Moderators: Rene, Willem4ever
Postby al30k » Mon Aug 14, 2017 7:14 pm
Hi, is it possible to "arm away" or "arm home" in instant mode with this app?
I use it with "arm home" at night, to make perimeter sensors around house work without "entry delay".
According this, PowerMax plugin for Vera can do it and use same interface, http://code.mios.com/trac/mios_visonic-powermax
thanks.
al30k
Postby bartbakels » Mon Aug 14, 2017 7:30 pm
I think this can be done by scripting in domoticz but dont use domoticz myself.
(ON ESXI )on NUC
bartbakels
Postby Blaabjerg » Tue Aug 15, 2017 7:42 am
I would like to use the PIR to turn on and off lights when it is not arm and detect motion. The issue is that the PIR is detecting motion and the is reset very fast. I know that I can set the reset time on the PIR. But is it not possible to config the PIR to keep in "detect motion" state as long as there is movement?
Thanks
/Claus
Blaabjerg
Postby bartbakels » Sun Aug 20, 2017 11:52 am
No sorry this is how the visonic panel is designed...
(ON ESXI )on NUC
bartbakels
Postby Blaabjerg » Mon Sep 11, 2017 8:30 pm
I have a MCM-140 unit. Visonic driver setting does not seem to register when I arm and disarm.
Am I not able to see events when I use MCM-140 remote keypad?
Thanks
/Claus
Blaabjerg
Postby bartbakels » Wed Sep 13, 2017 11:01 am
Blaabjerg wrote:Hi,
Thanks
/Claus
claus,
NO, first of all the panel events will be registered whatever used, but you can even trigger events on use of the MCW-140 (disarm/arm etc) as a separate event. I use them as well (2 of them) and this works great. So my panel status updates in HS3 obviously, but I also created to virtual devices which shows me when and which mcw-140 is used to arm/disarm.
bart
(ON ESXI )on NUC
bartbakels
Postby Blaabjerg » Wed Sep 13, 2017 2:29 pm
bartbakels wrote:
Blaabjerg wrote:Hi,
Thanks
/Claus
claus,
bart
Ok. But can you detect witch user / kode that have disarmed / armed the alarm?
/Claus
Blaabjerg
Postby Blaabjerg » Wed Sep 27, 2017 6:54 pm
I'm able to run the DISARM_[securityAdditionString] to disarm my alarm. But i would like to detect witch user that disarm my alarm.
Is that possible?
Ex: DISARM_[USERCODE]
Thanks
Regards
Claus
Blaabjerg
Postby bartbakels » Wed Oct 04, 2017 11:29 am
Blaabjerg wrote:I'm able to run the DISARM_[securityAdditionString] to disarm my alarm. But i would like to detect witch user that disarm my alarm.
Is that possible?
Thanks
Regards
Claus
Claus,
sorry for the late response, again I didn't get an update from the board, and was on holiday :D
I far as I know I cant detect the used usercode, however I don't use this my self. I have similar functionality but I use keyfobs, proxytags and wireless commanders. These can be userspecific off course, and I defined in the user event config tab the following actions;
keyfob 3 arm home httpcall1
keyfob 4 disarm httpcall2
to determine the actions of these devices and report these back to hs3, or vera, domoticz etc.
hope this helps?
Bart
(ON ESXI )on NUC
bartbakels
Postby Blaabjerg » Mon Oct 30, 2017 5:21 am
Is that possible?
Thanks
Regards
Claus
Claus,
hope this helps?
Bart
Yes, I have also configured my keyforbs like that. But ex. a wireless commander can have multiple users entering a code. And that could be cool get what number that have been entered, because then I know with user who have disarm/armed the alarm.
Do you use HS3?
If you do, do you know if it is possible to disarm the alarm from a tablet interface (On a security panel) with the user code that have been assigned in the Powermax alarm?
Thanks
/Claus
Blaabjerg
Postby bartbakels » Mon Oct 30, 2017 8:47 am
claus,
No its not possible to determine which code is used on the keypads. These codes are not stored in the panel but in the keypad itself.
Yes im using Hs3, and you can create an HStopucyh window to arm and disarm, but again, i cant extract the codes from the panel, to do so. You could create your own codeentry object in hstouch probably with stored codes.
regards
Bart
(ON ESXI )on NUC
bartbakels
Getting armed status from HS3
Postby Mario from Spain » Tue Feb 27, 2018 10:22 am
Hi Bart
Sometimes HS3 looses sync with the visonic driver status (armed, disarmed, arm, home, etc). How can I get the armed status from HS?
I tried http://ip:3011/VisonicDriver/jsonget?se ... tionString but it only returns {"Alarm":"FALSE","Alert in memory":"FALSE","Arm/disarm":"FALSE","ByPass":"FALSE","Last 10 seconds delay":"FALSE","Log Events":"","Ready":"FALSE","System Status":"","Trouble":"FALSE","Zone Event":"FALSE","Zone/User":"","ZoneEvent Types":"","Zones State":]} without status about the arm status.
Also, anyway to do something similar to get the status of each zone?
Thank you.
Mario
Mario from Spain
Postby Mario from Spain » Fri Mar 16, 2018 12:09 pm
Hi Bart.
I still have this issue with many errors each hour I suspect it has something to do with the loss of sync I suffer from time to time (maybe the program isn't processing communications with the popup with the error appears?).
It's a serious problem for me now as my system each time relies more on the data received from my Powermax system. Look at the frequency of errors:
2018-03-16 10:02:29,314   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
HTTP GET   TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->decode hex.vi->VISONIC DAQ.vi->Visonic MAIN.vi
2018-03-16 10:02:36,080   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:09:37,448   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:09:44,363   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:10:49,563   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
HTTP GET   TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC GUI.vi->Visonic MAIN.vi
2018-03-16 10:11:00,020   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:11:09,294   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:11:19,102   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:11:51,132   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:11:59,849   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:14:14,969   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:14:20,806   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:15:49,397   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:15:56,098   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:16:03,489   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:16:31,687   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:21:46,918   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:21:55,747   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:22:04,561   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:22:29,303   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:29:39,007   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:29:48,042   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:29:55,430   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:30:24,641   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:35:03,600   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:35:11,330   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:35:18,411   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:35:41,723   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:37:32,898   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:37:39,071   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2018-03-16 10:37:49,201   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
bartbakels wrote:Mario,
First the easy part, The error, is an error when the http get call can not be exectuted, probably you have a wrong url in the configurations somewhere, check the http calls you make if they are all correct.
regarding your zones, i have an idea, but is it correct that you now have for example zone 1 until 15 in use and zone 20, and 16 until 19 are not in use?
Bart
Mario from Spain wrote:
bartbakels wrote:released new version;
v1.0.7 Release With Build IN Webserver Installer Location V1.0.7 UPDATED
Changes
- BUG in HTTP GET which prevented Get command with (") and spaces
- Signal strength indicator of sensors available
MARIO please try this build for your HTTP Get Issue
Bart
Hi Bart.
I'm back from my vacation trip (good things are always very short :( ).
Tried the HTTP GET issue with (") and spaces with the new 1.0.7 version and it's working fine now. Thank you! :D
One of my sensors (zone 20) where not reporting correctly (can see the Open and Close events in the log but Last change was always 00:00:00.000 and didn't call the HTTP URL. I deleted the sensor and recreated it as zone 21 and now it's working fine. I'm not sure if the fault was on my Powermax system or in the Visonic Driver but it looks to me like a bug in the Visonic Driver affecting Zone 20 (don't know for sure if all other zones are working fine as I use just 15 zones out of the 28 my panel permits).
I still get this error very often (I don't thing it's related to previous issue):
2016-07-07 14:19:19,179   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-09 15:20:21,185   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-09 15:36:28,743   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-11 09:53:10,209   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-11 10:01:13,140   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-17 09:36:56,728   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-19 10:08:46,858   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-19 15:53:02,932   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-21 09:57:08,998   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-24 09:40:17,615   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-25 04:08:30,888   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-25 23:12:17,631   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-26 03:40:49,023   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 10:03:06,990   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 10:49:39,349   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 10:49:44,889   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 10:49:50,285   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 10:51:43,563   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 10:52:11,349   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
HTTP GET   TCP Read in Example HTTP GET method.vi->Zones ChangeHandler.vi->SensorStatesHandler.vi->VISONIC CONTROL.vi->Visonic MAIN.vi
2016-07-27 11:06:46,550   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:06:48,434   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:06:49,572   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:07:18,802   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:10:18,299   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:11:27,691   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:11:45,525   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:12:12,608   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:21:44,812   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:22:58,424   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:23:26,228   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:24:54,174   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:25:18,502   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:29:13,624   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:30:20,142   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:30:48,220   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:34:46,448   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:37:33,806   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:40:08,695   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:40:57,669   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:42:41,710   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:44:04,358   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:45:11,436   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 11:45:39,062   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:34:03,654   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:34:09,082   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:34:14,287   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:34:19,509   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:34:24,755   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:34:29,979   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:34:35,308   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:34:40,871   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:34:46,189   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:34:51,426   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:34:56,642   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:02,031   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:07,361   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:12,659   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:17,934   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:23,205   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:28,754   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:34,663   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:40,361   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:44,191   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:47,968   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:49,036   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:50,016   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:51,167   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:35:56,586   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:36:02,127   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:36:07,701   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:36:13,346   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:36:19,485   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:36:24,796   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:36:30,121   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:36:35,597   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:36:40,893   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:36:46,197   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:36:51,546   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:36:56,865   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:02,235   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:07,609   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:12,992   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:18,302   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:23,576   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:27,339   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:30,415   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:35,691   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:40,961   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:44,300   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:45,435   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:46,432   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:47,419   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:48,769   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:49,767   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:50,710   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:51,748   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:37:52,631   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:38:46,956   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:42:32,473   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:43:00,411   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:44:41,563   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:44:57,206   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:45:32,282   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:45:38,000   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:45:47,855   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:46:01,799   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 13:46:14,175   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:28:10,211   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:28:15,492   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:28:25,583   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:28:45,736   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:50:00,349   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:50:28,173   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:51:02,513   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:51:08,233   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:51:18,015   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:51:31,945   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:51:45,306   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:53:08,991   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:53:14,274   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:53:39,287   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:55:27,717   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:55:55,594   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:57:50,331   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:58:18,091   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:58:23,411   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:58:33,871   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:58:39,128   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:59:01,419   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 14:59:37,936   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:00:06,391   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:12:00,252   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:12:27,714   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:17:58,470   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:18:26,333   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:21:50,481   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:22:18,028   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:38:41,633   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:39:09,523   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:40:53,255   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:41:21,095   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:44:03,064   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:44:30,869   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:53:38,818   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:53:54,962   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:54:08,147   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 15:55:47,334   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:01:38,133   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:02:06,274   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:08:04,734   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:08:34,227   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:08:39,580   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:08:44,871   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:09:09,565   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:09:44,208   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:10:59,545   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:12:02,713   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:40:50,195   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:40:55,477   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
2016-07-27 16:41:18,484   VisonicDriver.exe   error   56   0   LabVIEW:  The network operation exceeded the user-specified or system time limit.
Mario from Spain
Postby bartbakels » Fri Mar 16, 2018 1:07 pm
Mario,
Sorry i dont get the forum updates somehow again :s
Regarding your issue, please check if the status of the panel is correct in the driver and i suspect it is:) no errors regarding the panel connection.
The issue you see is as stated before, that the http calls configured can not be executed , prob because a typo. It is not good practise to query the driver for the panel and zone state but these are being trasferred by the http cals to homeseer.
Bart
(ON ESXI )on NUC
bartbakels
Postby al30k » Wed May 23, 2018 6:43 pm
hello
do you know what can be wrong? my powermax complete only shows current status of panel(disarm, delay,armed...) (with some lags) but doestn show any other information (panel info, zones etc.) and doesn't react on pressing arm or disarm in windows app.
thanks
al30k
PreviousNext
