for compatibility
http://otgw.tclcode.com/matrix.cgi or have a look here
http://www.domoticaforum.eu/viewtopic.php?f=75&t=10541
Posted: Wed Nov 18, 2015 11:37 pm
by rpav
Which command you mean? Is there any command to switch from normal to reduced mode?
Sorry, but I don"t think so. I believe it can be achieve by CS=10, CH=0, CS2=10, CH2=0, but CS2=10 & CH2=0 are not exists on OTGW...
Or am I wrong?
r.
Posted: Fri Nov 20, 2015 6:15 pm
by Bororo
If my boiler is in "reduced" mode, I can send messages MM=100 and CS=22 and boiler will switch to "normal" mode...
