Put opentherm data into a database (MySQL) with PHP
hansieh
Post by hansieh »
Yesterday, I have my opentherm gateway soldered and connected and everything works fine.
My next step is to put the generated data via PHP in a database (MySQL) from where I can created the graphs.
Before I go creating it myself, I am wondering if there might be someone who has already created a database model and some PHP code what I could use.
For example what I like to created (My site):
http://www.chamiri.nl/drupal7/
(domotica, arduino, MySQL, PHP, electronics)
Re: put opentherm data into a database (MySQL) with PHP
Not exactly, but I have a matlab script (two, actually) that dumps otgw log data into a struct (per day). Is easily converted to php.
EDIT 20160103: parse_otmon_log.m had a bug, fixed.
grtz,
parse_otmon_log.m.zip
Updated version. Small error in the calculation of OT floats fixed.
(1.1 KiB) Downloaded 723 times
read_ot_log.m.zip
main routine
(945 Bytes) Downloaded 721 times
I just use a key value store, like for all my other metrics. Influxdb is perfect for storing timeseries.
hansieh
Post by hansieh »
Rene wrote:I just use a key value store, like for all my other metrics. Influxdb is perfect for storing timeseries.
Hi Rene,
Influxdb looks very intressing, I will give it a try. thank for the tip.
raymonvdm
Post by raymonvdm »
I use MQTTwarn to perform some actions based on the MQTT output of OTMonitor
https://github.com/jpmens/mqttwarn
Dickuk
Post by Dickuk »
Have a look at https://github.com/thoukydides/heatmiser-wifi
I modified his code to produce graphs on the opentherm data.
