Opentherm gateway not working
Posted: Thu Feb 18, 2016 11:01 pm
My gateway doesn't work. Also a friend has a working gateway but mine doesn't work at his home.
Everything works fine but nog boiler signal. I update the firmware. Webserver works.
When I run the diagnostics following appear.
Opentherm gateway diagnostics - Version 1.1
1. LED test
2. Bit timing thermostat
3. Bit timing boiler
4. Delay symmetry
5. Voltage levels
6. Idle times
Enter test number: 5
Thermostat: 3.01
Boiler: 0.00
Reference: 1.21
I think it's something with hardware but what can coause this?
Mark
1. LED test
4. Delay symmetry
5. Voltage levels
6. Idle times
Thermostat: 3.01
Boiler: 0.00
Reference: 1.21
Mark
